Results 1 to 9 of 9
    Veteran Member Three Rings B6T's Avatar
    Dec 16 2008
    2009 BMW 135i M-Sport
    Master Cylinder Interchangability
    Not sure about you guys, but one thing I've always noticed about the B5 is that the brake pedal is very numb. It was like this with my two previous 1.8T A4s, as well as my S4. I tried to remedy this with my current (3rd) 1.8T A4 by installing ceramic pads, rotors, stainless lines, and DOT 5 fluid. Regardless, it still feels as though it requires twice the pedal travel to achieve the same braking force as other cars I've driven... even my girlfriend's stock Ford Focus has a more touchy pedal.
    I could upgrade to a more aggressive pad, but I'm not sure it will make as drastic of a difference as I'm expecting. It seems as though a larger bore master cylinder might be what I'm looking for.
    Does anyone know if there are any other VW/Audi master cylinders that are swappable into the B5?
    Reliable Car - 2015 Audi Q7 3.0TFSI Sport Package | Project Car - 2008 BMW 335i 6-speed RWD
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    looks like this is not only in b5s but also b6's i have the same feeling...
    Established Member Three Rings jvega21's Avatar
    Aug 25 2012
    99 A4 1.8T Q
    Chandler, AZ
    Quote Originally Posted by B6T View Post
    What about this? Would this make a noticable difference for $100
    http://www.tyrolsport.com/brakes/tyr...t-for-vw/audi/
    "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
    - Jeremy Clarkson
    99.5 1.8t. 5spd swapped. air box delete. APR stage 1. 710n DV, ICM delete/FSI coils
    Dec 16 2008
    I looked through some online part catalogs and found that there's basically two diameter master cylinders used in most later model Audis. My A4 uses a 23.81mm diameter cylinder. I checked some other Audis from the same era, and found that the C5 A6, S2 A8, and the B5 S4 use a 25.4mm diameter cylinder.
    So a master cylinder swap from a B5 S4 might be a good upgrade. To the used parts classifieds I go...
    May 09 2009
    Syracuse, NY
    You know you shouldn't be using DOT 5 with ABS systems right? DOT 4 is more than capable.
    Dec 16 2008
    My brother, a BMW tech, bled the brakes for me. I may be mistaken on it being DOT 5 though. Either way, if it's compatible with BMWs it's likely compatible with Audi.
    Veteran Member Three Rings Urtorsen's Avatar
    Feb 09 2009
    chicago
    I did the whole steel braided lines, flush, super blue ate fluid, expensive pads, tyrolsport stiffening, A8/TT upgrade up front...bled it a few times, tapped the calipers incase any bubbles stuck to the walls.......the brakes are excellent considering the size but the pedal is still as you say just a little bit too much travel, I was thinking the m.cylinder too but started to wonder if there is any bushings or something related to the mechanics of the pushrod/servo????
    The tyrolsport with the lines makes a great difference incase anybody is on the fence about it, I went for the Ecs set of lines. Both these upgrades are child's play, no more than a couple of hours work.
    Jun 30 2008
    Erie, Pennsylvania
    Just checked ETKA. The B5 A4 and S4 all use the same Lucas 25.4mm bore master cylinder. The same part number is used on the A6, including 2.7T and Allroad models as well as the D2 A8. The only different master I came across was on the D3 A8 which uses a Girling 26.99mm bore master. The ETKA I'm using only goes to 2005, so it is possible other newer models also use this larger bore.
    Honestly, after doing the A8/TT upgrade up front, the pedal is plenty sensitive for me. I can kick in the ABS with very little pedal effort. I suppose there is some "travel" to it, but I think it feels good - and I haven't even done stainless lines or anything yet.
    Feb 09 2009
    chicago
    The braking is great alright and for the effort and cost you couldn't do much better. I just remember driving one of my family's brand new b5 way back in 2000, I almost put the guy in the passenger seat through the window because of how little travel there was. And the same with most fairly fresh cars since then. Something gives way over time, I just wish I had the time and money to experiment and find out, but for a 14 yr old car though the brakes are pretty good apart from being easy to cook.
    OP..... If you go and replace the M.cyl let us know how much if any of an improvement it makes.
