Results 1 to 11 of 11
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Auxiliary Water Pump Delete
    My secondary water pump is leaking really bad and I am thinking about deleting the pump by using the Silicon Horse from 034. How many of you have deleted this pump? Any issues I should be concerned about?
    I am planing on deleting the pump and install the Phenolic spacer since I have to remove the intake.
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Feb 17 2004
    Sterling, VA
    Vimal, don't delete it. That pump does a lot of work to protect your turbos from boiling the oil after you shut the key off. Just spend the $120-150 and replace it with the relocation kit.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    You can delete it. As long as you let the car cool before shutting it down the pump never runs anyway.
    Veteran Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    what Daft said
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Feb 07 2008
    The boonies, near Seattle
    Unless you replace the temp sensor associated with the after run pump, it's worthless to replace the pump.
    I relocated mine, but wish I would have just deleted it since I already have a turbo timer.
    -dre
    Jan 23 2007
    thanks guys.
    Brett-
    Where can I get the relocation kit from? I think this is the part # #078 998 998
    APR Stage 2
    Sep 27 2011
    Vancouver, BC
    Dre, what's the turbo timer? I've got a leaking sec H2O pump as well and just figuring out my options.
    Jan 23 2007
    Dre - Which turbo timer did you get? Any Pics?
    APR Stage 2
    Feb 07 2008
    My turbo timer is built in to my alarm/ remote start system. It is a viper unit.
    -dre
    Feb 17 2004
    Sterling, VA
    Vimal, I checked all the usual places to get the kit and the lowest price I've seen was $187. It used to be about $150 so I guess it has gone up a little over the past 4 years.
    Brett - Moderator
    Issue?: email me.
    Established Member Two Rings NWAUDIB5's Avatar
    Oct 07 2012
    San Diego
    i have the delete, no problems and i drive out of turbo and let it cool for 2 mins at least before shutting down, I will be getting a turbo timer to get rid of that problem. If you know how to treat your car then the delete wont be a problem
    2001.5 Silver S4----J-Fonz Stage 2!
