Results 1 to 21 of 21
    Aug 02 2012
    Boston
    Rear view camera not engaging?
    Has anyone ever had the rearview camera all of a sudden stop working? When I put it in reverse now the screen doesn't change to the camera, however the parking sensors do work. Any ideas?
    2017 S8
    Veteran Member Four Rings IanVr6's Avatar
    Jan 07 2010
    New Orleans
    Happened to me once. Turned the car off then on and started working again.
    2015 BMW M4
    2014 Jeep Grand Cherokee SRT
    2012 Audi S4 - totaled
    2008 VW R32 - sold
    2000 VW Jetta VR6 - sold
    Mar 26 2010
    US
    Quote Originally Posted by bpollock View Post
    Once in awhile, it stops working, then next time it works fine. It is one of those random gremlins (ghost in the machine), like the Audio not working or suddenly
    making a loud low frequency oscillation. It eventually works fine again.
    BMW M3 Competition X-drive
    Active Member One Ring robbrophy's Avatar
    Jul 18 2011
    los angeles, ca
    Oh yeah, that happened to me. Started flickering, kind of like static, then boom, nothing. Sensors were fine, but no camera. Dealer diagnosis was faulty chip that was installed after I bought the car because of the Japan quake problems. New chip and all is good. No problems for a year, always engages.
    Junior Member Two Rings
    Feb 13 2013
    06 M5-sold, 08 RX350
    northern ca
    Weird..This happened to me twice in the same day earlier in the week. Now no problems
    Aug 02 2012
    Boston
    Strange, seems to work fine now. Who knows!
    2017 S8
    Established Member Two Rings MikeyMikes84's Avatar
    Oct 01 2012
    Toronto, ON
    I've been getting this alot now starting on Friday. Warm weather has finally seemed to be consistent in Toronto and not sure if that is what's playing a role here. Been off and on all weekend. Anyone else experiencing this currently? 2011 model here.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Happened to me a bunch, got it on camera took it to the dealer and they changed a module in the camera system. Worked for a year after till I sold the car.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    This has happened randomly during the 4 years I have had the car. No idea of cause (it happens when cold, hot, rain, snow, from start, after driving for awhile, etc.)
    I gave up trying to diagnose it.
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Veteran Member Three Rings $nooze's Avatar
    Jan 02 2012
    Maybe audi put it in the software to see how many ppl complain to see what they can get away with lol
    '11 B8 S4 6mt
    Dec 23 2013
    Just happened to me a few times yesterday. Gonna try to get then to replace the module.
    2011 S4 Prestige | Ibis White | Black/Silver Nappa | DSG | Sport Diff | B&O | Nav | 19" Peelers | Roc-Euro Intake | LED Conversion | Supercharged Badges | VAG COM | BlackVue DR500GWHD | Passport MAX
    Mar 26 2010
    US
    Quote Originally Posted by ahc View Post
    Keep us posted, what the dealer does about it.
    Mine still does it once in awhile, two more months of the 4yr warranty.
    Dec 23 2013
    Same here warranty up in July. Gonna try to get a bunch of thugs looked at before then. I have an extended warranty but would rather just take care of these things now.
    Mar 28 2013
    Orange County, CA
    Get it taken care of under warranty ASAP, as the problem may come back - took my dealer 2 or 3 repairs to finally solve the problem. Each time they replaced a separate part until the problem was fixed, pretty annoying.
    Mar 26 2010
    US
    Quote Originally Posted by Zman84 View Post
    The problem is, every time I take it in, the rear camera works fine. It's about as effective as trying to get the door rattles fixed.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Check the hardware connections in the trunk. Mine was doing the same thing and always worked when I took it to the dealer. I just jiggled all of the connections on the passenger side trunk where the module is located ( I believe).
    Mar 28 2013
    Orange County, CA
    Quote Originally Posted by wwhan View Post
    I didn't have to show them the problem, they ran a test which triggered a fault. And/or you can record the problem on video and show it to them.
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Did it on my old b8 they ran a check and it was throwing some codes so they replaced the control unit.
    Sep 17 2013
    Philadelphia, PA area
    Happens sometimes if i start the car and go right into reverse. Without warming up at all
    2011 s4
    2011 Black S4 \ DSG \ Sport Diff \ B&O \ Black-Grey Alcantara
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by Kczach View Post
    I had experienced several intermittent failures with the camera where after putting the car in reverse, the camera would turn on properly, but after several seconds, I'd see some distortion/noise in the picture and the camera would then cut off (similar to how it does when the shifter is placed into a forward gear and the car goes into forward motion. I opened the panel in the trunk on the passenger side and saw what appeared to be fiber optic cable connections. I think there were two cables close to each other. Sorry, I didn't take any pics but the cables didn't appear to be color coded or have color traces on them if I recall correctly - they may have been dark brown or gray in color.) At any rate, all I did was wiggle them to ensure they felt like they were properly seated in the connectors they terminated into, and following that, the camera has been working without issue ever since (it's been months now). Also noteworthy was when the failure occurred, I saw an error for the camera with the VAGCOM scan - something like "Backup Camera Intermittent Failure". After checking the connections in the trunk and clearing the error, neither the camera display problem or the related scan error has returned.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 10 2018
    Australia
    Quote Originally Posted by LYKUNO View Post
    I am having the exact same issue as you described, just started today,
    The only unusual thing is that i had the side parking lights on for about 36 hours (was at hospital) then I drove it a small trip without any issues, drove back to the hospital and was trying to use the reverse camera and the flicker started. After a few seconds the camera shuts off, and even when you try to re-engage the camera or turn off/on the parking system it won’t show the camera.
    I will try your solution today.
    One other post suggested it was an issue with the Bluetooth and contacts load or data storage.
    Update: next small trip was fine.
