just picked this s4 about a month ago. everything has seemed fine. no creaks, leaks, or squeaks at all. driving tonight i shifted from first to second and i wasn't able to go into second. at first because of my stress and naivety i thought the clutch was broken. then i realized if it still moves then it obviously isnt in pieces especially since there is literally no smell at all even when it happened and there is no noise at all. So basically this is whats up. i can start it fine in neutral but i cant shift into gear once its started. i can also start it in first gear and get my car moving with no noises or smells at all. i can shift clutchless while driving and it also shifts with the engine off and the car in a stationary position. i looked near the slave cylinder and there is no fluid. i was not able to get my hand in there to feel the boot though because the pipes were still hot. my pedal feels a tad weak but still comes back because i heard that on the newer cars they are spring loaded(not too sure about that though). the line going from the pedal to the slave cylinder is dry and does not look streched out or expanded. ive come to two possible causes which is either a bad slave cylinder or the clutch fused to the flywheel. suggestions and/or comments?
edit: honesty. i just got the car and im 21 so i launched it like an *insert expletive*. then it wouldnt shift into second. i know im an idiot.
