Results 1 to 19 of 19
Thread: Valet button..
    May 08 2012
    Valet button..
    By accident I pushed the valet button in the glove box. Can you tell me what that does and how to turn it off.I keep pushing the button but it does not go off.Thanks for the help!
    Aug 04 2010
    Queenz/Westchester
    It limits the RPMs to 3k and keeps your trunk locked. I forget if it does anything else. Did you try shutting the car off/on? You should just be able to push it off....
    Deactivated Two Rings
    Oct 21 2012
    San Pedro, CA
    Quote Originally Posted by woodranch View Post
    try holding it down until the light turns off.
    May 08 2012
    I have kept pushing it and it will not go off and now I cannot get into the trunk!
    Active Member Four Rings DinB's Avatar
    Apr 20 2012
    O
    Quote Originally Posted by shonseb View Post
    Are you sure about the 3000rpm thing? I will need to test this.
    SOLD Ibis White RS5
    Factory: Nav., B&O, Sport exhaust, and Steel mesh/piano black trim
    Aftermarket: 20" Ti OEM wheels, 20% tint, v8 badges, dynamat in the rear parcel, Infinity Basslink sub, OEM silver tips, OEM alu-optic)
    To Do: (2014: KW HAS springs, spacers)
    "When the cat man speaks, you listen!" - Mops
    May 08 2012
    Held it in for 30 seconds..nothing.Does the engine have to be on or it does not matter.
    Apr 20 2012
    O
    Try getting out of the car. Lock it. Unlock it and try again.
    SOLD Ibis White RS5
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Doesn't hurt to try it that way and see. BTW, what does the owner's manual say ?
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by DinB View Post
    Actually Din you're right. I got confused for a sec with APR's valet mode which limits the RPMs. The 5s Valet mode just keeps the trunk locked.
    Aug 04 2010
    Queenz/Westchester
    Just looked at the owners manual and it didn't say anything about deactivation.
    May 08 2012
    I locked it and unlocked it and started the engine but no luck.
    Aug 04 2010
    Queenz/Westchester
    I'm at a loss. It's always worked flawlessly for me. You'll likely have to take it to a dealer (better sooner rather than later, being the weekend), unless anybody can come up with something else?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Maybe the button broke? I ran a quick google search and the first post that came up was this.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Apr 20 2012
    O
    So the little LED light on the button is on constantly?
    SOLD Ibis White RS5
    May 08 2012
    yes, on all the time
    Oct 27 2009
    Miami, FL | Boone, NC
    Valet button..
    I guess your switch broke. That is really strange...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 08 2012
    Took it to the dealer and need a new switch...hope my wife has enough air in the trunk till Tuesday :)
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    lolz
    '23 Tesla Model X | '17 Ducati Supersport S
    Apr 27 2004
    Pacific NW
    The real question is, what is your wife doing in the trunk in the first place and was it really an accident that you pressed the Valet button ? :)
