Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Established Member Two Rings geoffsta99's Avatar
    Mar 21 2008
    2001 S4
    Swapped 1.8T into B5 S4 chassis, need ABS advice
    I had a blown B5 S4, so I picked up a trashed, but complete B5 A4 cheap and swapped in a 1.8T. The car starts up fine, idles, drives, etc... (can't rev past 1600 rpm yet, need a TB alignment.)
    First things first, here is the VAG-COM scan:
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Thursday,03,January,2013,14:58:07:57757
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine Labels: 06B-906-018-AWM.clb
    Part No: 4B0 906 018 CH
    Component: 1.8L R4/5VT G 0002
    Coding: 16201
    Shop #: WSC 63351
    VCID: 69C76EA613987F5096B
    11 Faults Found:
    17522 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 35-10 - Internal Resistance too High - Intermittent
    16622 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 35-10 - Signal too High - Intermittent
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 - 35-10 - Implausible Signal - Intermittent
    17956 - Boost Pressure Regulation Valve (N75)
    P1548 - 35-10 - Open Circuit - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    18020 - Engine Control Module Incorrectly Coded
    P1612 - 35-00 -
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 35-10 - Signal too High - Intermittent
    17925 - Power Supply Relay for ECU (J271 or J363)
    P1517 - 35-00 - Electrical Malfunction
    18014 - Rough Road/Engine Torque Signal from ABS
    P1606 - 35-00 - Electrical Malfunction
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-10 - Signal too Low - Intermittent
    17879 - EVAP Leak Detection Pump
    P1471 - 35-00 - Short to Plus
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 E
    Component: ABS/ESP allrad D56
    Coding: 04395
    Shop #: WSC 06435
    VCID: 357FF2D60FA0EBB0C23
    3 Faults Found:
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-00 -
    00778 - Steering Angle Sensor (G85)
    37-10 - Faulty - Intermittent
    18265 - Load Signal
    P1857 - 35-10 - Error Message from ECU - Intermittent
    I need to take care of the ABS situation. The car currently has the complete braking system from the S4, with a 1.8T ecu from the A4. The brakes DO work, but I haven't been above 20mph yet.
    I'm seeing the blinking ESP/BRAKE lights in the cluster.
    My questions:
    1. Can I recode the currently installed B5 S4 ABS module to work with the 1.8T ECU? Or do I need to swap the electronic section of the module from the A4?
    2. Do the ABS valve section and the attached ABS control module have different part numbers? I can only see a P/N on the valve section on the module from each car, and they do not match...
    3. If I swapped just the electronic section of the ABS module from the A4, would I be able to retain ESP like I had with the S4?
    Thanks for the help.
    Sep 11 2009
    NE
    Your rights to post in B5 S4 section are revoked. Please use B5 A4 section.
    Thank you.
    Mar 21 2008
    2001 S4
    Quote Originally Posted by julex View Post
    Thank you.
    I'd love to hear this one...
    Congrats on being the first one to yell FAIL
    Feb 21 2011
    WA
    That isn't just fail, that's sacrilegious.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Quiter.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Three Rings Heavy Winter's Avatar
    Jan 27 2013
    Boulder, CO
    Any reasons why you just didn't find another S4 power plant instead of going to all this trouble to create a frankenmonster that only you - as its unfortunate creator - can love?
    Mar 21 2008
    2001 S4
    You both are about 2 years late for the hate party, either be useful or GTFO.
    Mar 21 2008
    2001 S4
    Quote Originally Posted by rtl5009 View Post
    Quiter.
    Are you calling me a quitter or asking me to be quiet? Either way I didn't find any useful information in your post.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    You hook the can wires up?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 27 2013
    Boulder, CO
    Actually, I'm not hating. I'm just curious.
    Perhaps you got the 1.8 for next to nothing and cost was the main factor?
    Given your skills, you probably understand that the resale of this car becomes quite a bit more complicated given what you're doing. But if you are keeping the car forever, then that doesn't matter, I suppose.
    I have the feeling that you may not get a lot of support in regards to the swap, as I doubt many here have embarked on this kind of project and your situation most likely has not been encountered before by most here. Or, even, by anyone other than yourself (I can't imagine that this kind of swap is very common).
    Regardless, good luck with it.
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by geoffsta99 View Post
    both. Its a hybrid word.
    c8 a6 allroad
    Mar 21 2008
    2001 S4
    Quote Originally Posted by Heavy Winter View Post
    That wasn't directed towards you.
    yeah the entire car was dirt cheap, plus after selling parts I didn't need, and whet i'll get for scrap, my swap was basically free. (aside from go-fast parts)
    Yeah i'm keeping the car "forever". No use in getting rid of a car that owes me nothing, plus i'm haviong a lot of fun with it and learning a shit-load. The car is clean, chassis components are solid. I've been booed for this swap since the day I started it, but who cares? It's my car.
    Veteran Member Three Rings joe@vwvortex's Avatar
    Feb 12 2004
    2008 Cayman S, 2014 Q7 TDI and 2000 Boxster S race car
    Cowtown
    Sure this car was an A4 at the start - BUT I wouldn't throw it out of bed.....I'm sure everyone would still be drooling over it if it was still the VR6 swap - but they decided that a 4 cylinder was better.
    It runs circles around my S4 - not just because it's faster - it is - but because it has far better weight distribution and handles so much better because of that.
    If my S4 engine looses the turbos again - I'll follow this guys path and build up a 400+ whp 4 cylinder........
    034motorsport Time Attack Car
    At least the OP has the balls to do something he wants - and doesn't deserve to catch all this shit because of it.
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    S4
    Jan 11 2007
    Salt Lake City, Utah
    In for the "you-can-no-longer-post-here-go-to-the-A4-section" party
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    ^yeah. Im usually not a huge douche on this site because so many people are, but gtfo of here man! Full of lose
    It would be fine if you planned on building the 4 cyl. or turning this into a dedicated track car but obviously this isnt the case lol
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Nov 16 2010
    WetSide, WA
    Id be making sure you are getting good power to those sensors.
    Not sure how you went about the swap, but would be fuse 34.
    Established Member Two Rings Widowmaker's Avatar
    Jan 10 2013
    Sydney, Australia
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Smh at some people...
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    What year was the donor? Which interior harness did you use?
    Established Member Two Rings rider384's Avatar
    Mar 30 2012
    Eau Claire, WI
    I don't know why everyone has their panties in a bunch, it's not like B5 S4s are rare or expensive cars.
    Any pictures?
    -Cullen
    '02 Black A6 2.7t 01e swap + Frankenturbo F21s. Stage 3- "The Pig"
    May 13 2011
    2015 BMW F30
    Do whatever you want to your car but be prepared to take some stoning.
    | Autospeed | JHM | Pure MS
    May 12 2009
    Detroit Metro Area
    I'm assuming the donor car is an 01 since its an 018 CH ECU which is ME7.5 and the engine code is an 06A AWM. These don't have ESP so I don't think you can retain that unless there's a way to recode it but I've never seen it done (might be possible). With that being said I'd swap over the ABS module (since you already have it from the donor and hopefully it's in good working condition and that should take care of that) and don't worry about ESP.
    If you want real help without the hassle post in the A4 section, there's tons of help there.
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    Quote Originally Posted by Turbo Nerd View Post
    01.5 a4's have ESP. I have it on my car.
    When he recodes his ecu he should be able to code it for ESP.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    May 12 2009
    Detroit Metro Area
    Well mine doesn't :) haha
    Edit: Your ECU is still a 018 CH correct?
    Veteran Member Three Rings Blake2423's Avatar
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    01.5 S4 AVANT Brilliant Black - SRM SMIC, SRM K24 HYBRID, SRM 102MM INTAKE, 1000cc INJECTORS, GET WATKINS E85 TUNE, JHM STAGE 4 CLUTCH, JHM SYNCHROS, SRM 3INCH DOWNPIPES, AWE MID MUFFLER EXHAUST, JHM SHIFTER, BREMBO GT KIT FRONT AND REAR, H&R RSS CLUBSPORT COILOVERS, 034 swaybar and links, AWE DRIVETRAIN STABILIZER, STERN ENGINE/TRANS MOUNTS AND REAR DIFF BUSHINGS, ECS REAR DIFF MOUNT
    May 12 2009
    Detroit Metro Area
    Dec 05 2007
    The amount of hate from some members in this section is incredible. I could have picked a B5 S4 up if I wanted (and still can), so I'm not exactly seeing how having a B5 S4 warrants the cockiness and arrogance.
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    I don't care what motor he throws into his car, but I don't see why he doesn't ask in the a4 forum since that is the engine he has. Yes there are knowledgeable members here that do tons of swaps but this is rare where it is more common in the a4 forum.
    Dec 05 2007
    Very valid point
    Sep 11 2009
    NE
    Quote Originally Posted by Street Nasty View Post
    And usually the other way around which is replacing four banger with something bigger. I don't see how receptive B5 A4 forum would be if the OP swapped Yugo or Trabant (google it) motor into a b5 a4...
    Jun 18 2010
    16 Jaguar XF S
    Fort Lauderdale Florida
    You probabally also need to swap over your cluster. As those are tapped into the ecu and if they don't communicate well car won't run properly. Search the b5 a4 forum for more info this forum doesn't ever attempt those kind of swaps...
    Sep 26 2006
    Ohio
    I have an empty bottle of Chemay blue, and im going to fill it with natty lite. What size funnel should i use?
    S4
    Senior Member Three Rings ReDLiTe's Avatar
    Mar 24 2009
    Pittsfield, NH
    Quote Originally Posted by Aggv View Post
    Weird. I was just filling my bottle of johnny walker blue with Jameson after reading this.
    When in doubt, when in fear, drop a gear & disappear!
    2000 S4 6mt Stock (dd)
    2000 S4 6mt Stage 3
    Senior Member Three Rings usmc.S4's Avatar
    Jun 20 2011
    Maybe because it's an S4 and he's seeing if any other S4 drivers have done this to their S4 in the S4 forums.....S4. Also, would you ask Jetta VR6 drivers how to swap their motor into our cars....lay the fuck off the guy, if you're aren't going to help then you should be the one to "gtfo".
    Mar 21 2008
    2001 S4
    Quote Originally Posted by sherbet View Post
    So you entered my thread to tell me to get out?
    Obviously what is not the case? I never disclosed my plans with the car. Go post a photo shoot or a LOL thread, I don't need you in here.
    Thanks, thats what i'm getting at. I'm not terribly worried about ESP, but the ABS code is preventing me from going any further.
    Mar 21 2008
    2001 S4
    Quote Originally Posted by Gumby View Post
    When he decodes his ecu he should be able to code it for ESP.
    I can't remember if the donor car has ESP...
    Yes sir
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    That made me laugh.
    Its more of a what do you have done to your car than mods. This way when I post about some problem with misfire or rough idle no one asks do you have bkr7e's because everyone knows if you post about a misfire it'll be a response somewhere in it.
    May 12 2009
    Detroit Metro Area
    Quote Originally Posted by speedlyte View Post
    No you don't.
    Feb 28 2011
    dirt scooters
    smh at the goon "build it our way or youre a tool" phags in this forum, take the cookie cutter bullshit to the mk4 forums. Apparently some b5 s4 owners have turned the corner from once seeing how far you could push the limits of a chassis and drivetrain to the land of douche and conformity. Purpose built vehicles have lost their way in a sea of "slammed" "stanced" and generally horrific shit builds. High five for using a little bit of creativity on a seemingly played out canvas
