So I'm swapping the clutch and flywheel and I cleaned out the bell housing. Bentley Manual says to use mos2 grease on the ball pivot pin and copper grease on the end of the push rod (plunger). I haven't been able to find the mos2 readily. What have you guys used? I have some belray waterproof grease I was going to use, but after research I'm not so sure it will last...can I use that or copper grease on both parts?
