Ross-Tech, LLC
881 Sumneytown Pike
Lansdale PA 19446, USA
Tel: +1 267 638 2300
Fax: +1 215 893 3816
ShopInfoF.A.Q.Download/UpdateManualUpgradesLiterature
Search:
Throttle Body Alignment (TBA)
Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk. As always, you should refer to a Factory Repair Manual for your vehicle!
This procedure details how to perform a Throttle Body Alignment (TBA) on many VW/Audi vehicles. This procedure cycles the motorized throttle body through various states (idle, part throttle, WOT) to relearn their positions. Some examples of reasons to perform a TBA:
The vehicle's battery has been disconnected and re-connected
The ECU has been removed and reinstalled
The Throttle Body has been cleaned or removed and reinstalled
The Accelerator Pedal has been removed and reinstalled
In some vehicles, the car will not run correctly, or may not run at all without performing a TBA after one of the above operations. The TBA can be performed on both Drive-By-Wire (DBW or E-gas) as well as Cable-throttle cars as long as there is no Idle Stabilization Valve (ISV). If there is an ISV, then there is no motorized control of the throttle at all. Typically, '96-'99 VW/Audi have motorized Cable-throttle, and '00+ VW/Audi have DBW. Obviously, there are some exceptions. This should be obvious but TDI's do not have throttle bodies.
There are certain test conditions that must be met before doing a TBA:
No DTC's in the Engine Controller
Battery voltage at least 11.5 V
Throttle must be at idling position (keep your foot off the gas pedal)
Throttle body part must not be dirty (carbonized).
Coolant temperature must be between 5 and 95C
If fault codes were cleared cycle the ignition off and back on prior to running Basic Settings.
Contents [hide]
1 Cable-Throttle Engines
2 Drive-by-Wire (DBW) Engines using KW-1281
3 Drive-by-Wire (DBW) Engines using KWP-2000 or CAN
4 Drive-by-Wire (DBW) Engines using KWP-7000 (UDS/ODX)
4.1 Special Notes
5 Video Link
(These are engines with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.)
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as ADY & AEE engines)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click the [Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
(These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KW-1281 by looking in the top left of the Open Controller Screen Some examples of KW-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audi TT 1.8T)
[Select]
[01 - Engine]
Enter Group 060
[Go!]
(These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KWP-2000 or CAN by looking in the top left of the Open Controller Screen. An example of a KWP-2000 engine controller is the 2002+ B6 Audi A4 1.8T. Some examples of CAN engine controllers are the Mk5 Golf 2.0T FSI)
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
If it did not complete, or resulted in Error, see the Special Notes below.
Check to see if the engine speaks KWP-2000 or CAN by looking in the top left of the Open Controller Screen. UDS modules do not support conventional Measuring Blocks - 08 so that button will be grayed out. They do not support conventional Adaptation - 10 or Basic Settings - 04 group numbers, so all choices are found in drop-down menus in these modules.
Make sure the coolant is warm. Turn the key on but do not start the car.
[Select]
[01 - Engine]
Chose a variant of Throttle Valve Adaptation from the drop-down list
[Go!] to activate the Basic Settings
After the result of Finished Correctly appears click [Stop]
The TB may cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Special Notes
In some engines, before doing a TBA, it may be necessary to cycle the ignition off and back on after clearing faults.
On vehicles that use Cable-Throttle systems, an over adjusted (or sticky) throttle cable can cause the TBA to fail, or symptoms like no CCS (Cruise Control System) operation.
On vehicles that use Cable-Throttle systems the idle may be erratic after the TB has been removed and cleaned, even after a successful TBA. It may be necessary to drive the vehicle normally for a while until the system has re-adapted.
Video Link
http://www.youtube.com/watch?v=2zrmhDw_v7Y
Categories
Main Page
Diagnostic Procedures
Common Procedures
Fault Codes
Retrofitting
Immobilizer
Meta
Log in
Update VCDS Today
Unless otherwise noted, all content on this site is Copyright © 2000-2010 by Ross-Tech LLC. All rights reserved.
"VCDS" is a Registered Trademark of Ross-Tech, LLC.
Ross-Tech is not affiliated with the Volkswagen Group in any way.
