Results 1 to 40 of 70
    Senior Member Two Rings Dan_Q's Avatar
    May 18 2011
    2011 BMW 335i, 392 whp
    Colorado Front Range
    B8 A4: DIY Rear Differential Fluid Change
    You’ll need minimal mechanical ability for this one and 1+ qt of the proper gear oil. This is even easier than changing your oil.
    I used Redline MT-90 75W/90 Synthetic fluid.
    Step 1: Get the car up levelly on four jackstands . You need the car level in order to fill the diff properly.
    Step 2: Remove the fill plug (red) using a 10 mm allen. Remove the drain plug (blue) using an 10 mm allen as well. Always remove the fill plug first, because if you open the drain plug first and the fill plug ends up being stuck then you’re F’d.
    Step 3: Drain the fluid into a pan.
    Old fluid wasn’t looking too good (This is actually my trans fluid). I took a pic of the diff fluid as well but it looked identical. I labeled the fluids in the photo so you can tell the difference. Very tough to tell the difference at first glance.
    Step 4: Once empty, reinstall the drain plug. This is the only car I’ve ever owned that didn’t have a crush washer on these plugs. I have no idea what the torque is but I torqued it to 32 ft-lbs. Seems about right for this size bolt.
    Step 5: Pump fluid into the diff through the fill hole. I use my trusty syringe which holds about a half qt of fluid.
    Step 6: Keep filling until you get a steady stream of fluid draining out the fill hole. Mine took just over 1 qt.
    Step 7: Reinstall the drain plug (again no crush washer). Again I have no idea what the torque is but I torqued it to 32 ft-lbs because that seems about right for this size bolt. This is obviously a non critical bolt and torquing it is good practice but not all that critical. I spray everything down with brake cleaner when I'm done so that if a leak ever happens it will be evident.
    Step 8: Lower the car if you’re done.
    I do this on all my cars every 30k miles. Audi recommends never doing it and says the stock fluid will last the "lifetime" of the differential. Of course the "lifetime" of the differential will be severely shortened if you never replace the fluid. If you do it every 30k miles it will basically last forever. Total cost for 1 qt of synthetic fluid is about $8-9. Not sure what the cost of a new differential is for sure, but it seems it's probably more expensive than a quart of gear oil every 30k miles.
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Good info, thanks!
    Veteran Member Three Rings eyrah's Avatar
    Dec 17 2011
    Southern NJ
    excellent! now i have something to do on sunday, you need to come up with one of these ever week until football season starts please and thank you.
    - Pauly
    2009 Audi A4 Quattro BB/B
    AprTuned, Apr quad tip, CTS Testpipe, Eurocode HFIP, LED interior pkg, 15%/35% tint, Bi-xenon, VAG, AWE Custom valance, Customized Grill, RS6 Shift Knob, Aluminum Pedals, ST Coilovers, VMR 713
    Build Thread
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    delete - double post.
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Aug 24 2011
    SF Bay Area
    Very nice! I noticed you were able to get jack stands on the jackpoints pretty much spot on.......where did you place the jack to get all 4 stands in there?
    I think the torque specs are 26lb/ft for the drain plug and 13lb/ft for the fill plug (per a DIY for B7RS4 rear diff change)
    Senior Member Three Rings yma4's Avatar
    Dec 27 2011
    San Diego, CA
    Thanks Dan-Q! Great DIY....definitely doing this next weekend :)
    Feb 13 2012
    Las Vegas
    Great DIY! Doing this for sure!
    Love the syringe to!
    New: 2011 A4 Premium Plus Quattro 2.0T
    Old: 2009 A4 Premium Quattro 2.0T (totaled)
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Thanks Dan. Is there a spec for this fluid if Redline isn't available, and do we assume the rear dif is the same for Tip transmission?
    2011 A4 Avant
    Sep 14 2006
    I love you Dan. Beer + DIYing is so fun when you have pictures/instructions lol.
    Quote Originally Posted by jfo View Post
    I'm interested in this as well
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    I'm only at 30K miles now but do I sense a fluid change day at Jaysen's? We could buy some Redline bulk and save some dough.
    Sep 14 2006
    Quote Originally Posted by TheHeiko View Post
    Your spider sense is pretty accurate because that's what's going to have to happen. Brady should come too. I'm always down to buy in bulk and save some dough!
    -Thomas
    Current: /S3
    Dec 27 2011
    San Diego, CA
    I'm in! Tell me when gents
    Apr 05 2011
    Pacific Northwest
    Much appreciated Dan. I'm going to be in DIY heaven when I get home in a few weeks. EC Pulley, Fluids and the Rear Diff mount.
    Highlander's Build Thread
    May 18 2011
    Quote Originally Posted by eyrah View Post
    Oh don’t bring up football! We just picked up Wes Welker and it is all I can do not to think about it every 5 min. Since you’re in SD, I hope you’re not a Charger fan. Because they won’t have a shot at winning the AFC West until Peyton retires!
    Quote Originally Posted by simplicity View Post
    I’ve got two floor jacks. I start out by putting one on where each of the Lower Control Arm Bushings connect to the frame to lift the front up. If you only have one jack you could lift one side then get a jackstand in its lowest setting under that side. Then swap to the other side and do the same thing. Then repeat to get up to full height.
    For the rear I just stick a block of wood on the jack to distribute the load and jack from the rear subframe.
    13 sounds really low for a bolt that large but maybe. The bolts are big enough that 32 ft-lbs certainly isn’t going to strip them. But like I said, it isn’t a critical location so “tight” is probably tight enough.
    Any 75W/90 gear oil should work. That is the weight of the factory fluid which runs about 8X the cost and is no doubt is inferior to a high end synthetic. The diff should be identical on an automatic. The only diff that is substantially different is the optional sports diff on the S4. And I'm sure that one takes a different fluid.
    Jul 16 2008
    Finland
    Redline shockproof heavy is better for the rear diff than MT-90. Nice DIY though! I need to do mine too next time I change the oil.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by Dan_Q View Post
    Stop it. How did that playoff game go for ya. My chiefs will have somthing for ya soon.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Apr 05 2011
    Pacific Northwest
    Quote Originally Posted by TDIaholic View Post
    Why is Redline shockproof heavy better? Just for education's sake.
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Quote Originally Posted by Bezlar View Post
    Oh wishful thinking...Go Broncos!!
    [B]Current: Shopping now....
    Aug 30 2009
    Fredericksburg, VA
    Quote Originally Posted by Highlander1010 View Post
    Im in the same boat....
    Aug 24 2011
    SF Bay Area
    For the rear I just stick a block of wood on the jack to distribute the load and jack from the rear subframe..
    Thanks, I might drive the front up ramps and then jack the rear at the frame underneath the rear diff.
    Apr 05 2011
    Pacific Northwest
    That sounds a wee bit risky. The car would want to be coming back down the ramps towards you. You can block the back wheels to help I suppose.
    Jul 16 2008
    Finland
    The shockproof heavy has EP additivies, which makes it behave like an oil with higher viscosity when it comes to film thickness. It doesn't work well in the trans as it's not really compatible with synchros.
    Apr 05 2011
    Pacific Northwest
    Interesting. Do you know of anywhere to read up more on this?
    Aug 30 2009
    Fredericksburg, VA
    Just wanted to update this thread....2009's have different differentials in the rear as I just completed this and the drain and fill plugs are on the drivers side of the differential and the bottom looks different. You will need a swivel and extension to get over the exhaust to remove the fill plug. Here are a few pics I took.....
    Established Member Two Rings nikatrel's Avatar
    Mar 07 2012
    Grundy, VA
    So do we have a confirmation it is the same oil on an auto as a manual?
    Nick - Extremely busy law school student
    2009 Audi A4 2.0T Quattro Premium (APR Stage II, EC HFIC, EC Test Pipe, EC DV Valve, K&N Intake) [35% / Debaged & Dipped / H&R Sports / Vag-Com]
    Jul 16 2008
    Finland
    The rear diff oil is always the same regardless of transmission. The Sport diff could be different, I'm not sure.
    The only difference between the manual and automatic oils is that the auto tranny has its own oil, and the torsen center diff has its own oil, where as in a manual tranny the center diff shares the transmission's oil.
    Jan 24 2012
    Hong Kong
    great info!!!
    Do we need to change the front diff oil as well, or it shares oil with the transmission?
    I have been struggling to find DIY write up for the DSG oil change...
    Mar 08 2014
    Bellevue WA
    What about the seals that are included in the ECS service kit?
    http://www.ecstuning.com/Audi-B8_A4-...Kit/ES2593489/
    Mar 08 2014
    Bellevue WA
    Quote Originally Posted by feistyfoo View Post
    Did any body replace them?
    Jul 16 2008
    Finland
    Don't touch the seals unless they're leaking. I'm not sure why ECS includes them in the kit as 9 times out of 10 you don't need to replace them when replacing the diff fluid.
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Well.. Ordered this Redline MT-90 75W/90 Synthetic fluid and will try to change it.
    Now only need to change Trans fluid...
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Mar 08 2014
    Bellevue WA
    Dumb question... Should the front differential fluid be changed too? Is it possible? In my old Touareg, the procedure was practically the same for the front and rear.
    Jul 16 2008
    Finland
    If you have a tiptronic transmission then the front diff has its own oil. If you have a manual the diff and trans share the same oil.
    Mar 08 2014
    Bellevue WA
    Cool. Thanks for the info. I saw the kit for the front on ECS so I didn't know.
    Nov 17 2010
    After looking at Redline's web info, I have a question about MT90 use in the rear dif. Audi calls for GL-5 oil in the rear dif. Redline's application guide suggests MT90 for both the manual trans and the rear diff. MT90 however is GL-4 grade, which is required for the manual trans but not the rear dif. The MT90 product details then says MT90 is "not for use in differentials with hypoid gears" Isn't our rear dif a hypoid gear system? I wonder why Redline doesn't suggest their GL-5 gear oil for the rear dif?
    2011 A4 Avant
    Jul 16 2008
    Finland
    GL-5 is one of the reasons why I'd recommend Shockproof Heavy instead of MT-90. The higher the GL number, the more additives it has. Myself, I would not use MT-90 in the rear diff.
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    I will changing the rear diff oil tonight and i will be using this, will also post some pics
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Apr 30 2014
    Sweden
    Got it done last night takes 20mins, also did the B6
    Sep 20 2011
    2009 A4
    Chandler, AZ
    At what mileage are you all changing the differential fluid??
    May 24 2007
    PA
    Quote Originally Posted by k9lovr View Post
    Which one is drain and which one is fill?
