Results 1 to 10 of 10
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    MAF sensor wiring
    I'm trying to fix a torque intervention problem that I'm having whenever I plug the MAF in. The PO cut the MAF harness as it was a maf less tune, so I got a junkyard harness and I'm trying to splice it back in.
    I got the wiring diagrams off of elsawin and got the 4 pins wired, but the black wire that is shielded with the green signal wire is just hanging right now. Elsawin says that it is a shield wire, and it terminates at the shielding for the green wire. Does this mean I just connect it to the shielding and that's it? Or should I ground it with the ground pin of the MAF? TIA
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    green is signal and plugs to maf and iirc the shielding is connected to ground back in the harness somewhere.
    http://nefariousmotorsports.com/foru...p?topic=2839.0
    contact via email please.
    May 22 2011
    South Jersey
    Quote Originally Posted by k0mpresd View Post
    Green is signal, yes. I am concerned about the black wire that shares the same shielded loom. The black wire meets the other shielded black wires in the ECU box, and then to the ECU. I am wondering if the black wire not being connected can send a wonky MAF signal. I can start and drive the car for about 10 mins before I get an EPC light, and a torque monitor 2 DTC.
    NefMoto Tuned
    so youre saying there are 5 wires going to your sensor?
    there should be 4 wires.
    bosch ecu/maf pin:
    connects to 12v somewhere in car / 2 / +12v
    27 / 3 / ground
    53 / 4 / +5v
    29 / 5 / signal
    so maf pin 3 goes to ecu pin 27, ect.
    May 22 2011
    South Jersey
    bosch ecu/maf pin:
    27 / 3 / ground
    53 / 4 / +5v
    29 / 5 / signal
    No, only 4 wires go to the sensor. I have connected the +12v, +5v, ground, and signal wires. The green signal wire is shielded/insulated along with another black wire. I am wondering where this black wire terminates at the connector. Do I just leave it unconnected or do I ground it to the shielding? I am not home right now, so I can't post the wiring diagram to help illustrate what I mean.
    If I could see a pic of a stock MAF connector and where all the wires go that would be great.
    Although I do remember now that the MAF harness got melted a bit at one point. I'll bust out the multi meter and report back.
    NefMoto Tuned
    Dec 05 2007
    I cut my connector off too for my wire tuck and have the connector in front of me. That black wire just comes out the shielding with the green wire (pin 5) and just sits there. Connected to nothing.
    May 22 2011
    South Jersey
    Thank you very much. I guess my next plan of attack is to look at that melted portion. It didn't look like it melted all the way through but we shall see.
    NefMoto Tuned
    Dec 05 2007
    Why not place the fully intact junk yard harness into your vehicle and keep your current one as a spare or parts one? More work yes, but just a better alternative IMO.
    May 22 2011
    South Jersey
    "New" AWM harnesses are upwards of $100, and I have already stripped and re-wrapped this harness multiple times, moved wires around, re-routed, deleted hardware, etc. It's just easier for me to figure out what's wrong, and I don't mind the troubleshooting.
    NefMoto Tuned
    Dec 05 2007
    I paid like $125 for my current one, but it was in like perfect condition. Then I seen a "brand new" one from a Passat (AWM) being sold for the same price like 2 months ago. I wanted to pick it up so bad just on the premise of "because" . But I think another AZ member scooped it up (he sort of asked me not to bid, so I didn't. and there was only one bid at the end of the auction).
