    Mar 03 2013
    estonia
    audi a4 b8 3.0tdi Maintenance Schedule after 200 000km
    Does anyone have maintenance schedule for audi a4 2008 3.0tdi
    I need schedule after 200 000km.
    thank you
    Madis
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Check your manual, .. should be there, or call your local Audi
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Jul 16 2008
    Finland
    The maintenance schedule doesn't change after 200 000km. Just go by what your service history states. Depends on whether your car is coded for the flexible Long-Life progrma or for fixed intervals as well.
    Mar 03 2013
    estonia
    Are you telling me that there is no gearbox oilchange, it should have on belt also? no engine chain replace ?
    I dont belive that lifetime story, because life has teached, that if you don-t change lifetime oils, chains and so one.. then you have to pay much more money to get your audi moving.
    Jul 16 2008
    Finland
    I change the oil in my 2.0tdi every 15-20 000km regardless of the LL-program. I'm not sure if gearbox oil is included in the service plan, but I did mine at 140 000km. My dealer recommends 90 - 120 000km interval for the gearbox oil change. This is for a manual trans. Brake fluid should be done every 2 years / 60 000km.
    As for the engine timing chain, it should no require replacement before 300 000km. If it doesn't make any noise it's still good. Since the chain doesn't need replacement you will need to change the auxiliary belt at some point. I would recommend every 150-180 000km.
