As usual,
old guy is right.
For future reference, here is a thread that includes the Bentley manual torque specs:
AZ thread
I was following an extremely helpful DIY in another forum, which unfortunately included the following torque information:
Lower connection to the sway bar - 100 Nm
Maybe I misinterpreted...
Now, I will wrap up this whole saga by saying, I was able to get the threaded part of the bolt out by removing the sway bar link completely, which allowed me to get a grip on the broken end, and remove it manually. No fancy tools required.
I discovered, however, that the bolts that were in place there (the original ones that came on my A4 when I purchased it 2 years ago) were definitely
not OEM. Check out the picture (on the left are OEM, on the right my broken one and its mate):
They were crappy relatively lightweight substitutes, I only realized after I ran to the dealership and picked up the OEM replacements, which are substantially more rugged and clearly hardened steel. So, in the end I was able to get everything torqued back down as close as possible to spec, and the car is on the ground, running. Feels pretty good, both the quality of the ride and the sense of accomplishment to have done upper and lower control arms myself. Next up: Motor mounts.
Final question: I did not replace the tie rod ends (they looked to be in pretty good shape, and the ones in my kit (EuroSpec) appeared significantly lower quality). Do I still need to do a 4-wheel alignment?
