Page 1 of 4 123 ... LastLast
Results 1 to 40 of 154
    May 25 2012
    Eugene, Oregon
    Giant Green Injectors for 1.8t?
    I have done some searching but I do not see much about Giant Green Injectors? I have a 2002 1.8t and I am planning on Motoza Stage 1+ remote tune. I did find one person running this set up from Australia but I would like other's input/reviews of these injectors. Eventually I plan on running a K04 and believe these injectors will work with that set up. I really like the price of Giant Green's compared to TT225's. Thoughts/suggestions?
    Here are a couple listings I am looking at on ebay:
    http://www.ebay.com/itm/Green-Giant-...4dc861&vxp=mtr
    http://www.ebay.com/itm/40-lb-42-lb-...72e4a0&vxp=mtr
    Any input is greatly appreciated
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I haven't heard good things about the knock off injectors. I believe Bosch makes the real ones and I know you can find them for around $50 each.
    http://www.ecstuning.com/Volkswagen-...uel/ES1866540/
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    May 25 2012
    Eugene, Oregon
    I did see that ecs sold them. I never had intentions of buying knockoffs but now that you mention it I see that the eBay links do not actually say they are Bosch. I should have looked closer but I figured that giant greens were the name of the Bosch injectors only. Thank you!
    Jun 27 2011
    Well the tt injectors are 386cc and the green giants are 440cc. Green giants aren't bad, but if your run calls for a smaller injector then the 440s won't work that well. Almost a 20% sifference in flow rate which basically maxes out the fuel trims which is very bad.
    Short answer, get the proper injectors the tune calls for, getting different ones because they're cheaper will only cause you to "buy twice".
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    I was talking to a engine tuner about this recently and apparently according to him, the green giants have a different spray pattern that the OEM or even the TT, he suggested these
    http://www.blueovalindustries.com/en7700.html
    as they have the same spray pattern as our OEM.
    May 11 2008
    Columbus, OH
    The TT injectors are OEM as well. Some tunes specifically call for the 386cc TT injectors (APR) as their spray patter is better than the 380cc injectors. I can't remember specifically why other than the conical spray better is much better and at a better angle? I'm just spitballin'. The 440cc injectors are overkill for anything k04 or smaller.
    Senior Member Three Rings johnwiz's Avatar
    Sep 08 2012
    2021 RS5, 2004 Audi A4 USP
    Leesburg Va
    I'm running the green giants 440cc, with my Motoza Stage 1+ and my KO3 (planning for a KO4 later in the year) and it runs fine. it idles like stock and pulls well. I'm waiting for an update from Dave, but s far no issues. also highway mileag seems about the same.
    2021 Ascari Launch Edition RS5, BC Forged RZ 21 (20 x 10 ET 22); 2004 Audi USP, B&B Sport Exhaust, VMR Rims, Stoptech BBK, Motoza Hybrid K04 Tune, ER Sport FMIC, Frankenturbo F21.
    Nov 18 2012
    2003 Audi A4 1.8T quattro (slow), 2007 VW GTI (not as slow), and 2008 Honda CBR1000RR (fast)
    MD
    Quote Originally Posted by daverdfw View Post
    From what I recall, there are green tops and green giants. They are different. The green giants are what you would get because they have the same spray pattern as stock (I believe dual cone). And the other green tops do not. And they may be overkill for a K03, but it just means they won't be worked as hard. You just need to make sure the tune is setup for the size injector you are using.
    Veteran Member Three Rings AutoUnionLov3r's Avatar
    Mar 03 2011
    MK4 Jetta 2.slow-sold, MK4 GTI 1.8t-dead, TT225-sold
    Pittsburgh
    I'm pretty sure OP could run 880cc's as long as their scaled down. Correct me if I'm wrong but you can run any injector you like as long as the scaling is tuned proper?...
    I'm sure Dave @ Motoza would be able to properly scale your injectors to match your setup. If the car runs like shit, pull a few logs and send them to him and I'm sure he'll be able to tweak whatever needs adjusted.
    '04 USP
    Test Pipe, SAI Delete, Custom Intake, APR Snub Mount, 710P, Joey Mod Headlights.
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    Quote Originally Posted by AutoUnionLov3r View Post
    You are correct. As long as the tune compensates for the larger injector, all is well. However! The spray pattern with green giants is far from optimal, and they're just not the best choice. 550cc ev14's are the best you can get, and they aren't that much more. IIRC, 229 gets you a set of 8. Find a buddy, split the cost.
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    Dave will say anything over 386cc is overkill for ko3/ko4.
    Trust me that's what he told me
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
    Senior Member Three Rings p8nt's Avatar
    Jun 05 2010
    Traverse City
    Quote Originally Posted by jubei4769 View Post
    Trust us as well, that Dave can scale down 440's so that they run just fine with on a K03. While the K03 will not use the full capacity of the 440, it can be scaled to work just fine.
    Green Giant injectors are what your looking for in the 440 range, as others have noted the Green Top spray pattern in not optimal.
    Then - 04 DG USP 6MT
    Now - 02 Avus Sliver S6
    Established Member Two Rings DSKeelo's Avatar
    Aug 29 2011
    2004 A4 - 1.8FWD / 2006 Xterra
    TN
    I have a email stating with my K04-015 turbo to use the 550cc injectors?
    04 Audi A4 - FWD
    Yea, couldn't find a AWD close enough that I was willing to fork out the money for!
    Jun 27 2011
    Quote Originally Posted by DSKeelo View Post
    As stated above. You can use whatever injectors you want as long as the tune is scaled for the ones you intend to use. The 550s are a VERY good injector and are available fairly cheap, probably why they're recommended.
    Having said that, no K03/4 turbo can use more fuel than the 386cc injectors can provide. Thats what jubei was saying.
    -CP
    2017 Q7 3.0t
    Dec 03 2012
    Sydney, Australia
    Yo OP, check out my thread. I am located in Australia as well, and I got a Motoza Stage 1+ tune and used Bosch Green Giant 440ccs, I wrote a review n chit... everything you need to know is in there:
    http://www.audizine.com/forum/showth...-REVIEW-INSIDE
    Feb 09 2012
    Kailua, HI
    thanks CP, guess i wasnt clear. Yea u can use any injector, and if your gonna go BT id go with the 440s atleast. there cheap and dave can tune them in.
    May 25 2012
    Eugene, Oregon
    Thank you all for your input! Learning more and more. I actually emailed Dave today and here was his response:
    We've been doing a lot more of the 440cc stage 1+ as a stepping stone to K04 and Hybrid K04 tunes. The file is fully setup for the 440cc injectors, fuel trims will be right on. If you ran 440cc on a 380cc tune you would get pretty large fuel trims.
    If you have intentions to go with a K04 or a hybrid version such as the F21 then the 440cc is a nice way to future proof and have enough fuel supply in place, otherwise I recommend using the 386cc OEM TT225 or Genesis 380cc.
    Upgrading between tunes is only the difference in price between them, so going from 1+ to the Hybrid K04 tune is $100.
    Quote Originally Posted by BeeSicks View Post
    BeeSicks, you are actually the person I was referring to in my original post. I remember reading it awhile ago but could not locate the thread again.
    May 25 2012
    Eugene, Oregon
    Quote Originally Posted by ddillenger View Post
    IIRC? Maybe a bad question but where is this deal you speak of??
    Sep 08 2012
    Leesburg Va
    I'm one of those that went with the 440cc Green Giants with a K03 and a Motoza Stage 1+ (planning on a K04 later in the year). Car runs great, idles well (just like stock), no significant change in mileage, and a noticeable change in acceleration (just have the first tune now). Very pleased with the upgrade and looking forward to any updates he sends.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Where can you find them for 229 for 8 ?
    Mar 03 2011
    Pittsburgh
    Could you post a link for the vendor on the said $229 for 8 injectors? I'll go halves with whomever.
    '04 USP
    Apr 10 2012
    Fort Worth,TX
    i posted it a few responses up,
    8 injectors for $229
    Jun 27 2011
    47lb/hr = 500cc. So those aren't the same.
    -CP
    2017 Q7 3.0t
    Oct 14 2012
    Upstate NY
    Read the part number, google it, and then tell me they're not the same. I have a set sitting in front of me right now in the ford bags.
    Ford part number M-9593-G302 Bosch part number 0 280 158 117
    Ford may rate them at 47lbs, but they are bosch 550's.
    Dec 04 2011
    Kansas City, KS
    Damn, solid find man, thanks a lot.
    But what about connectors, do they fit or do we need adapters?
    Oct 14 2012
    Upstate NY
    Quote Originally Posted by vvenom800tt View Post
    They have EV6 USCAR plugs. Stock are EV1's. They do require adapters (on b5s that is, not sure about b6's).
    Jun 27 2011
    Damn, I stand corrected. I've got no idea what those charts say, but if the part numbers match then I suppose they're good. The fact that they're 1/2 the cost of EV14s sold at most places gives me pause, but if they're legit its a solid deal.
    Yea we need adapters: http://www.blueovalindustries.com/en...l/en4545c.html
    Again, a very good deal. 1/4 the price ofthe ones 034 sells.
    -CP
    2017 Q7 3.0t
    Apr 10 2012
    Fort Worth,TX
    now we just need a buddy system group buy!
    Mar 03 2011
    Pittsburgh
    I'm down for a group buy.
    '04 USP
    Sep 03 2009
    San Antonio, TX
    Quote Originally Posted by coowhip View Post
    I know I'm jumping in here late, but I thought GGs were pretty much a standard (meaning common injector swap) with regards to FrankenTurbos and K04 swaps?
    MY BUILD
    Oct 14 2012
    Upstate NY
    Quote Originally Posted by sa_seahawker View Post
    They were before a better alternative presented itself. Now, they're obsolete.
    Dec 04 2011
    Kansas City, KS
    In for a group buy, do we want to start a list?
    1. vvenom800tt
    2. AutoUnionLov3r
    May 11 2008
    Columbus, OH
    1. vvenom800tt
    2. AutoUnionLov3r
    3. coowhip
    May 25 2012
    Eugene, Oregon
    1. vvenom800tt
    2. AutoUnionLov3r
    3. coowhip
    4. tlee
    Dec 04 2011
    Kansas City, KS
    Well autounionlov3r do you wanna group buy with me and then and then coowhip and tlee can get together.
    Mar 08 2011
    Houston, TX
    If anyone else is interested in jumping on this I am all for it. I just ordered my Motoza tune, but would be happy to pay the upgrade to 1+ for a deal like this.
    Veteran Member Four Rings swededA4's Avatar
    Apr 02 2010
    Usually other peoples Audi's
    Greenville,SC
    1. vvenom800tt
    2. AutoUnionLov3r
    3. coowhip
    4. tlee
    5. SwededA4
    Motoza PODI BAE Parts4Euro
    BAE turbo, 550 injectors, Greddy FMIC, S4 TB,Snow meth kit, Privat Werks 19 X 8.5, Solowerks Coilovers, 034 end links, RS4 rear sway, Deval Splitter, 15% tint, 3" full exhaust with Borla 40357's, JHM trio, PODI Stepper, Recaro's
    Mar 08 2011
    Houston, TX
    1. vvenom800tt
    2. AutoUnionLov3r
    3. coowhip
    4. tlee
    5. SwededA4
    6. Mazi
    Dec 04 2011
    Kansas City, KS
    I just ordered my motoza tune as well, and i can see that + in the near future.
    Senior Member Two Rings theboss's Avatar
    Oct 19 2011
    NJ & San Mateo
    i just upgraded to the + and its better than the 1 and as much as i want to jump in on this group buy i need to pick a BAT before i purchase injectors again
    Franken Turbo / Motoza / Test Pipe / EV550 / TR18T / 034 Street Motor Mounts / Apikol Snub / APR Diverter / 2.0TFSI Coils / Gates TB / JHM Trio Shifter / JHM B7 RS4 Clutch+LWFW / Neuspeed Exhaust / KW V1's / HSport S4 Sways / 18x8.5 Miro 111's / Conti DWS 225/40/18 / 10mm Rear Spacers / B6 S4 Brakes / S4 Bixenon Ecode / S4 Upper Grill / Neuspeed SS Brake Lines / 5% tint / Boser CF Hood / AVH-X5500BHS / Audisen Bit Ten D / Speakers on Speakers / Podi Gauges
