Results 1 to 34 of 34
    Active Member One Ring acar7145's Avatar
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    A4/B7 DYI License plate LED ERROR fix
    So i went ahead and took the risk of replacing the license plate bulbs with LED's and as expected! got the error on the dash... i tried it for a couple days and decided to switch to a new set of canbus bulbs with heat sink after i got annoyed of the error light. To my surprise not only did i get the error light again but there was a beep sound every 2 seconds which drove me crazy and got me to do a bit of research for the solution. i came up with different solutions as far as resistors but couldnt come with one resistor since people posted using 10ohm 25W, or 50w 3ohm, etc. so i came across a post that looked like the setup was similar to mine and decided to try it. thank god i did now im riding error free!
    So i decided to do a post and see if i could help anyone else having the same issue! (this worked on my car, im not resposible for any damages done to your vehicle)
    Tools needed:
    1. Screw driver
    2. (2) 100 ohm 1W resistors (Got mine at radioshack)
    3. Heat Shrink
    4. (2) Canbus LED bulbs
    5. Lighter (to heat heat shink)
    ________________________
    1. Remove the license plate light cover by removing 1 screw from each side. Then remove bulb.
    2. grab your resistors! here are the ones i used...cost about 2$ at your local radioshack
    3. Then what i did was slide the resistor inside a piece of heat shrink and using my lighter heated the shrink a bit so it would wrap around the resistor. (i gave it two layers of heat shrink just in case).
    4.Then i pretty much wrapped each corner tip of the resistor to the connecting pins on the license plate light housing. You can also weld it but for me it was tight enough and making contact without the need to weld it.
    I first did it to just one bulb because somewhere i read you just needed to add the resistor to one bulb but when i installed them the error light went off for the license plate but gave me a left foglight warning and foglight wouldnt turn on. So i then added another resistor to the other bulb using the same process as the first, got them installed and worked perfectly fine. now my foglights and headlights work fine as well as the LED license plate light and all without any errors on my dash!
    i forgot to take pics when it was done but i'll see if i can do that today and show you the final product! i hope this helps some of you with the same issue.
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    This may be a dumb question, but after reading a lot of "bulb-out warning" threads/fixes, can the error just be coded out?
    Apr 05 2010
    wow...that led has a awesome heatsink itself.
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Quote Originally Posted by Guitarmageddon View Post
    as far as im concerned im pretty sure you can get rid of it via VAG-COM, now im not sure if this is a permanent or temporary solution so i pretty much went with what i had at the moment
    Jun 27 2011
    Nope.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Get ready to have some melted lighting housings! Or at least a lot of browning. There is a write-up on this already, and I cover exactly what you need for this specific circuit. The circuit in the car draws out around 3.8w If I remember correctly, your resistors having a power rating of 1w are going to sizzle really fast my friend. That heatshrink your putting on is only going to cause the sizzling resistor to burn and deteriorate much quicker.
    If you give 2 shits about what I think, you can read this. I kind of summarize it up:
    If you want to know the details about the resistors, it's this: When you replace the OEM bulbs which which have a resistance of 37 Ohms, with LED's, what you're essentially doing is eliminating that 37 Ohm's of resistance. This is because LED's have next to no resistance properties to them. You NEVER consider them a load. Now, because that OEM bulb is not in the equation and LED's have no resistance, you have a straight 12v shooting through the LED's and the ampere rating is almost non-existent. The cars Canbus system reads this, and displays this fault as an error out light display. So what we now have to do, is find a resistor that can match the value of the OEM Bulb to take it's place. a 37 Ohm bulb and a 12v power source gives you an ampere rating of .32 Amps. This is what your car wants to see. So now we need to find a resistor that will produce the same ampere rating when shooting 12v through it. I used the 50 Ohm resistor, so this with 12v will produce an ampere rating of .24 amps.
    You're probably saying, well that doesn't match the cars OEM bulb at all??? Well, the LED's have a very minute resistive property, so tacking on a .006 milli-Amp or so will raise the .24A VERY close to the .32A the car wants. This is also why this DIY should be labelled that this will work using THESE specific LED's and THIS specific resistor. Different LED's will have different resistive properties and can but probably wont alter your values. This DIY I came up with was what i found worked best for my application. This will not work for every Audi model
    Now when it comes to the Wattage, the 5w as we see on the resistor, that is simply stating how much power that resistor can dissipate. The OEM circuit draws 12V x .32A = 3.84 wattage. This resistor can withstand up to 5w, so in this application, you're good to go.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 26 2008
    Op listen to shweini, he knows his led/resistor stuff
    May 21 2007
    Florida
    I had those bulbs and they burnt out in about 6 months. Said fuck it and spent the $45 shipped for the ECS assembelies and am very happy I did so.
    2018 Navarro Blue Q5
    Oct 16 2008
    South Florida - Ft Lauderdale
    Coming soon
    Phil
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    lmao ^
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Quote Originally Posted by Schweini View Post
    Hey thanks for the info! and of course i care and im glad you pointed this out since im a newbie pretty much at this, so which resistors should i go with?
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Coming soon
    Phil
    So what do you recommend? which resistors should i use?
    Oct 16 2008
    I don't want to beat a dead horse here but a DIY is posted in the tech section.
    However, I have been criticized because it seems that I am always doing more complicated than necessary.
    Put it this way: for me, safety and reliability are a must but at the end, do whatever you want it's your car.
    Phil
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Phil
    Hey im not here to judge but to share ideas and learn! Since you post a picture of a car in flames i do want to hear what you got to say it might help me in the end so all help is greatly appreciated and you could post which thread has the info ive seen a bunch but im a newbie here with not much experience on audis
    Oct 16 2008
    And since you are close to me, get the parts I did and I will be glad to install them for you free of charge.
    Why?
    Just because I care
    Phil
    Feb 26 2008
    Why?
    Just because I care
    Phil
    Now that is a good man right there
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by acar7145 View Post
    You're welcome, the only thing you did wrong was use the wrong resistor. Other than that, your logic behind it all is pretty spot on.
    You'll want two 50 Ohm, 5 Watt resistors. Replace them with the ones you bought and you're good to go for $3-$5
    these are the exact resistors I used, bought I didn't buy a pack of 5. Search ebay and you'll find them.
    http://www.ebay.com/itm/50-ohm-5-Wat...item3a7b4c39a2
    EDIT: wow, actually found a better deal than the ones I originally purchased, $2 for 10
    http://www.ebay.com/itm/Ten-Ohmite-5...item1c2fcb5f80
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 25 2011
    Seacoast NH
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Coming soon
    Phil
    Well, i dont want to be dramatic, but that give's me job, and job give's me money, a money buy mods. So hey! buy what ever resistor you want ;)
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    just ordered these, thanks for the link! now I've got to figure out how to get the light housings out because both phillips heads are stripped. looks like I'll be pulling the whole assembly and drilling....fun for me!
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Thanks i really appreciate the help! im gonna buy those today!
    Jan 27 2013
    07 Dodge Ram 1500
    Miami, FL
    Why?
    Just because I care
    Phil
    which parts do i need to get? and i didnt notice we were close by! thanks for the offer i might take you up on that one lol..
    Oct 16 2008
    Anytime
    http://www.audizine.com/forum/showth...oblem-Solution
    Phil
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by mcbuck View Post
    No problem. yeah, my screws got stripped very fast as well. I had to put some modified self taping screws in there to keep the housings on nice and strong. Those OEM screws are soft.
    No worries. I wish I could buy some too, they won't ship to Canada
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 25 2011
    Seacoast NH
    Mine started to get stripped as well. Phillips was not working, so I used a mini flathead that was really narrow at the end, and jammed it into the soft metal just enough to start the screw turning.
    Mar 21 2010
    Charlotte-ish
    no idea what it would cost to ship, but it was a lot of 10 and obviously I don't need that many. When I get 'em, I'll see what it would cost to send you some...
    BUCK
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    That would be pretty awesome, very nice of you
    Thanks buddy
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 21 2010
    Charlotte-ish
    got the above mentioned resistors, they were too big to go in the individual housings, wouldn't fit with the heat sinks on the LEDs. Ended up soldering and wiring them in outside the housings. Good news is the bulb out error is finally gone.....
    BUCK
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Glad your bulb out error is gone, and only for $2!
    2008 A4 S-line 2.0T
    JHM Stage 2
    Senior Member Three Rings Mlambrecht17's Avatar
    Aug 11 2014
    Minnesota
    Mega bump but I need help, I have the 5W 50ohm resistors in my housings like pictured above, with 12v leds with heat sinks built in, I didn't put any heat shrink on them, and when I had them on for about 3 minutes, they got extremely hot, too hot to touch, I figured this would be bad and maybe a fire hazard, can anyone help me out here?
    Established Member Two Rings mattj150's Avatar
    May 08 2014
    Twin Cities - MN
    Quote Originally Posted by Mlambrecht17 View Post
    The resistors will get hot because they are taking the load that would of gone to the OEM bulb to cancel out the error. It's best to locate the resistors AWAY from anything that could melt or become a fire hazard. I used these ones as they dissipate the heat better since they have heat sinks. I also wrapped my resistors in heat shield for extra protection.
    2016 Audi S3 2.0T Premium Plus Glacier White
    2008 Audi A4 B7 2.0T Dolphin Gray - Tiptronic - SOLD
    Aug 11 2014
    Minnesota
    Quote Originally Posted by mattj150 View Post
    Could you post up a picture of what you have? And how hot do your resistors get?
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Is it just cluster with the colored DIS that throws bulb out errors ... I've yet to have a bulb out error :-/ and I run leds in my license plate ?
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Aug 11 2014
    Minnesota
    I'm not worried about the bulb out error, I'm just worried about it getting too hot
