Originally Posted by
EvolutionArmory
Why would you order anything without reading the codes or doing any sort of diagnostic work?
I work too much and have no time. Worst case I have a spare part.
However, when I crank starter it does not even sound like engine is turning over. I see acc belt spin so I know it is. But there is no indication cylinders are making compression. I did timing belt when I bought it at 80k. @ 129k. Wonder if it let go and why sounds like that. Going to do comp test now. Thinking its fuked...
Here is a scan log I just took. Im not sure what caused CEL.
Sunday,09,June,2019,20:33:27:52553
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.4 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUDF78E86A223136 License Plate: A
Mileage: 208630km-129636mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUDF78E86A223136 Mileage: 208630km-129636miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H13--- Serial number:
Coding: 0104010A190F0120
Shop #: WSC 08316 444 91219
VCID: 2B000D294F09E4CF4F5-807E
4 Faults Found:
012417 - Engine Temperature too Low
P3081 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 26
Reset counter: 255
Mileage: 207034 km
Time Indication: 0
Freeze Frame:
RPM: 3000 /min
Load: 96.8 %
Speed: 104.0 km/h
Temperature: -40.0°C
Temperature: 41.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 208150 km
Time Indication: 0
Freeze Frame:
RPM: 1146 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 51.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 208638 km
Time Indication: 0
Freeze Frame:
RPM: 2822 /min
Load: 48.2 %
Speed: 131.0 km/h
Temperature: 92.0°C
Temperature: 20.0°C
Voltage: 13.970 V
000802 - Engine Speed Sensor (G28)
P0322 - 008 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 208638 km
Time Indication: 0
Freeze Frame:
RPM: 2421 /min
Load: 29.0 %
Speed: 120.0 km/h
Temperature: 92.0°C
Temperature: 36.0°C
Voltage: 13.970 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 C HW: 09L 927 156 B
Component: AG6 09L 2.0TFSI USA 0040
Revision: --H01--- Serial number: 4149060
Coding: 0000002
Shop #: WSC 06335 000 00000
VCID: 2708F11953E1C0AFABD-8072
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H06 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004528
VCID: 290CF72145F5F6DFBD9-807C
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6D84C331B48D2AFF111-513C
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0704
Coding: 01003
Shop #: WSC 65536
VCID: 3B203D69BA79744FDF5-4B00
3 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
30-00 - Open or Short to Plus
01498 - Bulb for Parking Lamps; Right (M3)
01331 - Door Control Module; Driver Side (J386)
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001KE2Q
Coding: 0032607
VCID: 3C223E75BA677377D6F-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 36HZB
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB402DC4F994ÿ†63
Subsystem 5 - Serial number: C4F994ÿ†6342DRB402F4132CNÿ†63
Subsystem 6 - Serial number: 4132CNÿ†6352ARB4010641723ÿ†63
Subsystem 7 - Serial number: 641723ÿ†6362ARB4010A24639ÿ†63
Subsystem 8 - Serial number: A24639ÿ†63729RB40101BB47Iÿ†63
Subsystem 9 - Serial number: 1BB47Iÿ†63829RB40101CC36Jÿ
Subsystem 10 - Serial number: 1CC36Jÿ
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 50
Reset counter: 39
Time Indication: 0
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 7
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02021
Shop #: WSC 06335
VCID: 41DC4F81D8951E9F859-4B00
6 Faults Found:
00576 - Terminal 15
57-10 - Electric Circuit Failure - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 08316 512 00000
VCID: 2E06043D7C0B91E768B-5184
2 Faults Found:
01176 - Key
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
2 Faults Found:
01176 - Key
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11820
Shop #: WSC 06335
VCID: 78AAE265CBCF9F57F27-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0506
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
5 Faults Found:
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
80-10 - Single-Wire Operation - Intermittent
End----(Elapsed Time: 06:10, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
