Results 1 to 14 of 14
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Car sat awhile...battery DIED. How to safely recharge battery in A4?
    Our B7 needs front brakes---the rotors are on order--in the meantime the car sat for a couple of weeks. Now its dead. It cranked over and started barely about a week ago......now dead. It looks like the original battery (its an '08) --so its prolly on its way out. Anyway I am wondering whats the safest way to recharge this thing?
    Can I just hook up the charger cables ---red + , Blk - to the battery while in the car with the battery hooked up to its cables ---then plug in the recharger? OR Plug in recharger, connect + and then neg?
    Or do I need to unplug battery completely from car then recharge it?
    I just dont want to fry anything. On all the other cars I have charged I just hooked them up---then plugged the charger in.
    On another note...will a battery from a B6 Audi A4 fit perfectly in place?
    Thanks in advance.
    Sep 03 2009
    San Antonio, TX
    You can jump it. Owner's manual says to connect black to black and red to red on both batteries.
    Or you can take it out and take it an Autozone or something. They can recharge it and test it to see if it's bad.
    More than likely though, you should be able to jump it and it will be fine. Sometimes batteries die out if left for awhile. Even though the car is off, there's still accessories that run off the battery. Not much but it could drain it after awhile. Cold weather doesn't help either.
    Oh and a B6 battery is the same one in a B7. I think the only real differences between a B6 and a B7 are cosmetic and engine wise. The B7 is still considered an 8E platform.
    MY BUILD
    Senior Member Two Rings jamezz23's Avatar
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Jump it or take it out of your car and hook it up to a car battery charger?
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    Jump it and go on at least a 45 minute drive. Most likely it was your alarm that finally killed the battery.
    Dec 14 2011
    Chagrin Falls, Ohio
    If you have any kind of half decent charger just connect to battery and charge away while still connected. It's better for the alternator and battery (when deeply discharged) to fully charge with a battery charger.
    Senior Member Three Rings turbowop's Avatar
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    I keep a Battery Tender on my Mitsu while it sits parked in the garage all winter with a redtop Optima. They're pretty cheap and good to have around. I would pick one up at Sears and throw it on your car. Like already said, it's better for the battery and alternator to use a charger if you have the time to wait.
    http://batterytender.com/
    -Mark
    '91 Mitsu GVR4 #1051 / 425awhp / 11.90@121mph / tuning and wrenching by me / full weight @ 3280lbs
    '08 Audi A4 2.0t 6mt Quattro / Ibis white / convenience & premium package / APR 2+ flash / APR exhaust / APR HPFP / 034 test pipe / CTS FMIC / Stasis street sport coilovers / RS4 rear swaybar / Thor undertray / Podi boost gauge / BFI snub /
    Thule ski rack / tint / paint matched reflectors / 19" Hartmann R8's on Conti DW summers / 17" stock split-5's on Dunlop Graspic winters
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    connect cables, start engine.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Surprised...no flaming?
    Established Member Two Rings jayulzvern's Avatar
    Dec 29 2012
    United States
    ^ me too
    '08 6MT 3.2 Ibis on Ebony
    20% tint, painted the orange reflectors, hardwired V1 and a passion for Quattro
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Quote Originally Posted by Silveravant View Post
    I second this. Most of the advice thus far has not been to answer your question. If you have a battery charger, why would the best thing be to jump it and drive around needlessly while your brakes are bad just to charge the battery? Stupid advice. Go ahead and charge the battery with the charger, I've charged mine several times while on the car with no ill-effects.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Dec 14 2011
    Chagrin Falls, Ohio
    I have a CTEK 56-864 charger that I highly recommend. Less than $60. Charges automatically and safely at 6 amps then goes into maintenance mode. Can be left connected indefinitely.
    Jun 15 2011
    Exiled.......
    thx fellas... charging it in the AM----starting the brake job later that day.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I'd get the battery replaced.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Dec 14 2011
    Chagrin Falls, Ohio
    I would think the best thing to do before spending the money for a new battery would be to try charging and or testing the old battery. With the CTEK charger i I was able to revive the battery from my lawn tractor that was completely dead and would not take any charge. On the other hand a battery from '08 may very well be shot but without testing who knows?
