...but it doesn't look like it's attached to anything at the bottom (i.e. it just "hangs" there). Should I at least put a couple small neoprene rubber pads between the stock RAD and the Mocal and zip-tie it back so they don't touch/rub/rattle against each other? And what is that looping tube thing? A/C? I just bent it out of the way like Mark did.
Also, I wasn't sure if those folks that track their cars are also running the OEM oil/coolant exchanger too... I live in south FL and the car is only street driven a few times a month, so warmup time isn't really a concern. Should I still keep it if possible? I still plan to run the Mann/Meyle oil filter and it looks like it will be really tight with both...
Lastly, my cooler came silver and I'd kind of like it black if possible... Does anyone think it would be a problem to spray a thin coating of black paint over just the front and sides? That shouldn't really affect heat transfer at all, right?
TIA!
