Results 1 to 38 of 38
    May 12 2011
    Washington
    Cool Projector Conversion Retrofit B7 A4
    Hey everybody!
    I recently decided to retrofit projector headlights into my stock halogen housings. I'm starting this thread just for the sake of showing some pictures of the outcome/process and offering advice to anybody who is currently working on a similar/same retrofit on their B7!
    I bought all parts through theretrofitsource.com, called them probably 5 times within 20 minutes as I continued to think up more questions.... They were awesome, patient, and answered everything promptly and accurately.
    I decided to buy the Morimoto Mini H1 Projectors. I also bought a few sealing/gluing supplies and "iris" shrouds: http://www.theretrofitsource.com/pro...oducts_id=4548
    SO FAR I HAVE:
    Painted the shrouds white
    Mounted them on the Projectors
    Opened up donor headlights that I found locally on CL, disassembled and painted the housings black.
    Mounted the projector/shroud in the housing and reassembled the housing.
    Now I just need to work on the alignment of the light and get everything sealed up then swap my original headlights with the new ones!!!
    Pictures (I will add several more):
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    That looks awesome!, are you keeping them white?
    Sep 03 2009
    San Antonio, TX
    creative I would be curious to see the cutoff
    I'm thinking you should go black though.
    MY BUILD
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    post pics of your car once installed!
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    looks nice!
    how much did this project cost ?
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Jun 27 2011
    Now this is the proper way to put HIDs in a halogen car. Take note all you noobs who think throwing an ebay HID kit in stock halogens is totally fine: this is the way you do it.
    Just curious, why white? Are you planning on painting the shrouds?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Senior Member Two Rings Godfather 2.0T's Avatar
    Dec 09 2009
    Won't the reflector high beams still work? Or are you wiring them as bi-xenons
    Jun 27 2011
    Quote Originally Posted by Godfather 2.0T View Post
    The Mini H1s are bixenon. If I were the OP I would use them as both highs and lows and then wire the halogen lows as DRLs or something.
    -CP
    2017 Q7 3.0t
    May 12 2011
    Washington
    Hi all, sorry for the delay in reply! I will attempt to answer most of your questions here:
    WHY WHITE?
    ---- I have painted my interior trim white and I am going to paint both my front and rear rings white, so I also have painted the shrouds white to match the theme of the car. I personally have always had a thing for white accents so that's why I painted them that color.
    HOW EXPENSIVE WAS THIS?
    I bought a $40 H1 HID kit of amazon.com, if you go that route make sure to read all the reviews so you don't buy a crap brand. All the parts from theretrofitsource including shrouds, projectors, butyl headlight sealer, and quick dry steel bonding products came out to $180 after tax and shipping. The donor headlights were $60 and I HIGHLY HIGHLY encourage you to buy an extra set of headlights if you do this because it WILL take longer than you think. Total for everything was $280. Not bad considering bi-xenons are upwards of $800-$1000....
    HIGH BEAMS?
    I will put the car back together with the high beam bulb in place but not wired up, as Charles noted the H1s are bixenon so I will be wiring them up as such.
    PICTURES!?!?!?
    They are coming! I promise! I'm quite busy lately between work and college finals (the work of the devil), but I am working on swapping the lights out as we speak. Bumper just came off and I thought it would be a good time to give an update!
    Thanks everyone for the interest, if I can finish by tonight I will take some photos and you can all enjoy ;)
    Here's my interior trim by the way:
    Feb 09 2013
    Texas
    Re: Projector Conversion Retrofit B7 A4
    Interesting. Id be down for more pics of your trim and an explanation of what exactly you did to it. Looks like a nice contrast though. I have the all black interior as well, minus the headliner if course, and I have the aluminum cross thatch looking trim. It's looking a little old and worn and I've been debating on what to do about it.
    As for the bixenons being almost $1000 I thought they were cheaper but I guess I'm mistaken. That's quite a bit of savings though overall if they work out. Plus you can go ahead and black house them. Then maybe throw in some leds like Phil does ! :-)
    2015 Audi A8L -> Soon to have upgraded RS7 turbos, intake, exhaust, tune, suspension, and S8 front and rear facelift.
    ~ Matt ~
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    TRS (www.theretrofitsource.com) is a great company and great to work with. I am running a previous offering of their (blazer fog retrofit kit) for my fogs and their ZKW-R lens swap for our e46 projectors. I would recommend them to anyone looking for projector modifications.
    @OP nice work so far, be sure to post up some nice cut off shots. I am guessing you will have better output than OEM xenons as the e46 projectors are not the greatest... (hotspots, weird cutoff shields etc)
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    May 12 2011
    Washington
    Quote Originally Posted by yagie View Post
    In regards to the interior trim, I went to Lowe's, bought 1 can of white plasti-dip for $5.98, read SEVERAL reviews explaining how to properly use plasti-dip, and removed my interior trim pieces/painted them all white! Brand new finish, customized to my liking, and completely removable by just rolling it off After wiping the aluminum trim down with alcohol, the plasti-dip sticks like a charm and looks/feels great.
    And as for the bixenons, I know you can find them in the classifieds for $600-700 sometimes but they usually have broken clips, don't come with ballasts (very expensive), or don't come with bulbs (ALSO very expensive). You can rack up a $1000 deficit really quick. I like things that make my car personal to me So I went the cheaper and more personal route. Makes sense, right?
    May 12 2011
    Washington
    Quote Originally Posted by rongeur View Post
    TRS is fantastic. Their customer service is spot-on and immediate. They supplied me with more parts than I needed as well as some extras for those oh s**t moments when something goes horribly wrong (thankfully none of that). They are THE only place I would recommend going through to order retrofit/lighting supplies.
    Here are some process pics as well as some cutoff shots, I will continue working on the adjustment over the next couple of days but this is already pretty close to how I want the end result:
    Driver's side needs a little rotation
    Enjoy!
    Jun 27 2011
    Hmm the white reminds me of teh game Portal for some reason, haha.
    Those have a great cutoff though! very nice.
    -CP
    2017 Q7 3.0t
    Veteran Member Three Rings khaos443's Avatar
    Nov 27 2011
    Ft. Worth, TX
    That's awesome! At first glance I didn't think I liked it but after looking at it a little more I like it a lot!
    06 A4 2.0T SOLD - Shopping for a B5 S4
    May 12 2011
    Washington
    My buddy said the same thing!! Funny that you mentioned that! They look like eyeballs to me, I'm hoping to make people look twice as I drive by
    Thank you! I appreciate the encouragement! This was a huge job all things said and done and I'm glad at least some people are enjoying it/appreciate the effort I put into it.
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    did you do a diy for your fogs? never saw anyone do projector fogs on our cars.
    to the op this looks great! i would love to see what they would look like with red instead of white. it would look evil on a black car
    this makes me really want to do this to my original halogens but i already have bi xenon's blacked out clear cornered with fly's leds. first world problems lol.
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Feb 09 2013
    Texas
    Quote Originally Posted by thehofhammer View Post
    This looks man as hell lol. I wonder if you could do it to both of the inner bulb areas. Pop some leds at the bottom and it'd be the coolest thing since sliced bread lol. I may have to do this. I just have standard black housed halogen and they not nearly bright enough
    ~ Matt ~
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    not diggin' the bezels around the projector, but I give you credit for doing the retrofit!
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
    May 12 2011
    Washington
    Thanks for the feedback everyone! Sounds like some are fans and some aren't but that's how it is with everything ;) I'm keeping it exactly the way it is at least for a while! Maybe LEDs sometime in the near future. Thanks again!
    Feb 09 2013
    Texas
    yeah I'm not a huge fan of how much the white stands out, but I am a big fan of the idea. Wonder how hard it would be to get the bezels hydro dipped with a graphic of some sort. could be really wicked depending on the car :)
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Woah youre a local! Would you mind maybe helping me out sometime when i go ahead and do my retrofit? They came out great
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    May 12 2011
    Washington
    Quote Originally Posted by AKOeuro View Post
    Send me a pm sometime! Let me know what your plans are and we can always go from there! I'm usually pretty busy but I can always make time somewhere in my schedule. Just let me know!
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Just kidding, i like your work. What is the OEM size of the projectors? (i think they are Valeo). I'm trying to look at the shroud options, cant find oem on ebay or else, the Iris look good.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Jun 27 2011
    Quote Originally Posted by Mister W View Post
    I think the lenses are 3" but I'm not certain. I know the b6 Bixenons were 3" so thats likely what they are.
    -CP
    2017 Q7 3.0t
    Jun 04 2011
    Clayton, CA
    OEM projectors are the Bosch E46 projectors. The lens is 3" diameter.
    Build Thread
    Active Member Two Rings steelblade's Avatar
    Feb 14 2013
    Sweden
    Does the "AUTO" function still work on the lights? When i replaced my halogens with xenon the lights are allways on....
    May 12 2011
    Washington
    Quote Originally Posted by steelblade View Post
    My car is a base model, no AUTO function so no worries! Hahah I couldn't tell you whether or not the auto function will work. If, when you say you installed xenons, you mean an HID kit, and the lights are always on.... Then it will be the same with the projectors because you still use an HID kit but just insert the bulb into the projector housing rather than the stock bulb holder.
    Feb 14 2013
    Sweden
    Yes i have a HID kit :) Thx anyway! Great job with your car!
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    that looks good hammer. I was wondering did you have to shave the iris shroud down just a tad bit as well?
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Junior Member Two Rings
    Jun 23 2013
    2006 Evo MR
    Milford
    so your projector acts as a high and low beam?
    Aug 16 2009
    Did you get a bulb out warning when you converted to the TRS MH1? If you did, how did you get rid of it? I'm considering this kind of retrofit. Thansk.
    Established Member Two Rings Contained's Avatar
    Feb 22 2013
    Houston, Tx
    Loving the white! I may have to do this to my halogens.
    2008 A4, 2.0T Quattro S-Line
    APR Stage 2 ECU (Fully Loaded) | Custom CAI | AWE Exhaust | H&R Coilovers | RAI PCV/ Catch Can | RAI FMIC | APR Testpipe | 034 TIP | P3 Vent Gauge | 145 Bar PRV | 034 RSB/ Endlinks | TSW Nurburgring 18x8.5 | APR Snub Mount | Hardwired Escort 8500X50 | Pioneer AVIC-Z130BT | 640 Mod |
    Owned/ Awaiting Install: n/a
    Retired: Carbonio CAI | 034 TIP
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2013 B8.5 allroad (current) 2007 b7 a4 (previous) 2006 vw touareg (previous) 2003 b6 a4 (previous)
    Ummm the Jersey Shore
    Enjoy!
    I have done the retrofit and need to adjust the levels of the projectors now. But like shown in the pics above, the driverside needed rotation. Did you have to rotate the whole projector or can just the bulb be rotated a bit to level the cutoff out. Trying to make the adjustments asap. The car looks so much better with hid now but the car looks like it has walleye at the moment because the beams are so out of whack. Thanks for any help!
    Miss my B6
    Oct 24 2015
    Perth, WA
    Holy necro-thread batman. Either way, glad you did, hadn't seen this.
    My respray thread
    Aug 09 2007
    Mount Airy, MD
    Quote Originally Posted by JerseyShoreA4 View Post
    You have to rotate the projector. the bulb doesn't determine the cutoff.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Nov 21 2015
    2005.5 S4 6sp Avant
    Bellingham, Washington
    curious how they've performed 3 years later. I have retro-fitted OEM HID's into my B7 Avant and they seem a tad 'fiddly' at start-up...once fully warmed-up, they seem to work great tho. I was thinking about taking my original halogens apart and going the H1 route, with a higher discharge high-beam, cleared corners and (don't flame me) full corona rings for the main lights and partials for the highs...then black it out (my Avant is Blk/Blk)
    Jun 17 2007
    Quote Originally Posted by SykoraA4 View Post
    Thats a pain in the ass... was hoping a little easier fix.
    Miss my B6
