Results 1 to 40 of 59
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    Wire harness repair
    So my central locking stopped working on the driver's door, and then the window stopped working. So I decided to stop being lazy and take a look at the harness.
    This is the door wiring harness connector that links up on the frame. This wasn't even the bad part, as this cleaned up pretty easily. Though i'll still be ordering a new one... they are only $10 for the connector.
    So i pulled the interior trim back to get a look at this connector 8E0972701 there should be 12 active pins on this harness for me... There were only 6 pins remaining. So i'm guessing the water damage just rusted them off.
    I looked up the wire harness this connector goes to hoping it was just a small on that connects to the main interior harness, and no such luck. It is part of the interior harness and i really don't feel like spending that kind of money. Does anyone know which repair wires I can order and solder in that would be the correct pin size? The pins that are broken are for the small 8 wires that control the door control module/window regulator.
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Re: Wire harness repair
    Nice. Mine looked similar. I think I wrote a thread on it. Its a 300 $ harness from the dealership but I rigged one together. Check my posts created. I'm on my phone otherwise id link u directly.
    Sent from my SGH-I747M using Tapatalk 2
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Jun 27 2011
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 18 2012
    Boston, MA
    Not the harness in the door. That is the picture I took, yes... but I was able to salvage the door harness. The harness I'm looking to fix is in the kicker panel under the fuse box. It is the harness that runs everywhere inside the car. I just want to repair the wires and connector socket on that harness instead of replacing the entire harness.
    Sent from my Banana Phone
    ST Performance Coilover Suspension, 18" VMR 702 Wheels, Unitronic HFC & 3" DP, BKR7EIX plugs, 2.0 TFSI Coil Packs, FrankenTurbo F21L, JE Pistons, IE Rods, ClutchMasters FX350 Clutch, ClutchMasters FW-027-SF Flywheel, Custom Tuning
    Aug 26 2005
    Quote Originally Posted by vjborelli View Post
    If the chassis side connector was damaged, then you should replace the door side harness as well. Even if it is not causing problems now, considering the condition of the chassis side harness connector, the wires between the chassis and door at the door jamb are likely near the breaking point.
    Vorsprung durch Technik
    Apr 07 2011
    There's a couple part outs on vortex, you should ask if one of them has this available still. Your best luck getting one cheap is someone with a part out. There's also someone parting a B6 out in northern CT if your willing to take the ride or convince the guy to ship it.
    http://hartford.craigslist.org/pts/3641954386.html
    Dec 25 2004
    Earth
    Audi uses the VAS 1978 Harness Repair Kit...
    Type VAS 1978 into Google.
    Dec 25 2004
    Earth
    Audi Electrical Harness Inspection and Repair Manual in *.pdf.
    http://www.google.com/url?sa=t&rct=j...43148975,d.cGE
    Apr 18 2012
    Boston, MA
    I pulled the entire harness out of the door... cleaned and inspected it for damage. The only problem there was with the door was the connector having a all that stuff all over it in the picture I showed. That all cleaned off with some electric parts cleaner.
    Essentially all I need is the contacts on the chassis side of the harness. The 4 large contacts in chassis harness are fine. There are 8 small contacts that run down the connector that were damaged... well 6 of them were damaged and broke off.
    Apr 18 2012
    Boston, MA
    So i'm going to order this repair tool, since i'm not shelling out $2,500 for the VAS kit:
    CE-70-2
    And i'm thinking this would be the repair wire.... but I think I'm only going to need the terminal ends. Anyone have the part number for just the terminal ends like these ones?
    000979012A
    Could be this one too I guess? 000979017
    Apr 18 2012
    Boston, MA
    Ok, so I went down to the deal to verify the repair wire numbers and I was right with the 000 979 012 being the correct one. And the new connector, 8E0972701, will be in on Tuesday.
    Each of the wires was $12.90 and completes 2 possible connections when you cut them in half.
    This is everything I picked up today to get ready to repair it when the new connector comes in on Tuesday.
    Apr 18 2012
    Boston, MA
    Ended up ordering the schwaben electrical repair kit through sears. It was on sale for $63 and they offer free shipping. I also had some of sears rewards points to use and brought the price down to $52.
    http://www.sears.com/schwaben-termin...;blockType=G20
    Jun 27 2011
    http://www.amazon.com/Lisle-56500-Te...connector+tool
    That works FYI. Used it on the connectors for my Sub and I'll be using it to replace the connectors for my broken MAF connector and Coil pack connectors.
    -CP
    2017 Q7 3.0t
    Jun 30 2008
    Erie, Pennsylvania
    ^Yep. I use that one too. Takes a tiny bit of finesse, but works good.
    And those repair wires are highway robbery at the dealer. Yikes.
    Apr 18 2012
    Boston, MA
    Yeah, they are very pricey. I wish I could order just the terminal contacts and use my own wire. would be much cheaper. No clue where to find just the contacts though.
    Jun 30 2008
    Erie, Pennsylvania
    I have several scraps of VW harness around. I'd be happy to harvest "repair wires" and send them out.
    Apr 18 2012
    Boston, MA
    So here is some of the stuff I have put together. I got everything working again, and now that I have the correct tools to repair harness problems, I feel much better knowing I won't have to pay someone else to do the work. I absolutely hate paying other people to do things I feel I should be able to do myself. I will say that it is mind numbing going through the Audi wire diagrams, lol.
    Driver's Door Harness Repair
    Door Terminal Part # 8E0 972 702 (T20)
    Chassis Terminal Part # 8E0 972 701 (T20)
    NOTE: (T20) is the designated name, in the Audi electrical wiring diagrams, for the 20pin terminal housing located in the A pillar for the driver's door wiring harness.
    1. Brown (2,5mm) -> Ground # 44 (Lower left A-pillar)
    2. Blue/Yellow (1,5) -> T8a/6 (Radio)
    3. Red/Yellow (0,5) -> S22 (Fuse in fuse holder/relay)
    4. Red/Grey (0,5) -> B207 (Connection "comfort", in passenger compartment wiring harness)
    5. Orange/Green (0,35) -> A146 (Comfort System High-bus Connection)
    6. Orange/Brown (0,35) -> A147 (Comfort System Low-bus Connection)
    7. "Door" Lilac/White (0,35) -> "Chassis" Lilac/White (0,22)
    8. "Door" Lilac (0,35) -> "Chassis" Lilac (0,22)
    9. ** Green/Lilac (0,35) -> T17g/13
    10. *** Green/Black (0,35) -> T10o/5
    11. Red/Black (2,5) -> S37 (Fuse in fuse holder/relay)
    12. Brown/Green (1,5) -> T8a/5 (Radio)
    13. Empty
    14. Empty
    15. Empty
    16. Empty
    17. Empty
    18. Empty
    19. * J526 Lilac/Green (0,35) -> T20/19 Lilac/Red (0,35) -> B136 (Open-comfort system)
    20. * J526 Grey/Lilac (0,35) -> T20/20 Blue/White (0,35) -> B137 (Closed-comfort system)
    Schwaben Tool CE-70-2
    ECS Tuning
    Sears
    Repair Wire - Chassis side (each wire repairs 2x terminals)
    ECS Tuning
    Here are some pictures I put together. Let me know if you have any questions, would like to add any info here, or correct any mistakes I may have made.
    May 20 2014
    e92
    Bumping this thread for an answer.
    How did you remove the connector at the chassis end? Is there a certain tab or clip I need to remove? Removed the foam insulation from the inside, unplugged the harness coming from door control module.
    I am trying add a 3 wires to the connector to get the memory seats and auto dim retrofit done.
    Excuse the wire tap. Thats what I am trying to avoid, since I am going to add 2 more wires and tapping would not be ideal.
    Apr 07 2011
    I beleive that purple clip has a some type of latching mechanism to it. Should lift and then be able to pull the harness. Not 100% sure but that's the best I could do for ya.
    Jun 30 2008
    Erie, Pennsylvania
    It's too bad about this common problem. The lucky MK5 guys got a class action settlement over this (deadline ends in 2 weeks):
    http://wiringharnesssettlement.com/
    May 20 2014
    e92
    Thanks, I tried to pry the purple tab, not too hard though. Scared that I will break it. These cars break even if you look at it the wrong way. Anyone else who have taken a dab at this?
    FIY: Its a B7, but I am sure B6 and B7 use the same connector.
    Right now, my interior is in pieces trying to sort this retrofit.
    Mar 05 2013
    CA
    OP, how do you like the Schwaben tool kit?
    Wait...so this is common, and happens over time due to repeated door opening and closing???
    May 20 2014
    e92
    Update:
    That little pink or purple plastic piece on chassis side of the T20 connector has to be slid towards the front of the car. That allows the clips on the top of the T20 connector to be depressed and push/slide in to the body of the car.
    Now to figure out how to install the new repair wires. There are pink or purple tabs. I am sure it needs to be slid to get the wires installed. Well if anyone knows, please update. I will try to figure it out as well.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Spike00513 View Post
    Yeah. It's somewhat common on all cars, really. Wires don't like to repeatedly bend in the same place forever. The MK5's got it worse than most due to the factory harness being made too short. When like half the cars have problems at 60k miles, you get unhappy people. And then you get a class action lawsuit.
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    an innovative patch product for this problem
    The driver window on my 2005 A4 stopped working, leading to discovery of the same problem. Any kind of splice in this location is clearly NOT going to last. So priced new harnesses only to run screaming from the sticker shock. Then there's junkyard harnesses. No thanks. How long before that insulation fails in turn? Then I found this:
    eBay-- Audi FLEXIBLE Door Harness Repair Kit
    which puts 20 centimeters of SILICONE insulated wires in that spot to do all the flexing. This holds out the best promise, I think, of fixing the problem for good without spending a stupid amount. It will put a mass of splices in one spot in the harness, but that spot will be well inside the door and stationary.
    Common wire insulation is VINYL, which when pure is not flexible. It's hard, rigid, and brittle a la vinyl records or PVC pipes. It can be made flexible for things like upholstery and air mattresses by the addition of plasticizers, but over time, especially when heated, those additives evaporate away and the vinyl becomes stiff and brittle again. That's what leads to this failure. The multi-strand copper conductors fail due to metal fatigue only because the insulation is cracked at that spot and rigid on either side of it, causing all of the flexing to happen at that one point.
    Basically, vinyl is a miserly cheapskate engineering solution for insulating any wire that must remain flexible. Silicone is a much better choice of material.
    The downside is soldering and heat-shrinking 20 butt splices.
    I also found great YT resources for this job:
    How to Remove Door Card Panel
    How to Remove Door Wiring Looms
    How To Replace Front Power Window Regulator (includes removing the regulator gearmotor, a step in removing the door loom versus patching it.)
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Spot-on technical description of why these wires at flex points can eventually fail. I recently had to repair trunk wires due to the severe twisting those things experience. My only comment is: if the original Vinyl insulated, copper stranded wires can last 15 years, why not just replace the flex-section with another set of 15-year wires?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    That is a nice find for a harness repair! I just replaced mine a few months ago. The harness was rather expensive but it was a fairly quick and painless replacement. I considered splicing wires but it just looked like too much of a pain in the ass. I figured, if I made it 18 years with the original harness, the replacement should last as long as I have the car.
    Jun 22 2020
    Athens, GA
    Quote Originally Posted by Turbo510 View Post
    I'd be fine with that except new vinyl-insulated harnesses with 15-yr lifespans from date of install are psycho expensive, while the "pre-owned" ones are all at least 14 years old (B7) and thus pre-deteriorated as well. I'd like to not do the repair again in a year or two. So both of those solutions have big drawbacks.
    Perhaps you mean splicing in NEW vinyl primary wires just in that flexed section? The mid-harness butt splices would be fine but I really don't want to do splices at the terminals, which means crimping new terminals to that end of each wire. With the silicone kit I don't have to deal with that, those crimps are done for me.
    If there's another option I'm not thinking of, I'm all ears.
    Nov 03 2010
    Fallbrook, CA
    Quote Originally Posted by Puddin Tane View Post
    Yes, I did mean replacing the broken wires, or all of them if preferred, with new wires of the appropriate gauges, leaving all crimp-splices or soldered joints away from the flexing area. But if you can buy a new harness section ready to plug in, that sounds like a faster solution.
    How's are things in Athens? I've got family in Roswell (my daughter), and cousins in Duluth, Loganville, and from Alpharetta.
    Jun 22 2020
    Athens, GA
    "How's things in Athens?"
    Not great. It was a more wholesome, sane place when I moved here 30 years ago. I lived on Athens' east side then. It was solid working class suburbia, mostly wholesome hard-working folks. There's a big subdivision there actually called Green Acres, and that's what it was like. It's all gone sketchy there now. Athens is... increasingly polarized, like so much of the country these days. You have all the hardcore Trumpies out in the boonies where I live and the "woke" types mostly concentrated in Athens proper and Oconee County. Athens is a blue island in a sea of red. Both sides seem to be itching for Civil War II, and they just might get it. I'm sort of caught in the middle, wishing both would grow up and realize what they're throwing away by letting teevee and "social media" play them like violins. What is it about a turd world destabilized hell-hole that calls them so? "Interesting times" is no doubt a hellish curse.
    Greater Atlanta is worse in this sense, much worse, from what I can gather. I don't know about Duluth, but most of deKalb is nowhere you want to be at night.
    Nov 03 2010
    Fallbrook, CA
    Definitely strange days. And the mainstream media plus much of social media outright wants to instigate violence, it seems. The major broadcast "news" outlets, and cable channels traffic in lies-of-omission and inuendo. The BS is off the charts!
    Anyway, some years ago my wife and I drove downtown to meet a friend of hers, staying at a hotel adjacent to Underground Atlanta. Being from California, we were unfamiliar with the area and borrowed my cousin's car to go there. We parked in a garage a couple of blocks from the hotel, and in daylight it was nice and pleasant. After dinner and sundown, the scene had changed, and was a lot more crowded. While we stood on the sidewalk talking, a hooker in heels and fishnet stockings came up behind me and barked like a dog, right behind my ear. Our walk back to the car was uneventful, but I was on heightened awareness, so to speak.
    Jun 22 2020
    Athens, GA
    Exactly. I haven't watched television at home at all in most of 30 years, don't even own one. Don't do social media, never opened a single account. My GOD I wish more people would do that! None of it "informs" or "entertains" them. It's all Orwellian propaganda that's socially engineering this country into an inescapable lunatic asylum. People need to realize: if they let "media" jackhammer raw sewage into their brains all day every day, eventually they are going to believe it as if they thought of it themselves. How much more proof do they need?
    She was probably whacked on 15 different street drugs. Atlanta is a frikkin ZOO. I witnessed similar goings on back when I did the tourist thing there, before I reached my limit for gross.
    BTW, ECS carries the only new door harness I could find. All other parts houses say "discontinued." ECS wants 327 bucks. No way in hell...
    Jun 27 2011
    I watch plenty of TV, but never the news.
    For current events I only read stories in my Fox News and QAnon Facebook groups. /sarcasm
    The whole mainstream media is all lies is sorta right sorta wrong. Plenty of outlets have really awesome journalism and actual truthful shit. But many more operate on “maximize eyeballs and clicks, truth isn’t relevant”. Most Americans have terrible BS detectors though so that stuff gets views and then get propagated everywhere. Social media in general is a cesspit of polarized nonsense that’s intentionally hyperbolic (or straight up lies) just to get more ad revenue. It’s a mess.
    Meanwhile nearly half our elected politicians are doing their utmost to gut our education system in an attempt to return to some sort of quasi/feudal system where the .1% calls the shots and the rest of us just live here in blissful ignorance.
    -CP
    2017 Q7 3.0t
    Nov 03 2010
    Fallbrook, CA
    ...nearly half our elected politicians are doing their utmost to gut our education system in an attempt to return to some sort of quasi/feudal system where the .1% calls the shots and the rest of us just live here in blissful ignorance.
    Mandatory school attendance for all kids was at one time the secret of the United State's success. But an educated population, with the skills of critical thinking, is an impediment to those who want to control those same people. Look to Cambodia's Pol Pot regime for an extreme, opposite example: People who looked smart were eliminated. The U.S. founders knew how important education was, because of their familiarity with the kingdom's in Europe, and so designed the new government to have limited responsibilities, such as national defense and relationships with foreign countries. It was supposed to be the people's government.
    The situation today, sadly, seems to be the deliberate gutting, as you say, of that education system. Covid, which has almost no effect on normally healthy kids, is the excuse for them to not attend school. What instruction many of them do get is that the United States is a nation of hatred and oppression, and where the flag is often not allowed in the classroom. Parents who complain about that, or the current fascination with transgenders, or of the teaching little kids of oppressor vs. oppressed groups, were called domestic terrorists by the American Federation of Teachers. A number of moms and dads have been arrested at board meetings, with even the FBI being involved to investigate these parents for terrorism. So no, I don't think any of this is just coincidence (apologies for the non-B6 rant).
    Jun 22 2020
    Athens, GA
    Plenty of outlets have really awesome journalism and actual truthful shit...
    Stuff like the Stalinist handling of Darrel Brooks and the Waukesha Massacre has me totally and permanently alienated at this point, and it's been going on for a looooong time all across the board. Remember Stephen Paddock, the Las Vegas shooter who killed 60 people and injured hundreds by firing on a country music concert with automatic weapons? He was a LEFTY with a Latina wife who wanted to murder lots of Trump voters over the Border Wall, etc., and so he did, and he had planned it for months, but when a lefty gun nut goes on a politically motivated killing spree or a black goes on a hate whitey rampage, "our" traitor government and the WHOLE media, ALL outlets are like "duh, we dunno why he did it. Who knows? It's a MYSTERY. We'll never know." But when a white guy does an Eric Rudolph or kills a black for ANY. reason. whatsoever. we never hear the end of their screeching and posturing about white supremacy, domestic terrorism, systemic racism, blah blah blah... Excuse me, why didn't Stephen Paddock have them doing that over leftist terrorism? They're so blatantly corrupt and biased they make me puke. You had to totally distrust them in the first place to catch their Orwellian sanitizing of Paddock, otherwise it went right under your radar.
    Jun 27 2011
    What is a leftist? Or rather, what do you define as a leftist?
    Extremists are extremists, regardless of which side they’re on. Personally I view it as a circle go too far either direction and they circle back on themselves.
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    100%
    They're not scared of you. They're scared of what you represent to 'em.
    Nov 03 2010
    Fallbrook, CA
    There are the preferred narratives, and there are the inconvenient facts. The Las Vegas shooting episode is a great example. I grew increasingly dubious as time went on and the official story never changed: "there is no known motive". Or how about the George Zimmerman/Travon reporting - NBC edited the 911 audio to take out the operator's question to Zimmerman: "OK, is this guy White, Black, or Hispanic?" The broadcast version was "There's a real suspicions guy, he looks Black". Or another classic. Katie Couric's documentary "Under the Gun" was deliberately manipulated to make gun rights folks look stupid when asked a simple question about background checks. That group was asked to be absolutely silent for 10 seconds for an audio equipment calibration, when in fact that was the ruse to get video of a bunch of "gun nuts" looking clueless when asked an obvious question. And I could go on and on, but I've bored you guys enough.
    Jun 22 2020
    Athens, GA
    ...but I've bored you guys enough.
    You ain't boring me. Thanks for understanding.
    Jun 22 2020
    Athens, GA
    I use "left versus right" as a matter of convenience because it communicates, but I actually think it's a false paradigm. Those are really names of two large herds herd-thinking in reaction to each other in ways that make both a single set of mental captives serving a single program comprehended by neither. Meanwhile there are two objectively real poles that vaguely correspond and can be demonstrated throughout the entirety of civilized history, but if I used accurate terminology for them, such as "Sargonites" versus "their pathetic winged monkeys," no one would understand what I'm going on about.
