Results 1 to 7 of 7
    May 25 2012
    Eugene, Oregon
    G13 Coolant & Pentofrost SF Mix?
    I just noticed that my coolant is low and I am going on a trip this weekend. When I changed my timing-belt I used G13 Coolant which came in a timing belt kit from ecs. My question is whether or not I can add Pentofrost SF to G13? My coolant is quite a bit lower then the MIN line (bigger issue that I will take care of when I get back) so I wouldn't consider it an "average top-off". I have had no luck locating a thread on any site that directly references mixing G13 and Pentofrost SF. Any help is much appreciated.
    Jun 27 2011
    I assume you mean G12 coolant. But yes Pentofrost SF will mix just fine with OEM coolant. Keep a jug of distilled water in the trunk for the trip also. You never know. Distilled water is better than nothing...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 25 2012
    Eugene, Oregon
    Awesome. Thank you for your reply but no I meant G13. That is why I posted this thread. Here is the G13 that I am running:
    http://www.ecstuning.com/Search/G13/ES2603076/
    I had a feeling it would be fine based off all the searching I did but wanted others opinion. Especially since its Pentofrost SF and not Pentofrost G12++
    Feb 09 2010
    Jersey
    Pentofrost SF is G12+. Says right on ECS what can be mixed with what.
    http://www.ecstuning.com/Audi-B7_A4-...oling/Coolant/
    Past - 2008 Audi A4 2.0T Quattro 6MT S-Line Ti Ocean Blue Pearl
    Past - 2002 Audi A4 1.8T Quattro Tip Dolphin Grey
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Compatible:
    May 25 2012
    Eugene, Oregon
    Quote Originally Posted by djibouti99 View Post
    Perfect. I knew what everything could mix with but I didn't know that Pentofrost SF = G12+. No where on the bottle doesn't it mention that it is G12+ and ECS advertises it as G12+ so I didn't bother clicking on the link. I appreciate everyone's input.
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    I am going to be doing my thermostat and last time i flushed a few months go i went with the SF which is pink, but now i picked up the ++ which is purple, but since i am flushing it wont be mixed. the ++ was actually cheaper than the SF which is +
