S4/B5 with 160,000 miles. Original owner, original turbos, well maintained etc etc.
My coolant temp gauge went "erratic" about 3 months ago. Usually reading colder than "12 o'clock" where it used to be rock solid. Doesn't warm up as fast as it used to, then "cools off" and recovers on long hill ascents and similar. Oil temp looks completely normal the whole time, usually running very cool, rises for long drives uphill, cools down again on descent. The thermostat was changed along with water-pump and timing belt at 90k miles - so it's due again.
But, I thought I would change the coolant temp sensor in case it was this $30 part that was at fault. Nothing is as easy as you hope...Bought the new part at the local Audi dealership. I removed the air pipe for a better view of the rear water-rail where the sensor fits. I snapped the plastic clip immediately, got the remains out and pulled out the old sensor, which does not look good at all. I imagined it dipped in coolant the whole time, but it looked oily all over the sensor-tip and the pipe seemed only about "half-full" of coolant. I'd also thought the that coolant would run out of the hole once I removed the sensor (since the expansion tank is higher than the sensor) but that didn't happen. Does this suggest there's a blockage somewhere? If so, where? why oil on the end of the sensor?
The motor does have oil leaks which I need to work on, and it's possible that oil is leaking down on to the back of the sensor, then past the o-ring - but I don't think so.
Last of all - the dealership sold me completely the wrong sensor, different connector shape etc, so I had to put the old one back - but now I'm thinking its erratic reading is due to not enough coolant in that pipe and NOT due to a bad sensor.
Any thoughts on any of that?
Thanks,
-Richard
Scotts Valley, CA
