Audi realized that not all owners are fond of this feature and issued a TSB to disable the audiopilot feature. I have added the TSB to my google drive which you can see here. The TSB is issued in '05, but I figured this would apply to all Bose systems in the B6/B7.
Although I never real felt like my stereo was as much of a nuisance as others have posted, I stil figured I would give it a try because, in general, I am in favor of pure, unadulterated audio. I went to the dealer, purchase the required pin, and went after the Bose amp. I was to add the pin to slot #24, and bridge this wire to #6, per the TSB.
However, after uncovering the bose amp harness, I already have a wire at slot #24! That was odd. Then, I checked under the map light to see if I have the Audiopilot mic, which is supposed to be in the circular slot pictured below. I doubled checked my Bentley manual; It says I SHOULD have a Bose microphone, and an empty slot in amp pin #24, as my car is newer than November 2003.
SO, does anyone know if Audiopilot was disabled from the factory after a certain year? Although the Bentley is saying I should have it, it doesn't appear that required hardware/wiring is installed. Thoughts?
