Results 1 to 7 of 7
    Feb 27 2013
    lawrenceville/Ga/30044
    Upgrading my MAF sensor to an Audi TT 225hp MAF sensor.
    I got a 2001 a4 stock ecu for now and exhaust. I currently have the audi tt 225 injectors and fuel pressure regulator. Also have k03/k04 hybrid turbo. Now i want to put in the maf sensor from the 225.
    Im wondering if anyone has upgraded their maf sensor and what their experience has been? Will it help gain power with the stock ecu or do i need to upgrade my ecu?
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I dont know if any one has? I would say I dont think you see much difference (maybe worse) unless you get a tune. the car will still only be calling for stock specs its just alot easy now (air flow) more room to breath. Are you going to use the tt maf housing too or just the sensor?
    SOLD the GOINHAM A4 ---> GT2860 Project
    Oct 30 2009
    Miami, FL
    You can't just swap MAFs, best case your car will run worse than before, worst case it won't run at all. Install whatever parts your tune calls for, anything else won't work. Don't think about swapping housings either, that will just make your car run lean, which could lead to detonation and a nice hole in a piston or the block.
    2018 S5 Coupe - stock for now
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    You'll need a retune. What file is on the ecu now?
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    Quote Originally Posted by Mad Cow View Post
    All bosch MAF sensors are the same, the housings are different.
    To OP, you'll need a retune. MAF housing diameter is programmed into the software.
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by catbed View Post
    Not all of the sensors are the same either, which is why there are part numbers with a different letter at the end even though they are the same MAF housing. This is how many A4 1.8t owners got into trouble when they tried running a really cheap sensor/housing from a NA VW.
    May 22 2011
    South Jersey
    Quote Originally Posted by M-Hood View Post
    Understandable. I should've clarified I was talking about the FI MAF sensors.
    NefMoto Tuned
