Results 1 to 10 of 10
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Coil Pack Wiring Harness. How to replace?
    So I've searhed but didn't really find a clear answer. Turns out my Coil Pack wires are cracked and frayed, and now is what I believe is the cause of occasional misifre. I;m guessing this is the part to replace it with; http://www.ecstuning.com/Search/Atw_Harness/ES7679/. Now, is there a good DIY on how to install this? I've read some post but wasn't sure if this part requires, cutting or splicing the wires. Also not sure if special tools are needed to get the connectors on the right way. I'm one that doesn't really feel confident when it comes to messing with the wiring, but I believe this looks like a easy plug and play job but I could be wrong, so let me know if there is something more involved than just simple unplug old, plug in new..TIA
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    034 coil pack harness repair.
    Did it last week. No more random misfires. Awesome.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Nov 18 2012
    2003 Audi A4 1.8T quattro (slow), 2007 VW GTI (not as slow), and 2008 Honda CBR1000RR (fast)
    MD
    Did you look at the application guide for the part you linked? Because it's not for our cars. I'm sure you probably could use it, but the pinouts may be different.
    Make Model Submodel Engine
    Audi TT MKI All 180HP
    Volkswagen 337/20AE All All
    Volkswagen Golf IV All 1.8T
    Volkswagen Jetta IV All 1.8T
    Volkswagen Jetta IV GLI All All
    From my research, many people are using the 034 harness as cjonesgo did. Not plug-and-play, but does look to be a fairly easy installation.
    Established Member Two Rings MTS's Avatar
    Jan 04 2012
    Barefoot Nautique, k5 Blazer
    Austin TX
    The ecs harness will take a lot of modifying to make it work. The 034 harness is a good product, but you will need to buy a wedge crimper. Or...the stealership will sell you a 'pig tail' that can be spliced in for each corroded wire. I used and recommend the 034 harness.
    Dec 05 2007
    I just replaced my entire engine harness with a used one when I shorted that section out. Cheapest way to go about it.
    Sep 08 2010
    Asheville, NC
    034 here it was super easy
    Jun 30 2008
    Erie, Pennsylvania
    The Jetta harness works great. I've used it multiple times on A4's. At the moment, it is the cheapest option for a brand new coil harness (there used to be an entire Jetta 2.5 harness for like $15, which was awesome but now NLA).
    Anyway, the only difference is the wire colors. Just match it up pin-for-pin, trim off the extra wires for the speed sensor and such, and you're golden. I recommend using marine-grade heat shrink crimps.
    Dec 22 2008
    2003 A4 1.8T
    Phoenix
    I used the the harness from ECS and it worked fine. It does need to be modified, but its not too bad. Just take your time and be careful. When I did I mine I had it all hooked up and the car wouldn't start, turned out I blew a fuse. So watch for that while your working.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Sundevil84 View Post
    Guessing you didn't unhook the battery did ya? As a precaution always unhook the battery when you are messing with the wiring or electrical sources.
    Jason
    Dec 22 2008
    2003 A4 1.8T
    Phoenix
    ^You are correct. I learned my lesson.
