Results 1 to 11 of 11
    May 01 2012
    Cerritos, Socal
    if you ever change your own spark plugs...
    dont forget to reconnect the coolant hose lol... stupid me. lucklily i caught it shortly few min after driving.
    still at the minimum line.
    '14 RS5 Suzuka Gray | Akrapovič Exhaust
    Dec 05 2007
    If it is slightly low you can just fill it with distilled water. Most you can do is 60:40 of water to coolant. Don't place straight G12 into there. That is only an anti-freeze for the water which does the majority of the cooling of your block (oil).
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    I didn't need to disconnect the coolant hose when I did mine. I just moved the tank around as needed and was able to get at all the plugs.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    Quote Originally Posted by PitchS4 View Post
    When are we changing the plugs at how many KM and are we replacing them with STOCK ones?
    May 01 2012
    Cerritos, Socal
    damn you big hands!
    Quote Originally Posted by Kay15 View Post
    around 80k km (50k miles) replacing with OE stock ones
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Nor did I. I just pushed it out of the way.
    I replaced mine at 30K. The factory ones looked okay, but I felt better just getting new ones, especially with the tune.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    May 14 2007
    Northern VA
    I replaced mine at 20k but it is a 2010 so they were 3 years old. Defiantly didn't need to be changed but I had just bought the car CPO and wanted to see how they looked.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Veteran Member Three Rings chuthis's Avatar
    Nov 30 2012
    socal
    Is there a DIY for changing the plugs on our cars? I feel like it'd be a fairly simple job, but would just feel better w/ instructions.
    10' S4 | 14' SQ5
    May 01 2012
    Cerritos, Socal
    not worth paying dealership $400 thats for sure. took me 30 min and hand tightened the plugs.
    Nov 30 2012
    socal
    Quote Originally Posted by ihkskim View Post
    Wow, yeah I'll def be doing this myself then. What plugs did you go with? Also, were you able to reset the service reminder yourself?
    10' S4 | 14' SQ5
    Senior Member Three Rings iceboss23's Avatar
    Jul 18 2009
    2010 S4, 2001 allroad
    Silver Spring MD
    Quote Originally Posted by chuthis View Post
    This
