I am planning out my valve cover gasket job. I have everything together except the RTV to seal the corners.
I have a few questions for the Guru's here.
-Should I seal the head and cover side of the gasket or just one of them? Which?
-Should I just use sealant on the corners or a thin bead all the way around?
-Which sealant would be appropriate of these? Or any other options ?
--Black - Max oil resistance and temp 500F
http://www.permatex.com/products/pro...t-maker-detail
--Red - High temp 650F
http://www.permatex.com/products/pro...-gasket-detail
--Copper - Max temp 700F
I have also read in a post that removing the Valve cover you are sure to break the PCV valve.
How likely is this to actually break?
Thanks for the advice.
