Results 1 to 15 of 15
    Feb 01 2013
    Torrance
    Anybody run 255/30/20 on 10'' wheels?
    Title speaks for itself. Does anybody have this setup? If so, what is the offset you have and is it flush? Any spacers and what size?
    Thanks in advance!
    Veteran Member Four Rings Not A Good Idea's Avatar
    Apr 26 2012
    Hmmmm...
    Li. Ny
    Re: Anybody run 255/30/20 on 10'' wheels?
    20x10 et 20 on front with 255/30
    Very flush and I'm very slammed.
    Sent via [Random Device]!
    Oct 08 2010
    CA
    I'm same as him too ^^^^^
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    Jun 21 2008
    NYC | ATX
    Me three & all the cool kids
    Sent telepathically
    Jan 07 2011
    2013 C300 4Matic
    me 4
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    me too.. on my S4. stretch is mild- check ActivS5's thread, he has close ups of the stretch. offsets that hulk gave are nice, too.. his car is super frush. whoring time:
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Quote Originally Posted by staticuxo View Post
    Those the same wheels from your S5? No rubbing? Are you running the same size tire on the rear?
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Sep 16 2008
    Quote Originally Posted by Audiforumuser View Post
    nah, i had to sell those.. too wide and aggressive for the S4 ): i went with 20x10 and 255/30-20 all around no rubbing!
    PREVIOUS:
    Feb 01 2013
    Torrance
    Quote Originally Posted by Not A Good Idea View Post
    Holy cow! Thats such an aggresive set-up. Based on my math thats about the equivalent of stocks plus 30mm+ spacers. How is the Poke, and the having stretched tires help with the tucking?
    Veteran Member Four Rings tboooe's Avatar
    Jan 29 2012
    2013 Infiniti G37S Sedan
    San Clemente, CA
    Quote Originally Posted by alphava View Post
    Just for reference I have 20x10 et 30 front, et 23 rear. I could probably get away with et 25 on the front with my 275 tires so the 255 should be good to go.
    Good bye *sniff sniff* - 2012 Ibis S5 Cabrio (Build)|Sport Diff|Nav|B&O|CF Inlays|Adv Key|PDC
    Mods: Tint|Clear bra|BC Racing HB29 20x10et30|KW V1|AWE Air Filter|Black Optics|Ecodes|Int LEDs|RS5 pedals|HOEN|EG CF valence/splitter|SPC UCA|FL shift knob
    Feb 01 2013
    Torrance
    Quote Originally Posted by tboooe View Post
    The reason why i ask is because I currently have stock Y-spoke wheels and researching new wheels. 19x8.5 et32. Most if not all people recommend going spacers 20 front and 25 rear. But based the aggressive setup of some you guys without spacers it seems like i can ever go further like 25 front and 30 rears. But most people said that would stick out too much with spacers. Am i missing something here?
    Apr 26 2012
    Hmmmm...
    Li. Ny
    How Low Can you go? + negative camber ;)
    Sep 16 2008
    yes- think about it.. 255 is the stock size on an 8.5" wheel that you have, right? now take that same 255 and stretch it over a 10" wheel instead. the side wall gets stretched inward, allowing you to run a more aggressive offset. this is why it may seem impossible to run a 30mm up front with the stock setup vs a 10" with 255s.
    THIS!
    PREVIOUS:
    Feb 01 2013
    Torrance
    [QUOTE=staticuxo;8550987]yes- think about it.. 255 is the stock size on an 8.5" wheel that you have, right? now take that same 255 and stretch it over a 10" wheel instead. the side wall gets stretched inward, allowing you to run a more aggressive offset. this is why it may seem impossible to run a 30mm up front with the stock setup vs a 10" with 255s.
    Ahhh! brilliant!
    Sep 16 2008
    Ahhh! brilliant!
    PREVIOUS:
