Results 1 to 8 of 8
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    B6 vs B7 batteries ---same size --different output. Interchangibility?
    My car (B7) was undriven for a couple of weeks and the battery died. I recharged but it just doesnt seem to be its former self. Its the Orig battery ---'08 model year. I assume the battery was made in 2007---so 6 years old. 84K miles. I figure this is about the lifespan of an OG battery right?
    My B6 (out of commision with faulty Tstat and Valve colver gasket work thats needed) has the same battery dimensions--but a different cold cranking amps output. Will this battery work without hitch in my B7?
    Will it work in the LONG run--or will it die out prematurely? When I look up B6 batteries on an auto website like autozone--it says they wont work in a B7.
    Thanks in adavnce
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Is the cold cranking amps more or less?
    In the end all u need is 12volt battery and bigger amperage capability is better than less.
    If not worried about winter performance the CCA doesn't matter that much.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Dec 25 2004
    Earth
    OEM Battery "HEAVY!"
    Jun 15 2011
    Exiled.......
    Just looking a that pic and my battery.....where's the tie down?
    I havent gotten in there deep to check it all out.
    I got a new battery and need to change it out.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by B72011 View Post
    Thanks in adavnce
    I just looked up a B6 (2003 A4 3.0 quattro) and a B7 (2007 A4 2.0T quattro) on Autozone's website. Both came back with a group "94R" battery. The "alternate" size is group 48 which is used on the smaller engines in warmer climates. Indeed a B6 1.8T shows a group 48 battery, but here in ice cold Pennsylvania, I think they all come with the larger V6-capable battery (94R) from the factory.
    Anyway, the answer is: you're in sunny California. You'll be just fine.
    Sep 08 2010
    Asheville, NC
    look down in front of the battery its either a torx hold down or allen i cant remember
    Jun 27 2011
    ^^ Its an Allen.
    Be advised, if your car has the sport package, you need to remove the strut bar OR you need an EXTRA long allen wrench or a super skinny allen driver socket with a wobble. clearance is tight from the strut bar, though it does have a recess cut out of it to allow access...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 15 2011
    Exiled.......
    Yeah I picked itup from the guy yesterday--it came off a B6 V6--soit should fit nicely into the B7 slot.
