I found out that a couple of my coil pack harnesses had frayed wires this weekend. I repaired the connections but the original insulation had to be cut off. Does anyone know of a split wire loom that is heat resistant? I've used the corrugated stuff Autozone sells but it does not hold up to heat well at all. I've also used the DEI wire sleeves but they are not split so I'm not sure how I could get them on the wiring without cutting off the plug.
