Results 1 to 29 of 29
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Avant H&R spring question
    I know H&R has a specific kit for avants, 1.2" lowering all around (29061-2). However the sedan sport spring has 1.5" all around, in theory can you install the sedan sport spring (50361) on an avant to get it lower?
    Update, according to H&R the avant springs are longer and stiffer than sedan to make up for the weight difference.
    Sep 30 2009
    b
    Quote Originally Posted by d.p View Post
    yeah, I wouldn't recommend it. you'll probably get weird sag issues.
    Feb 13 2004
    Silicon Valley, CA
    It has been done, but as you noted from H&R, there is a difference to make up for the weight. If you put sedan springs on the Avant, you will probably drop almost 1/4 inch more.
    Kevin - Moderator, Audizine
    Senior Member Two Rings tgofsweden's Avatar
    Nov 03 2012
    ///M3
    GBG, SWE
    with H&R 29059-2 or 29059-4 will give you 1.5" all around for Avant
    Nov 08 2006
    F80 M3
    Annapolis MD
    Quote Originally Posted by tgofsweden View Post
    Are those avant specific springs? Available in the US?
    Veteran Member Four Rings audirings4's Avatar
    Nov 23 2011
    SQ7
    DFW
    Do yourself a favor and buy some coilovers.
    The H&R springs will give you reverse rake and kill the quality of your ride.
    Ask me how I know.
    Nov 03 2012
    ///M3
    GBG, SWE
    yepp, got those at h-r.com
    Nov 08 2006
    F80 M3
    Annapolis MD
    Quote Originally Posted by audirings4 View Post
    Ask me how I know,
    I have had coil overs on numerous past cars and in the end I am not sure I want that ride comfort, or lack thereof at this point in my life. I want no wheel gap and a comfortable ride, is there a such a thing? lol
    Nov 08 2006
    F80 M3
    Annapolis MD
    Yeah that is the german site, the US site doesn't even list those springs. They have one set for the avant.
    Nov 23 2011
    SQ7
    DFW
    Not sure what coilovers you've had in the past but that's your best option if you want a lowered/comfortable ride.
    Nov 08 2006
    F80 M3
    Annapolis MD
    JIC, TEIN and PSS9s. Also had tein lowering springs on an e46 m3 and they were money as far as looks and ride went.
    H&R street comfortable enough? Any firsthand experience with them?
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    i would go with H&R sports or even more of a compromise is H&R OE's
    the sports will give you a 1-2 finger gap while keeping your car's ride quality somewhat in tact. The OE's will be closest to the factory ride quality but a larger wheel gap.
    also look at Vogtland coilovers. I had them on my b7 s4 and the ride quality was better than the oem s4 suspension..
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Nov 08 2006
    F80 M3
    Annapolis MD
    Only option for the avant from H&R is the avant sport springs, I have sport package on my avant already so its lower than stock.
    Nov 03 2012
    ///M3
    GBG, SWE
    another option is Eibach Sportline
    Aug 11 2012
    Beaufort, SC
    @audirings4 how would springs compromise ride comfort if your just lowering your ride?
    If anything, it should be a slight improvement
    Nov 23 2011
    SQ7
    DFW
    Quote Originally Posted by usmcchery2010 View Post
    You do understand that the stock struts/shock are meant to work with the OEM springs.
    When you swap out aftermarket springs with shorter coils and a more aggressive spring rate
    your suspension will be stiff (not sporty). Very uncomfortable for a daily driver.
    Coilovers on the other hand are designed so the spring/shock combo work hand in hand.
    Veteran Member Three Rings CloseEncounters's Avatar
    Mar 04 2012
    2020 Navarro Blue SQ5, 2019 Black Q5 Prestige & Cannondale 27.5 'Beast of the East' MB.
    Tucson, AZ
    [QUOTE Update, according to H&R the avant springs are longer and stiffer than sedan to make up for the weight difference.[/QUOTE]
    True...I did some pretty intense research before going for the H&R Avant Sport springs and you really do not want to go any lower (especially on the Avant) if you're still using the OEM shocks... My drop was actually just around one inch after the car settled. If you really want to go lower I'd suggest to just go H&R coil-overs if your budget can handle it. You believe you would be quite happy with the drop and handling as I was.
    2020 B9 SQ5
    Nov 08 2006
    F80 M3
    Annapolis MD
    So you have coilovers or the avant springs? If springs can you post a pic ?
    Aug 11 2012
    Beaufort, SC
    When you put it like that.....
    I'm looking into lowering my car and was looking into H&R springs but seeing as it is my daily driver it sounds as if I should cough up the cash for coils
    Feb 15 2012
    Montreal/Quebec/Canada
    Did you look at the KW Street comfort? http://kw-suspension.com/us/kw_streetcomfort.php
    Maximum driving comfort for a perfect performance and more driving pleasure
    Guarantees more comfort, flexibility and sportive as regular OE sport suspensions
    Comfortable adjustment
    Better handling due to less body roll
    With TÜV tested adjustment range for a individual lowering of 10 to 40 mm
    Trapezoid thread for a easy height adjustability
    High quality damper components for a long durability
    Adjustable rebound damping
    Complete delivery content inclusive detailed documentation for a easy use
    2011 S4 Premium \\ Phantom Black \\ Lunar Silver leather \\ Carbon Trim \\ Sports Diff \\ Alufelgen SF71 19x9.5
    Nov 03 2012
    ///M3
    GBG, SWE
    H&R 29061, right after install
    Nov 23 2011
    SQ7
    DFW
    Quote Originally Posted by typer100 View Post
    You may want to read this thread about the sagging issues with V1 & V3's.
    http://www.audizine.com/forum/showth...-rears-sagging
    Nov 08 2006
    F80 M3
    Annapolis MD
    Looks good to me. Got a picture of the rear as well?
    Anybody have stock sport package avant fender to ground measurements and also avant sport springs fender to ground?
    Nov 03 2012
    ///M3
    GBG, SWE
    BBS 18x8.5 ET35 with 235/40R18
    Aug 11 2012
    Beaufort, SC
    How do you guys feel about the ST coils?
    Jun 02 2009
    San Francisco
    Here are some not so great pics of my Sport Pack Avant right after the H&R Avants were installed. Sorry I don't have measurements but it definitely lowered the wagon a bit more than .8" (or whatever 20MM less would be in inches) from Sport height.
    The ride height is dead level, but of course the higher front wheel arch gives the perception of rake, which it is truly not. Only CO's will fix that on our B8 Avants.
    Overall height and comfort were just fine for the price IMO.
    I am on 19"s now, click the link in my sig for pics.
    Nov 08 2006
    F80 M3
    Annapolis MD
    Ty man. Can you measure fender to ground for me ? I am really interested to know the exact difference between stock sport package and the sport springs.
    Jun 02 2009
    San Francisco
    I can ASAP, will measure next time i am parked on perfectly flat ground. Keep in mind I am on 19's now with 255s, rather than the stock Sport 18"s on 245s.
    Nov 08 2006
    F80 M3
    Annapolis MD
    Exactly what I am looking for, I am stock sport package with 19's and 255's so your measurements will give me the exact drop to expect from these springs.
