Hi guys
I have an audi a4 2.0 sports auto with alt engine. I posted a thread two days ago with regards to water not regulating. People recommended that its possibly air problem and system needs bleeding. Went to my mechanic and basically everything is ok the water is regulating to the engine fine to but not so in the radiator. It's there , it's warm but just not flowing. Also after 30 mins or the radiator got warmed up.
The mechanic said the radiator is blocked possibly. The water pump works fine as the coolant was coming back in the reservoir from top hose, also pumps and belt changed at 75k. It's now at 96k. Air pressure bubbles released from the reservoir opened cap and also bleeped the system through the nozzle on top.
Can the radiator be flushed and cleaned to clear the blockage, using the special mixture and pressure washed etc or do I have get a new radiator ? Any help will be much appreciated
