Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Active Member Two Rings b5racecar's Avatar
    Jan 03 2013
    miami/fl
    A4 track car build
    Hey everyone I am building a b5 1.8 turbo for a track car.
    I already stripped the interior, suspension done, garret turbo, bigger injectors, cold air intake, fmic, race seat, 5 point harness which is a big help to keep me place.
    My next step is to drop the motor and make it stronger.
    I have done a couple track days with the car and it's amazing good alignment and adjustable upper arms were great for proper setup.
    Ran it with Goodrich r1 and the car was stuck to the ground. My next step is also to work on brakes stock ones hold but not good enough. I ran it with motul 600 rbf and of course braided brake lines.
    I installed a oil cooler which helped big time my temp was always low the oil temp was perfect.
    I have pics trying to up load them but having a hard time from the iPad.
    I have a Aeb motor was looking to change the block to a newer block any suggestions.
    Thank you
    Oct 19 2011
    Tacoma. PNW
    For breaks depending on how big you want to go, I would suggest perhaps the A8 brake upgrade. If you want more you might go through with upgrading to S4 uprights and brakes.
    As for the block, the AEB is pretty strong, drop in rods will hold up nicely to larger turbos, there is a thread in the DIY and FAQ section that goes over increasing displacement if you decide you want to get into that.
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    This be awesome! which garret ?? 3071??? Those BFG R1s are grippy and low wear-rate that most users seem to experience..whats your cold pressure set up.. i would start at 30psi and adjust according when i used them..what size u run?? i have a set of 245 40 18s i can sell ya for cheap..just 4 heat cycles..hit me up if interested..
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Jan 03 2013
    miami/fl
    thanks for the reponse i like the a8 brakes option going to look into that..
    johnnybravo i have a t3 60/63 as far as tires am running 245/40/17 and i also start the day at 30psi and work from there.
    i am also runnung the aeromotive pump..looking for a good swaybar
    thanks for the help..
    http://tinypic.com/r/9rq99f/6
    http://tinypic.com/r/2mrcef4/6
    Jan 03 2013
    miami/fl
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    For an AEB I would suggest just dropping in a set of Scat H beams or since it is a track car maybe the IE Tuscan I beams or a set of Pauter rods. Any of these will drop right into the 058 block without having to modify the IM oil shaft like you would if you were to go with the IE H beam rods.
    Dec 05 2007
    Look into brake ducting. After that, there are a lot of brake options. Just stick with the 058 block unless you want to convert your engine, ECU, cluster, DBW (pedal and TB) etc for a wideband. That block has made a lot of power. Person who posted above me has that same block I believe, bored to 2L. Over 600whp.
    Jan 03 2013
    miami/fl
    Wow 600 hp that's awesome I wanted around 400hp.
    I was looking to see how to install the brake ducts. I really don't wanna go through that conversion I will keep the 058 block
    Dec 05 2007
    Brake ducting has to do with your ingenuity. You basically make a back plate with an inlet (you want this to be near the hub section of the rotor, so the air can travel through the center veins of the rotor and basically shoot outwards on the edges of them), route brake ducting (can be picked up at Jegs, Summit Racing, and the likes), and mock up something for the front. You don't need a really big brake setup (bigger is better, though) as long as you can keep the rotor cool.
    I had back plates made by a company called PureMS, but sold them a couple months back. Here are the ones I used to have, to give you an idea. I never installed them and was holding onto them for when my car was track ready. But was holding onto them for over 3 years and figured someone else could actually make use of them. So, I sold them brand new. The company no longer makes them, and not sure if they ever plan on doing another production run. But all it is is sheet metal cut properly, holes for the mounting points placed in the right spots, and an inlet directed to the right part of the rotor.
    http://www.purems.com/Products/BS001...Backing-Plates
    Here is a thread where someone made his own system.
    http://www.audizine.com/forum/showth...ght=brake+duct
    And another thread from the B5 S4 section.
    http://www.audizine.com/forum/showth...highlight=duct
    Jan 03 2013
    miami/fl
    Wow thank you for so much information on the brake ducts...
    Thank you I am going to try to make my own hopefully I have luck making them.
    You guys have been so helpful
    Dec 05 2007
    I eventually want to track my car, but will also be a reliable street daily driver. Taking baby steps, but getting there slowly. Have a fair amount of mods, but the car is not where I want it to be currently. Looking at a minimum of 350whp.
    Jan 03 2013
    miami/fl
    It was my dd until one day I went crazy and took off the interior and a/c there's nothing left lol. My goal is to build a cage. I had a custom harness bar made for it . It's a work in progress but it takes plenty of time. The hp is my problem too that's why I wanna build a soild build for the track.
    Dec 05 2007
    There is a guy in the B6 section with a really intense track car. I'll try and see if I can dig up his videos. His car is a dedicated track car like yours, and is actually a driving instructor too.
    Found it: Here is a list of his threads. Send him a PM if you want some advice on how to go about building your track car. As you can see in his videos, his is done properly.
    http://www.audizine.com/forum/search...archid=3011666
    Jan 03 2013
    miami/fl
    Sweet that's nice !!!! I had a blast with the car last track event the car handles awesome.
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    What oil cooler and suspension are you running?
    I would recommend A8 front and S4 rear brakes, 034 motorsport rear sway bar with brackets, and maybe relocate or get a lighter battery. Our car is too nose heavy.
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Looks pretty nice so far. What are your plans for tuning? Stand-alone?
    Also, any specific classes that you race in? Where are the tracks in Miami?
    "You know you have a bad idea when Ford guys are making fun of you."
    Jul 27 2010
    Queensland, Australia
    Care to share your alignment settings? :)
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
    Jan 03 2013
    miami/fl
    I am running the motol oil cooler that connects to the oil filter as far as suspension pss10 which are great.
    I think I am going to try the a8 setup and move the battery to the rear.
    Tunning maybe standalone looking into that. I run at homestead speedway hpde.
    I will put my alignment print out in a ill
    Established Member Two Rings SlowBone's Avatar
    Oct 30 2012
    Chicago
    +1 for the alignment specs. Im progressing towards my track setup, but need an alignment and pads. What pads are you currently running? i was going to run hawk HT14 fronts and hp plus for the rear all on autozone blank rotors.
    Jan 03 2013
    miami/fl
    Awesome my alignment specs are at the shop that will have to wait till Tonmorrow. As far as brake pads I ran the 9012 hawk blues and Hp plus in the rear not a big fan trying something else next time. I think with proper vented brakes you should be fine. My last session was a hour and ran the whole hour but my brakes were not holding up I think it was the brake pads and i also ran with stock rotors. Going to work on some kind of vents for the brakes. I was wondering what kind of motor oil were you thinking of using I ran the motul 300v
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Oct 30 2012
    Chicago
    honestly, i was going to run some fresh mobile 1 synthetic, and just replace it after the weekend.
    Jan 03 2013
    miami/fl
    Mobil 1 synthetic nice stuff ... Thanks wetwilly01 I was looking at
    Nov 17 2008
    I was tempted for a brake upgrade for my new DD B5. But its a b5 on budget.
    -Andrew
    Jan 03 2013
    miami/fl
    A update on my build
    034 efi llc with wide band
    Stroker build aeb motor
    Most of the car is gutted
    Looking for a bbk and some aero (front splitter and rear wing)
    Also looking for custom rollcage. Hopefully soon be installed
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    first off, you might as well delete this thread unless you get some heavy pics up of the progress.
    second, why not check out s4 hp2 calipers for the brake upgrade? I know a lot of guys think they arent much better, but once you go s4 uprights you have plenty of big brake upgrades available to you, like pretty much all newer S and RS oem calipers and of course aftermarket
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Established Member Two Rings doug9870's Avatar
    Mar 04 2010
    LI, NY
    A4 track car build
    +1 on the pictures. This is like trying to have sex via text.
    Jan 03 2013
    miami/fl
    I post some pics today. My motor hasn't arrived yet. Looking to get Porsche calipers in reference brakes.
    Doug that was awesome!!!
    Veteran Member Three Rings c0r3y.af's Avatar
    Apr 04 2012
    Warwick, RI
    Sounds like an interesting build man. Car looks great too. Looking forward to seeing some progress!
    You have those huge vents up in the front bumper that you can use for brake ducting. Good call with the stroker too.
    Jan 03 2013
    miami/fl
    Thank you ... Am trying to post pics having a hard time I will find a easier way..
    Waiting on my motor and my schrik cams and springs to get here to start..
    J&w motorsports can't wait !!!
    Jan 03 2013
    miami/fl
    I was thinking of using brake ducts from the opening of the front bumber.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by b5racecar View Post
    To post pics, upload to the likes of photobucket, imageshack or whatever, and post the url in between the [img] [/img] tags. Or click the little picture window in the replay box here.
    1998.5 A4 1.8TQM My Build
    Feb 25 2013
    MKIII Jetta,Integra GSR built B18C1T, Mazda RX8
    United States / Georgia/ SE
    I spy "gopro"..... I want to see vids!
    Ninja Edit: I have the ECS stage 2 Porsche brakes (Boxster) with A8 rotors and absolutely love them.. Relatively inexpensive for what you get, and maintenance parts (rotors, pads... etc) are easy to find and inexpensive.
    http://www.ecstuning.com/Audi-B5_A4-...tage_2/ES1188/
    Florett Silver Metallic, Black Optic, Sport Diff, B8.5 S4
    Sep 17 2005
    Fremont, California
    Great to hear you're going to be running a Stage IIc. I'm "nearing completion" (as in its still months away lol) of my B5 A4 2.0L track car as well, running a full Stage IIc, etc. The flexibility of the standalone and all the extra options can really help, especially things like the "Push to Pass" boost control. This can really help cut down on understeer out of corners and allow you to put power down much sooner while exiting; soon as you hit a straight, just hit a steering wheel mounted button and boom, 10 more PSI. On our A4 Time Attack car, this helped lap times considerably as you will always be fighting the less-than-ideal weight distribution.
    Did you already get the IIc?
    Let me know if I can help with anything.
    Quote Originally Posted by redline380 View Post
    I personally would not recommend "upgrading" to HP2 calipers. They are still a single sided large iron caliper and while they can stop pretty well during a single braking session, on the track they are pretty easy to overpower and overheat, losing modulation. Just a basic Porsche Boxster caliper with an A8 rotor will be far superior, especially as things get hotter. Modulation is often more important. If HP2's are sufficient for you (even with track pads, proper fluid, good lines, and 2 piece rotors), than you're not pushing the car hard enough.
    Apr 22 2007
    Riverbank, Ca
    Just to clarify, He said 600WHP, I think around 620-630whp?
    Thats like 800crank hp..
    Last time I was on the track I cooked by brakes. I think the right pads are the important choice here. However if you have the coin then definitely go for some bigger calipers and rotors. Maybe look at some Porsche Cayenne calipers? They are a popular upgrade.
    Dont forget to do some sort of power steering cooler as well as an external oil cooler. 20 minute time trials are one thing, but back to back or hour long enduro's and your really cooking some fluid. Change your trani and diff fluid as well, Throw in some "Shock Proof" in the trani.
    When you upgrade your rear sway bar, buy metal end links as the plastics have a lot of flex, then also forget about whatever sway bar bracket it comes with (Or buy a bar without one, my H+R bar didnt have one) and weld up your own bracket.. I made my for 1/8" flatstock bent to shape. Really simple and way better than anything else on the market.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Jan 03 2013
    miami/fl
    I already got it !!!! We can't wait to put everything together.. Just bought schrik cams am springs for the aeb head..I can't wait to learn how to setup the 034 system also got the high output coils.
    I am trying to get the Porsche boxer setup with a8 rotors
    That should be enough I hope. I will be keeping in contact with you for sure.
    Jan 03 2013
    miami/fl
    My next buy was going to be sway bars and solid mounts on motor and tranny . That's a pretty good idea on the sway bar.
    Sep 17 2005
    Fremont, California
    I don't mean to keep trying to sell you stuff , but our 25mm rear swaybar is the largest and stiffest bar out there and is available with billet subframe reinforcements.
    Our Motorsport Motor Mounts actually drive quite well, have very very little movement/deflection, and have a lifetime warranty to boot. We have Motorsport transmission mounts also, which use Delrin and are very very stiff. Combined with an Apikol red rear diff mount, some diff carrier bushings, and a snub mount/bracket combo...you'll be quite locked down.
    Sway bar frame reinforcements:
    Jan 03 2013
    miami/fl
    You guys at 034 are awesome... I love your b5 time attack car. I have a parts list that am going to order already.
    Jan 03 2013
    miami/fl
    Here's a video @ homestead been busy working on the car haven't posted anything in a while.
    Quick updates roll cage built, motor is being built as we speak went with stroker kit, 034 motorsports efi 034 swaybar,034 motor and tranny mounts, oil cooler, tranny cooler, car is gutted completely, Porsche brakes, momo start race start,and as far as suspension pss10.. started to work on the brake ducts, front spitter and looking for rear wing.
    Well here's the video I will try to upload some pics !!!!
    http://m.youtube.com/watch?v=gN2igDKjKN4
