Results 1 to 13 of 13
    Established Member Two Rings labmat's Avatar
    Jul 13 2011
    FS: '04 S4 Avant 6MT, '10 DSG A3 Sportback
    Minneapolis, MN
    Audi Telematics Backup Battery
    My Avant is equipped with the usless Audi Telematics module and recently the status indicator changed from the usual green to red. I did a VAG-COM scan and found the following fault code.
    Address 75: Telematics Labels: None
    Part No SW: 8E0 035 616 B HW: 8E0 035 616 B
    Component: Telematik USA1 1616
    Coding: 0005033
    Shop #: WSC 01013 444 59202
    VCID: 244D9181E4FBC838654
    1 Fault Found:
    01531 - Emergency Battery
    002 - Lower Limit Exceeded - MIL ON
    Does anyone know where this battery is located?
    Matt
    2010 Silver A3 Sportback 2.0t
    Jan 29 2007
    08 S4 00 S4
    MD
    It's located in the passenger side floor area. It's a little bit of work to get to if I recall and expensive to replace. You should be able to code it out, which is far easier if you don't use it.
    08 S4- Stock SOLD
    Jul 13 2011
    Minneapolis, MN
    Quote Originally Posted by mholme View Post
    I hadn't even thought of that, I'll look into this option and see what I can find out.
    Matt
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Audi telematics doesn't work anyways. It was disabled long ago.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Was that their version of OnStar?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    I believe the name refers to their phone integration system, in which Onstar can also function.
    Jul 13 2011
    Minneapolis, MN
    I'd love to physically remove the system...
    Matt
    Mar 08 2011
    Chicago IL
    So when I bought the vehicle the idiots who did the PPI told me the Telematics battery was a "backup in case your main battery fails"
    Jan 29 2007
    08 S4 00 S4
    MD
    That is what it does. Or did. They meant it supplied power to the telematics system should the main battery fail due to an accident, drain, etc.
    08 S4- Stock SOLD
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Correct, what it did do. This battery would allow you to contact OnStar after a crash, even if your battery failed or became disconnected. Since Onstar is no longer functional, this battery serves no more purpose. When I replaced my Onstar module on my 2004 with a OEM BT module, the light turned red and stayed that way.
    OP, if you want to eliminate the red light, I would get a non-onstar dome light cover. Or maybe even just unplug the LED up there.
    Mar 08 2011
    Chicago IL
    No, he really thought it was to start the car. When the code showed up for the low Telematics battery I asked what that battery did, and he started improvising on the concept that it would let you start your car if the main nattery ran out.
    Jan 29 2007
    08 S4 00 S4
    MD
    Well I hope that's the last time you visited that shop.
    08 S4- Stock SOLD
    Mar 08 2011
    Chicago IL
    yea, I'm still composing my Yelp review for those good ol' boys.
