Hi all,
I have this judder problem with my Alcon 365mm 6 pot BBK on DS performance pads. After about 2k kms on it, I took it to the Sepang F1 circuit. First 2 laps was a warm up lap, then on the 3rd lap i started pushing it a bit hard and it started to judder during braking and I didn't continue further. When cool and normal driving all was ok but after multiple medium braking the judder is back. Drove for a few hundred kilometers before I took it to the mechanic.
After careful inspection it was found that the brake wear was tapered ( how do I post pictures here?) Using a dial gauge, mechanics confirmed the rotors were warped ( is it so easy to warp these rotors?) so had them skimmed and bought new Pagid RS29 pads.
Bed them in as per the instructions from Pagid. Now at about 100-110kmh it starts to judder again with even light braking ..when pressed harder the judder is less. Also after a couple of medium braking, the steering starts vibrating even without any brake inputs...I've already had the wheels balanced and rotated front to back. I'm not keen on skimming the discs further..any other ideas what is causing this? Hope you guys can help out.
Regards
