Results 1 to 32 of 32
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Clutch comparison
    Given the mods in my sig..
    Stage 3 ko4 aggressive e85 tune
    should I go with the fx400 or Project B5 stage X clutch with a RS4 PP?
    Which one will last the longer? And take more abuse ie launches/ spirited driving ?
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    Stick with an rs4 pressure plate and any 6 puck clutch disk. No need to spend more than 200$ on the disk as well.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Non sac fx400 pp will prob take more abuse than rs4, dont have to worry about it over adjusting.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Established Member Two Rings tag5071's Avatar
    Oct 13 2010
    Forest City Pa
    Anyone have experience with the project B5 stage X? Curious to hear how it is for a daily driver.
    01.5 Audi S4 K04 car
    1998 Jetta TDI, daily beater
    Sep 11 2009
    NE
    "Project B5 stage X clutch with a RS4 PP" is not Rs4PP. It is a sachs PP, similar or even the same as used in SB extreme clutch.
    May 16 2008
    South Texas
    Quote Originally Posted by zillarob View Post
    I'm very familiar with the B5 RS4 cover but have not seen a SAC problem not related to improper installation. However by eliminating the SAC mechanism you don't have to worry about problems with it. I know VAST used to bend the adjusting tabs on the SAC mechanism essentially defeating it.
    Quote Originally Posted by julex View Post
    SouthBend uses the SRE (Sachs Race Engineering) cover. The Stage X clutch uses a modified off the shelf OEM Sachs cover which is not made by SRE.
    May 29 2010
    2001 Audi S4
    New York
    So which clutch is your best bet to handle abuse? I'm wondering this myself.
    Veteran Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    I've been using the project B5 clutch for the last couple hundred miles. Pedal feel is light and easily driveable, and it is rated to handle a lot of tq. I had a 6-puck FX400 in the past and engagement was significantly harsher
    BMW E30 Holset hx35
    B5 S4 Brilliant Black
    B5 S4 Avant: Imola Yellow (retired)
    May 16 2008
    South Texas
    Quote Originally Posted by zdriver View Post
    Engagement is almost 100% related to the disc. Puck discs generally engage harsh.
    Jan 17 2010
    Boston, MA
    ^^ thats why I am surprised that the FX400 and Project B5 have a different engagement feel. I have the 6-puck disc for both.
    I do only have 200miles on the Project B5 so maybe the feel will change more with break in
    BMW E30 Holset hx35
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    A lighter pressure plate will soften the engagement some as it's a little more controlable. If the pressure plate or flywheel have any cup to them, causing them to not contact the disk 100% will really add to rough engagement. Metallic disks can drive nice, but almost always have a little to decent amount of chatter. They will take the heat better from slips for launching, but also break more parts if dumped.
    I can't see how this Sachs "racing" plate is so high dollar. It's a fricken stamped steel cover with a heavy spring, etc. Nothing really that special so why can't we just buy them and add our own disk (of proper thickness) and go?
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    May 16 2008
    South Texas
    Quote Originally Posted by slow ride View Post
    I'd agree, The SRE is high bucks because Sachs charges high bucks for it.
    Senior Member Three Rings Sl0w_S4's Avatar
    Mar 18 2012
    BPT
    i have a 4 puck unsprung clutch with a rs4 pressure plate. after 1k miles of average driving tried launching the car and the clutch actually slipped. also noticed if i FFS it doesnt grab as hard? do you think its because of the pressure plate? and the car is a strong stage 2+ car
    2000 S4
    Dillenger Tuned - RS4 K04 Housings with K24 compressor and RS6 turbine from SRM-JHM FMIC-034 Soild Mounts - 034 TBB
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by Sl0w_S4 View Post
    4puck should grab like a mofo. They can be pretty aggressive on the pp and fw though. I would be curious how much preload it had when installed and how much it has worn since. Does it release up at the very top?
    The Sachs pp that comes with the higher end kits is stamped out of a thicker steel than the run of the mill units, even though they look the same otherwise.
    They change the lever points internally to gain more clamp and retain the light pedal. Dont think it quite justifies the mega premium though.
    Mar 18 2012
    BPT
    [QUOTE=zillarob;8514140]4puck should grab like a mofo. They can be pretty aggressive on the pp and fw though. I would be curious how much preload it had when installed and how much it has worn since. Does it release up at the very top?
    it grabs half way and has a little chatter.
    2000 S4
    Nov 16 2010
    WetSide, WA
    Half way should be fine. I wonder if the rs4 pp just doesnt clamp it hard enough to work like it should. The 4puck cars I have driven were straight gnarly, not s4 though.
    Mar 18 2012
    BPT
    thats what im thinking. i had a fx400 in my sti and that car launched like a bat out of hell. now ive got a triple disk in it and its a huge difference, but im curious if this PP can be causing the problem, or possibly heat related?
    2000 S4
    Account Terminated Two Rings
    Aug 02 2012
    ft.lauderdale/florida
    go southbend stage 4 dxd i beat the crap out of mine
    its just a little annoying during street driving but not terrible
    Jan 29 2012
    2002 B5S4
    Wilmington nc
    I have a spec stg 3+ clutch and its been great. Full face disc will outlast a puck style disk by a lot. Soft clutch pedal too.
    02 s4 stg3, 6spd, j fonz tune, pj ko4s, 4 bar fpr, 90mm maf, ev14 72lb injectors, spec stg 3+ clutch, spec flywheel, aem wideband, no,n75 or 249, turbosmart ebc, cone filter, piggies, test pipes, topspeed cat back dual, bipipes stern pro trans mounts, koni coilovers, rs4 rep. 18 in wheels.
    Nov 16 2009
    Sandy eggo
    Quote Originally Posted by Griecos4 View Post
    Really? So a 8 puck is the best of both worlds? Does the stage X come 8 puck? How long does a 6 puck usually last on average? I know thats a really generally statement...
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Quote Originally Posted by 4ringjunkie View Post
    Hey Alex, I suggest you respond to my emails and PM's. Quit dodging me
    http://www.audizine.com/forum/showth...parts-from-him
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    May 13 2011
    2015 BMW F30
    Alert**
    This guy is a scammer!
    | Autospeed | JHM | Pure MS
    Nov 16 2009
    Sandy eggo
    Bounce to the top
    which 1 will hold, last longest with my mods
    full face clutch disc rs4 Kit or project b5 stage x or fx400 8 puck??
    Jan 29 2012
    2002 B5S4
    Wilmington nc
    Don't get a puck clutch disk if your looking for longevity. I just did a six speed swap and a lot of research on clutches. Full face clutch disk is what you want.
    Quote Originally Posted by Shhmaudi View Post
    Bounce to the top
    Veteran Member Three Rings z00lander's Avatar
    Apr 10 2010
    VW Atlas family mover
    everett, wa
    I have an unbranded stage 4 clutch and rs4pp. Can somebody explain to me why i can launch car and go wot thru all gears with 0 problems, but if i do no lift shifting as my ecu is tuned for something is clearly slipping. That is the only time i have any issue at all.
    My signature is a blank canvas of censorship
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    Rs4 pp does not have the clamping force needed for launching... Highway pulls...probably.
    I had rs4 pp and south bend stage 4 and it started slipping, upon removal noticed hot spots all over where there wasn't enough clamping force and it was slipping
    RS6 hybrids and corn
    Nov 16 2009
    Sandy eggo
    Quote Originally Posted by bigern45 View Post
    Great info, does the rs4 clutch disc mated to a south bend pp hold close to 500whp?
    Sep 28 2009
    ky
    I do not know this, I haven't had the experience with the RS4 clutch/Southbend PP. My setup only slipped during launches, even with WOT highway pulls it held fine. This is even after it was slipping bad at the strip, never once did it slip on the open road.
    Veteran Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    NYC auditioning.
    The new B7 RS4 pps seem to be doing well and drive well. I'm utilizing an AMD pp with twin-disk-like clamp load. 3200ishlbs. I will let you all know how it goes.
    Nov 16 2009
    Sandy eggo
    Mine is the same way. Except sometimes when I am taking a turn and getting all of 2nd the clutch will slip on the exit. But launching it slips, but WOT highway pulls its fine.
    Quote Originally Posted by TweetsS4Estate View Post
    Hmm might go B7 rs4 PP with a b5 rs4 clutch disc? thoughts?
    Mar 30 2008
    NYC auditioning.
    You have to have a modified B7RS4 PP inorder to run it on a stock flywheel. AMD offers a modified PP, JHM also offers a kit but requires the purchaser to buy a flywheel as well as it is unmodified. Both are great options IMO.
    Veteran Member Three Rings c0rrup's Avatar
    Oct 15 2010
    Fairfield County, CT
    fx400
    TiAL 605s | ER Intercoolers | Clutchmasters FX400 | EPL Tuning | ICS Performance
