I get a spool / whoo noise under vacuum but no noise at all through boooooost. Ko4's and full exhaust with no cats, aftermarket DV's. I have done a lot of searching for the answer but I can't find one with the same symptoms as I.
No burning oil from the exhaust side, and i get full boost.
It is not the high pitch screech from a dentist drill scenario but the turbos are definitely vocal.
Is turbo whoo normal under vacuum only or should i start saving?
