Originally Posted by
fid
Thanks for letting me know! I didn't notice that when looking through the carfax.
Care to share a virtual checklist of things I should hammer the car on?
Check the tires, make sure there is some meat on them. OEM replacements are close to 400$ a piece.
Check the brakes. If they need replaced this is a 2,000$ job if done by your dealer.
Check the oil cooler lines in the front. These are known to leak and there is an updated part number. Not a super huge issue however you don’t want to but the car and start dumping money.
Check the DRC for leaks, they original units were faulty and will fail. There are updated parts for this, check if it was done.
Drive the car! (Obviously) Make sure the gears all engage smoothly up shifting and down shifting (rev match). When I got my car it had a bad throw out bearing and was a bit funny going in and out of third gear. I didn’t think much of it when I bought it but it got progressively worse fast and resulted in my dealer replacing my clutch, flyhweel and throw out bearing. It was covered under CPO but I'm sure this would have been well over 2,000$ probably close to 3,000$ and it took over a month for them to get the parts in.
Play with everything. The nav, sat radio, CD player (bring a CD to test) and SD slots. If any of these items don’t work I can almost guarantee you your dealer will recommend you replace the whole unit. Again very pricy.
Make sure the inflator kit and tool kits are in the trunk.
There is more I'm missing I'm sure. That’s just off the top of my head.
I would try and get them to pull the plugs and scope to see how bad the carbon build up is. This one’s going to be a long shot but it’s worth a shot. Done by a dealer a carbon cleaning is going to run you about 1,000$
Another side note, the car in question has Titanium package wheels on a non Ti package car. Not a big deal but to me thats a sign some one tweeked with this thing a bit. Check for modifications or any sort.
Good Luck
