Results 1 to 36 of 36
Thread: Peeler options?
    Established Member Two Rings Capt. Slow's Avatar
    Nov 01 2012
    2013 Santa Cruz Highball C 29er
    Poland
    Peeler options?
    So I love the way the stock peelers look on B8 chassis, but the offset is too small for my taste. I'd like to avoid using spacers. I know that other Audi models use the same design with different width and offset. I've researched the topic a bit and S5 rims are out, but does anybody know of any other models which use the peeler design that would give a more flush look? Maybe TT-S or from a Q5?
    Veteran Member Three Rings LJO's Avatar
    Dec 30 2011
    Cats
    SLC
    Offset for the TT-S is high, like et51. You would be moving in the opposite direction. Your best bet is a set of 19x9 et33 S5 wheels.
    '18 A7 COMPETITION NARDO
    SOLD '11 A4 AVANT S-LINE IBIS
    SOLD '07 A4 AVANT TI MT6 IBIS
    Nov 01 2012
    Poland
    Quote Originally Posted by LJO View Post
    Yeah but S5 wheels are 19x9 so essentially you're pushing the wheel out an extra 22mm from stock I think that would stick out too much, no? Or are my calculations off?
    Are TT-S wheels 19x8.5 or 9?
    BE NICE OR LEAVE
    Apr 08 2013
    United States
    Re: Peeler options?
    Quote Originally Posted by Capt. Slow View Post
    Aren't the s4 wheels et47 and 8.5" wide? The s5 wheels would push out by 10-11 mm.
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    Stock is 19 x 8.5 ET 43...
    You would be 16.3mm wider that stock.. With the slight stretch of the 255 on a 9" you should be alright. The front's would poke a bit (3mm).
    Quote Originally Posted by steveo72 View Post
    See Above.
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    I see your dilemma, but it's so close. Does it really look that bad to you? I'm actually okay with it right where it is. I just hope I feel the same way once I get my H&R OE springs installed.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    May 03 2012
    NA
    Quote Originally Posted by VR2V8 View Post
    You won't. It looks weird how tucked they are.
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by 13S4 View Post
    If that turns out to be the case, my only recourse will be spacers........which I don't exactly like the idea of.
    Oct 14 2012
    Empty...for now...
    SE PA
    Yeah I don't really like it. Here is mine with the stock peelers with 255/35/19 ContiSport contact3's lowered on H&R OE. Not really happy with the HR OE drop....every single other car I see on here seems to have dropped farther than mine. I knew I should have just gone with coilovers in the first place. Anyway, I need at least 5mm front and 10mm rear spacers, and even then I won't be really happy with it. Better to get 9.5" wide wheels and run the 255/35's with a decent offset, then lower the car so that tops of the tires are even with the tops of the wheel arches. Anything else is a compromise aesthetically, in my opinion. On the HR OE springs I probably wouldn't do 255/35 on a 9.5" wide wheel, because the slight stretch won't look right with that much wheel gap. But I think that amount of stretch is pretty ideal looking with the right ride height and offset.
    (don't mind the OEM grille...)
    SOLD 2015 Daytona Gray S4
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by SteveYem View Post
    Just going by what I see in your pictures, I'm okay with that drop and the offset. I'm not looking for anything aggressive; just more the way I think it should have looked from the factory. This drop is all looks for me.
    Oct 14 2012
    Empty...for now...
    SE PA
    Here it is from the side just so you can see another example. I guarantee you that "shadows" are helping the wheel gap look a bit smaller than reality in this photo:
    BTW whereabouts are you near Philly? If you happen to be nearby you could have a chance to see the OE springs in person before putting out the cash.
    Dec 20 2007
    Philly Area, PA
    That picture looks fine to me as well regarding wheel gap. Even if that gap is bigger than the picture shows, it's still worlds better than OEM.
    Thanks for the offer, but these are going in regardless. In my mind there are no other options. This is a daily driver. I'm not looking for it to be a show car. I don't want to sacrifice much comfort. And I don't see the point in spending extra for coilovers if I'm only doing it for look, don't need to go that low, and would never adjust them again anyway.
    I'm southwest of the city. Media/Springfield/Swarthmore area.
    Oct 14 2012
    Empty...for now...
    SE PA
    Sounds to me that OE's are perfect for your application / preferences. I do have to agree that it's still worlds better than the stock stance, and I still have plenty of ground clearance. Comfort is pretty close to stock.
    Anyway, back on topic: Yes, the 19" peelers look great. If the S5 wheels are 19x9 that could be a good solution. It would be nice if Hartmann would make a 19x9 or 19x9.5 version of the peelers but it doesn't look like they do.
    Nov 01 2012
    Poland
    So no other models use the peeler design? I tried to look up Q5 but I think they only come in 20".
    BE NICE OR LEAVE
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Check out the Hartmann reps from Achtuning. They've got a bunch of sizes and offsets available with the correct bolt pattern and bore.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    any reason you're against spacers? i ran 5mm front and 10mm rear without issue. you could use the S5 peelers, but you might rub with 255s, so a 245 is a better size if you're lowered.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Dec 20 2007
    Philly Area, PA
    You could also try Pyspeed. They sell peeler replicas in a few different sizes, widths, and offsets. I'm just not sure who the manufacturer is.
    Nov 01 2012
    Poland
    Quote Originally Posted by staticuxo View Post
    I was thinking of doing 10mm all around but I hear all these stories of wheels falling off, hubs being damaged and vibrations. I looked at H&R but they only make 10mm for the front, can you run those in the back too? Plus its adding more components to an already complicated system. More parts = more things can go wrong. I'm still torn on that issue. Need to see S5 in person to see if I like how much they poke.
    Quote Originally Posted by Leor604 View Post
    Id rather stay away from reps.
    BE NICE OR LEAVE
    Sep 16 2008
    depends on the tires you have as well- dunlops run super wide and the conti's run narrow. my pirellis rubbed a little with 5mm front and 10mm rear. i had no vibration, no wheels falling off, etc. i ran H&Rs with extended lugs.
    hell, i'm even running 3mm front and 5mm right now with my 20x10s. no issues.
    PS. still interested in my STaSIS?! lol. if you're interested in the rear mufflers and tips only, let me know. i have the original ones still as they aren't damaged, the cat was. it would be very quiet still as everything else would be stock. let me know.
    PREVIOUS:
    Oct 14 2012
    Empty...for now...
    SE PA
    I don't think you will have any problems. From a very basic standpoint, all you are doing is sandwiching a 10mm plate between your wheel and the mounting hub, and installing new wheel bolts that are ~10mm longer than the stock ones (to accommodate the 10mm spacer thickness). I could only see a wheel falling off if a) the wheel bolts were not torqued sufficiently when installed, or b) the wheel bolt length was not increased sufficiently to accommodate the thickness of the spacer.
    For what it's worth, I've run spacers (5mm, 10mm and even 15mm) on my other car for ~15000 miles (so far) with no issues whatsoever. I'm not worried about it.
    Sep 16 2008
    to ad to this and what i posted above about using spacers on both setups on my B8 S4, i used 20mm and 25mm spacers on my S5 and also had no issues.
    PREVIOUS:
    May 21 2010
    Absolutely nothing wrong with spacers if installed properly. I've used them for years. Cost WAAAY less than new wheels.
    Oct 14 2012
    Empty...for now...
    SE PA
    This is my first experience with a car that has wheel bolts as opposed to pressed-in lugs with lug nuts. I actually prefer the wheel bolt arrangement because you don't have to replace wheel studs (which can be a PITA depending on the car) just to run spacers. Or worse yet, run adapter-type spacers (which I currently have on my other car) because the spacer is too thick to allow sufficient thread engagement using the existing studs. Then you're bolting a spacer to the hub, and bolting the wheel to the spacer. If you're doing things by-the-book, you need to drive your 50 miles and then remove the wheels and re-torque the nuts that hold the spacer to the hub, then reinstall your wheel and drive another 50 miles, then check/re-torque the wheel lug nuts.
    I would bet most horror stories of wheels falling off are with adapter-type spacers where the nuts that hold the spacer to the hub come loose. Probably due to laziness, i.e. people not wanted to take the steps I outlined above to check torque on the spacer fasteners. As much of a pain as it was, I followed those steps to give myself peace of mind and have not had any problems.
    Nov 01 2012
    Poland
    Alright, what about running the 10mm H&R spacer in the back? Its listed as a front only, but is there a difference between the front hub and the rear? Has anyone done this?
    BE NICE OR LEAVE
    Oct 14 2012
    Empty...for now...
    SE PA
    That's odd. I'm just speculating but I would say there is no difference between the front and rear hubs, based on the front and rear wheels being identical.
    Can you post up the link to the ones you are looking at specifically? (I'm also in the market for 10mm spacers on my S4 so my curiosity has been piqued...)
    Nov 01 2012
    Poland
    BE NICE OR LEAVE
    Oct 14 2012
    Empty...for now...
    SE PA
    Well, I'm stumped.
    Veteran Member Three Rings bkkchris's Avatar
    Dec 05 2006
    Los Angeles & Bangkok
    I am running 12mm rear and 10mm front on stock 19 wheels/tires and HROE. No rub, looks great (would like to go a few mm more actually), and so far zero issues with the HR spacers.
    2018 RS5 COUPE // SONOMA GREEN
    - Gone -
    2017 TT Mythos
    2017 Macan GTS Rhodium
    2014 S5 Monsoon
    2013 S4 Phantom
    2012 S4 Monsoon
    2008 S4 Dolphin
    2006 S4 Moonlight
    2004 A4 Dolphin
    Established Member Two Rings easytreez's Avatar
    Feb 28 2013
    Lake Tahoe
    There are also a lot of people that will throw 5mm spacers on and use the stock lug bolts or use them with wheels that are not compatible. As long as the wheel sits on the spacer nice and snug and you use the right length bolts you'll be fine, oh and the right torque spec helps as well.
    In the market for a B8 S4 | '08 Touareg V6 bone stock | '92 Gti VR6-T | 300+ whp at 12psi | T3/4 turbo | Wavetrac Diff | ACT sprung 6 puck | and a whole lot more...
    May 21 2010
    Thats what the site says but apparently it is wrong. My guy (Porsche, Audi, McLaren) has installed some 10mm H&R with no problem. Audi went to new larger hub...thats the culprit. Eibach 10 do not fit...I tried.
    May 21 2010
    I've spent a shi&^load of time on this (see spacer thread). Rear hub is now larger and H&R didnt think their spacer would fit but it does. Eibach does not fit in 10mm but 15 fits.
    Oct 14 2012
    Empty...for now...
    SE PA
    When you say the rear hub is "now" larger, are you referring specifically to the 2013 models?
    If that is the case, then is the bore of the rear wheel different on the 2013's?
    Nov 01 2012
    Poland
    Quote Originally Posted by easytreez View Post
    Glad you brought this up.
    What should the bolts be torqued to?
    What length bolts should I use if I want to use 12mm in the back? H&R has a 37mm bolt which is 2mm shorter and a 40mm which is 1mm too long.
    BE NICE OR LEAVE
    Nov 01 2012
    Poland
    Sorry mate, it's too loud for my taste. Plus I'm going for a sleeper look and those tips are way to massive.
    BE NICE OR LEAVE
    Sep 16 2008
    haha, well with STOCK downpipes and cats it wouldn't be loud.. but no problem. like i said, i have AWE non res downpipe and i am missing a cat, so it's MUCH louder.
    PREVIOUS:
    May 21 2010
    Bore is still 66.56 but hub is deeper so some spacers will not sit flush on car.
