    Mar 18 2012
    Houston TX
    Coolant hose diagram?
    Hey, my coolant hose snapped and I found a 2001 A6 with 2.7t. Not sure if it's the same engine as my 2001 allroad but it looks exactly the same. I know there were two types of 2.7t. Anyways The hose that is connected to the top of the radiator on the driver's side of the car goes to the little T hose that goes to the resevoir, and then the big part goes all the way down to the block. Where exactly is it going to, how is it connected and how can I get it out easily?
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    Here you go. It's a pretty straightforward, albeit complex system. The hose you are talking about goes directly into the engine block, just under the #4 cylinder. There is a spring "C" clip and 0-ring holding it in place and sealing it......and it's a PITFA to get at without extricating the engine. The tight space to work on makes this task NOT FUN at all. I suggest you also remove the driver's side fender liner and give it all you got, mate:
    http://www.auto-parts.spb.ru/cat/au/...Sr_O83WvqhKz/a
    Mar 18 2013
    States
    i would like to know the part# of the " little T hose " . not easy to replace?
    Jun 27 2010
    Palm Desert, CA
    Quote Originally Posted by lucio_liu View Post
    Part # is: N 906 930 01. Easy to replace. Make sure coolant is out of the tank, when exchanging.
    Mar 18 2013
    States
    Quote Originally Posted by Zachariah View Post
    ended up going to replace the upper hose assembly about $75 shipped. it should comes with the t piece
