Results 1 to 12 of 12
    Veteran Member Three Rings Dr.d's Avatar
    Jun 20 2012
    2001 S4, 2024 Model 3
    Vancouver, WA
    What size cone filter to use with stock maf?
    I'm looking to order a cone filter to hook right up to my stock Bosch maf. I measured the O.D. of the maf and got about 3 3/8" or about 85.5mm but I can't find a filter with that size flange so far. I am considering getting 3 1/4" and just jamming it on there but thought I'd see what others may have done first. Any thoughts?
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    I would stick with the stock air box unless your running a BAT or something. You will not have HP gains or anything.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Jun 20 2012
    Vancouver, WA
    I'm aware of that. I did the same mod on my b6 and really enjoyed the increased sound. Since my car almost never sees rain im not worried about loosing the protection of the airbox from water. Thanks for the heads up.
    Active Member Four Rings
    Dec 11 2006
    Boston
    3.5" x 9" AEM Dryflow
    Stage 3+ RS6's
    Jun 20 2012
    Vancouver, WA
    ^^ thanks!
    Feb 08 2013
    Port of Spain/Trinidad
    Quote Originally Posted by Das General View Post
    Quick Ques on this.... the MAF dia is 3" yes?....wud the 3.5" x 9" AEM Dryflow be a direct fit?....
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    If you have a stock maf you don't need a filter.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Veteran Member Three Rings udcc11's Avatar
    Oct 17 2011
    west virginia
    Just darintake mod the airbox with a 3 inch cone filter and 30 degree bent 3 inch tubing.
    2000 Nogaro S4 Six-Speed Stage 3 Frankenturboed
    Totaled 2002 Santorin S4 Six-Speed Stage II+
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    Adding a filter will throw off your maf readings. Adding a cone filter increases the maf's efficiency.
    Dec 11 2006
    Boston
    Quote Originally Posted by Banzai_Rasta View Post
    An 89MM MAF is 3.5 inches. You are going to need a 3.5" coupler to attach your MAF to the intake.
    Stage 3+ RS6's
    Veteran Member Four Rings kbS42001's Avatar
    Mar 03 2009
    01S4
    Delaware
    3.5x9 AEM Dryflow like Das mentioned. heavy duty rubber plumbing reducer and hose clamps from Lowes, Darintake bottom half of airbox remains and helps support the filter. bonus is that the grill "ram intake" snorkel still remains and clips in.
    '01 Santorin S4
    "Welcome to owning an Audi...its a love/ f'n loathe relationship...but shhhhh...it might hear you and somthing else will break..."
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    hot air!=power.
