Results 1 to 36 of 36
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Colorado Emissions Testing
    I need to pass emissions by the end of the month.
    Im not too concerned about the actual emissions part, I think that should be fine even though I have piggys, frankenturbos, and big injectors. Plenty of people pass with that or more.
    Im a little concerned about the visual inspection.
    They say they do a visual check on the SAI. I deleted mine. HTF do they even know where to look? Our engine bays are so cramped they couldnt possibly know every engine bay. Readiness should be "OK" since I have an S4 ECU file. Also, S4s have no SAI, but allroads do, possible negotiation point try to "say" I replaced the engine with a 2001/2002 S4 engine and it doesnt have it.
    Lights on the dashboard. I have traction control, abs, level control and CEL lights on. I guess you can pass with CEL and codes, they will just print out what you have for your own reference. But if you have too many dash lights they wont pass you. Air ride, traction control, and abs are all related. Its saying theres a short to ground/open circuit when i pull codes. None of these are related the the physical functionality or emissions of the car. I could say its just a popped fuse, short to ground. I think its just part of the ECU issues Im having. Or just come up with some BS excuse that the ABS module is dieing or its an air level sensor causing all the lights. Or pull the cluster, take it apart and electrical tape over the lights?! ahhah
    So, I was planning on going in tomorrow. Is it even worth it for me to try, or will I fail miserably? I dont really want to waste my money if Im guaranteed to fail.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    In NY they hook up a computer to the OBD port. Engine light=instant fail. More than 1 monitor not ready=instant fail. I don't know how CO works, but I would think they would at least hook up an OBD scanner.
    Why is your CEL on?
    Sep 18 2006
    Colorado
    MAF is not plugged in, ECU is coded for wrong MAF type(technically, it just says the voltage is too low). Also, misfires.
    Actually, wrong answer. CEL is on because 2.7T
    From the air care colorado site
    Effective April 1, 2003, an illuminated "check engine" light is no longer a mandatory pass/fail component of the emissions testing process. If the "check engine" light is illuminated, it is noted on the vehicle inspection report each motorist receives at the end of the emissions testing procedure. However, it is an informational tool for the motorist, rather than a reason for failure.
    Sep 18 2006
    Colorado
    I might bolt the SAI pump back on(but not actually plug it in or do anything with combi valves) tomorrow morning so it looks like I have it for the visual inspection.
    Emissions testing is stupid.
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    On my A4 they hooked up, rolled it for 30 seconds and it passed. On my LS1 swapped 944 they put me through the wringer and looked for and traced every single line
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Sep 18 2006
    Colorado
    Quote Originally Posted by Docwyte View Post
    They probably noticed it clearly was not a Porsche engine in the 944 which is why the scrutinized it. Hoping they are mellow on the allroad. Going in to try my luck at 9am
    Jul 19 2011
    Northern Minneapolis, MN
    Put you belly pan on for starters.
    They will want/need everything plugged in, so that means that you should hook up your MAF, then just cut the wires further down, an put conduit around it so nobody can tell.
    Any PCV, or vacuum hoses or anything that isnt hooked up, run them to a place where they cannot be seen.
    They might fail you for a cone filter. I passed with mine, but my buddy failed because of his (stupid). Also, if you just have a baby cone filter on your PCV instead of it going into the air box, fail. So rout it away)
    They are going to want to see your cat's, if you cant see them from the engine bay (stock), that's good. And then they like to use mirrors to look under it, but probably wont go as far as to get on their knees.
    Other than that, you have the tailpipe sniffer test on an AWD dyno (they might run your wheels into the side of it like they did mine and refuse to pay!), and then they test to see that your gas cap holds pressure.
    GOOD LUCK!
    Sep 18 2006
    Colorado
    Bullshit-city right here. Passed the emissions with flying colors, except failed for no sai.
    Oct 14 2012
    Upstate NY
    I can code you SAI out for you. It'll come up as UNSUPPORTED. I can also fix your MAF problem.
    Jul 19 2011
    Quote Originally Posted by ddillenger View Post
    ^looks like the best option to me.
    I assumed you had the MAF tuned out already.
    Sep 18 2006
    Colorado
    It's coded out, it failed visual inspection. I just bolted the pump back on and made the hoses look like they go somewhere. Time to try again.
    Jul 19 2011
    Quote Originally Posted by 4ringAR View Post
    but then why are you getting a check engine code about it?
    but buttoning everything up to pass visual should get you through.
    Sep 18 2006
    Colorado
    Oh I was talking abbot sai. Mad I just have the wrong coding right now. Working with jfonz to get everything squared away.
    Sep 18 2006
    Colorado
    Boom
    Jul 19 2011
    Boom
    good work!
    Sep 18 2006
    Colorado
    Now hopefully they will get rid of emissions testing in the next 2 years like they are taking about so I don't have to do this again.
    Jul 19 2011
    Who is talking about that?! I would be very happy. I had to pay some shady shop to pass my diesel truck ;-) And it will only be getting worse as I keep pushing for more and more HP!
    Sep 18 2006
    Colorado
    http://www.denverpost.com/opinion/ci...missions-tests
    The auditors say it would be a good idea. Auditors are always correct, right? ;)
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    As an auditor, I agree ;)
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Feb 02 2005
    Nothing in that article said they'd be getting rid of the emissions program. They've extended the exemption for new cars from 5 years to 7 years. That doesn't help any of us.
    '17 KTM 690 "Adv"
    Sep 18 2006
    Colorado
    Right here:
    The state audit argues, for example, that adopting an exemption for model-year 2001 and newer vehicles would be both cost-effective and still maintain the bulk of the benefit the program provides.
    Senior Member Three Rings Tyler S4's Avatar
    Aug 24 2011
    1998 Jeep Grand Cherokee 5.9 Limited
    Westminster, Colorado
    with your piggies are they only gutted pre cats or did you gut all the cats?
    2011 Ibis White S4 Prestige 6MT - APR Goodies | Roc Euro
    2001.5 Santorin S4 6MT - 034 | Darintake | EPL | ST | JHM | SSAC | VMR - Sold
    Sep 18 2006
    Colorado
    Precats only. Main cats are still there.
    Senior Member Three Rings ProfileX's Avatar
    Mar 12 2009
    S5 2011
    Denver, CO, USA
    I have a new car so I haven't had to mess with this in a long time. But now my daughter has a used car, can't you just drive by the mobile testers twice and then avoid all of this hassle?
    Jul 19 2011
    Wth, it would have helped me! lol 2008-2013=5years. Damn and I got it done last year, so I shouldnt have had to? It was out of state if that matters.
    Feb 02 2005
    They mention that they're thinking about it, that's a far cry from implementing it. If the car has already been registered and smogged, then yes, you can drive by the mobile vans and as long as you meet those standards, you won't have to bring your car in. When they mail you the registration renewal card it'll either say you need to come in or not.
    '17 KTM 690 "Adv"
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by ProfileX View Post
    ... can't you just drive by the mobile testers twice and then avoid all of this hassle?
    Exactly what I was thinking. To get plates, etc. for the car you need to have passed emissions & inspection at a station when bought/transferred in to the state. I plan on driving past multiple sniffer-vans when mine comes due next year.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Senior Member Two Rings Devin's Avatar
    Mar 06 2012
    Denver, Colorado
    How could one go about registering their car in a county that doesn't do testing?? I guess I would have to know someone with an address in that county??
    Veteran Member Four Rings Club Cheetah's Avatar
    Oct 28 2009
    03 allroad
    CO
    Try getting a P.O. Box in one of those counties I think. I'm holding off for some sort of miracle to end this bullshit Envirocare. I would be willing to bet if that takes place all of a sudden exhaust shops are going to be busy as hell making DP's for all of us.
    Mar 06 2012
    Denver, Colorado
    That's a fantastic idea. Thanks man!
    Feb 02 2005
    Except your insurance company won't be happy to find out the car isn't garaged where it's registered not to mention what the state will think of it when they find out
    '17 KTM 690 "Adv"
    Mar 06 2012
    Denver, Colorado
    Yeah I looked into it. Also, it cost just as much as doing the stupid test. I think I should pass just fine.I'm going tomorrow afternoon. I do have a cone filter, but other than that its all stock. I have a check engine light as well, but I don't think it's anything to do with the emissions side of it. Lastly, no credit cards??? And it's $40?
    Sep 18 2006
    Colorado
    Its $25 cash or check.
    You should be fine passing though. I have a cone filter they didnt say a damn thing about it. If your engine is more or less stock you should pass with flying colors. I passed the emissions with the above numbers(well below the limits), my car has piggy pipes, no SAI, frankenturbos, 550cc injectors, stg3 tune, and hybrid blow off valves. Still has the main cats, but as you can see i didnt have any issues with the actual emissions part. just make sure the car is nice and totally warmed up before taking it in.
    Mar 06 2012
    Denver, Colorado
    Awesome! I'm about to do piggy pipes after this crap so, thanks for the info man!
    Edit: I'd love to check out your AR sometime. I just picked up one as well and I'm absolutely in love with it.
    Feb 02 2005
    They don't care about cone filters and the like, there isn't a visual inspection beyond making sure your car has the emissions stuff it should have (O2 sensors, cats, SAI, etc).
    Piggy pipes will easily pass all the emissions, you don't need the pre cats...
    '17 KTM 690 "Adv"
    Sep 18 2006
    Colorado
    Quote Originally Posted by Devin View Post
    Awesome! Welcome to your newest addiction!
    Its certainly not a sports car, but with a few upgrades its certainly fun and a GREAT daily driver.
