Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Feb 25 2011
    Seacoast NH
    DIY: Error-Free Rear License Plate LED Lights the Easy Way for B7 A4
    Parts and Tools needed:
    - 2 new LED bulbs. I purchased mine as part of a complete LED light kit from Krauto Parts c/o Emil: http://www.krautoparts.com/ Great service all around. 36 mm festoon LEDs are what you need: http://www.krautoled.com/products/36...led-bulbs-pair
    - 2 Ohmite brand wire-wound resistors (50 Ohm, 5 Watt). I purchased mine on eBay from seller "r_francis82". The resistors cost me about $6.00 shipped.
    - Tiny phillips screwdriver (glasses repair kit size).
    - Thin flathead/regular screwdriver; or thin file.
    - A normal size screwdriver (any size).
    - Pliers (any size).
    - Microfiber towel or cloth.
    Difficulty:
    - 1 of 10. This install took me MAYBE 15-20 minutes.
    - This was one of the easiest mods that I have done to date - mostly thanks to the idea and info from Audizine member, Schweini - thanks again!
    - See where this idea started from if interested: http://www.audizine.com/forum/showth...-today/page236
    How-to guide with pics:
    - Remove your license plate with screwdriver to create more room and easier access to the plate light housings.
    This is what it looks like the light housing is still installed:
    - Take your tiny screwdriver, and remove the one screw from the light housing. The light housing probably will stay put (and not fall out), especially if it has never been removed in its lifetime. Mine took a look coercing from a very thin flat screwdriver. A very thin file would also work if needed.
    This is what it looks like when removed:
    This is what the OEM bulb looks like:
    - Remove the OEM bulb gently. Do not break any of the metal pieces in the housing.
    Light housing with OEM bulb removed:
    - Use microfiber towel or cloth to clean the light housing at this point (inside and out). Might as well.
    - Get your LED lights ready to install.
    LED lights:
    - Install LED light into housing. It will fit in the metal clip in the exact same way as the OEM bulb.
    LED light installed in light housing:
    - Feel free to angle the LED light however you feel. I angled mine about 40 degrees pointed towards the car. I was trying to achieve the look of having the LED light mostly on the license plate, and not on the bumper or ground behind my car.
    - Take the resistor and get ready to wrap the metal wire contacts around the light housing prongs. The wire is a little too difficult to manipulate with just your fingers. I figured out the length that I needed, and put a normal-sized screwdriver against the metal wire contacts, and wrapped the metal wire contacts around it, creating a circle. I then took the pliers and crimped the metal wire contact circle into almost an oval shape. I then slipped these oval shapes over the lighting housing prongs. If needed, gently use pliers and make sure the contacts are touching the resistor metal wire contacts nicely.
    Pics of this process:
    - Add heat shrink around the resistor if you want. This just makes sure that the small amount of heat from the resistor does not damage the LED lights or the plastic light housing.
    Pics of heat shrink:
    - Install your new LED housing with resistor back into the trunk lid. I installed each side without putting the screw in at first, just in case. Started the car, and turned on headlights. Made sure the LED light angle was how I wanted it. Kept the car running (again just in case). Put the screw back in. Confirm you are not getting any bulb-out warnings. Repeat for the other side.
    OEM (left) versus LED (right):
    Both LED plate lights installed:
    The benefit of doing it this way versus the other method is that you do not need to remove the trunk clip or find a spot to mount the resistors like in that method. I have been assured that these resistors do not get hot, therefore the housings and lights should not be in danger.
    Grab the LED lights and resistors, and do this on your lunch break or after work some day. It was really simple, and I am happy so far. Note that I installed these during the day, so I do not yet have pics of the plate lights at night yet. I will update this DIY thread soon with night pics. Hopefully I angled them properly the way I wanted. The good news is that if they need adjusting, it will only take me approx. 5-10 minutes to do so now.
    Good luck, and ask any questions that you have here in this thread. I will be sure to answer any questions that I can, and I'm sure Schweini will be happy to help out as well!
    Edit:
    I have a RED DISPLAY.
    Feb 25 2011
    Seacoast NH
    Night pics added:
    Night video added: be sure to watch in full HD 1080p!
    I feel that the first photo shows the true color and brightness of the plate lights the best. They definitely are NOT as bright as they seem in either the photos or the video. I guess it is difficult to capture the true brightness and light quality at night. Looks good though to me.
    Senior Member Three Rings blownb6's Avatar
    Apr 08 2012
    Ontario
    Thanks for write up , my bulbs just died wanted to do this mod but did not want the error ,
    Senior Member Four Rings A410's Avatar
    Feb 29 2012
    2004 Pontiac GTO
    Baltimore, MD
    Very nice!!! Will have to get on this soon! What was the approx total cost??? Maybe add that to the description, just as a quick reference too
    Again, nice job! I like it.
    2008 A4 2.0T Quattro / 3M Matte Orange Vinyl Wrap / APR Stage II+/ APR HPFP / RAI TP / RAI Catch Can / Custom RAI Exhaust / TR-11 FMIC / 034 Motorsports TIH / K&N / AudiUp Race Snub / 640 Mod / Various VAG Mods / New South Boost Gauge / R8 Coilpacks / NGK BKR7E / 200+ Lbs Weight Reduction / 19" RS3s / RS4 Rear Sway Bar / Coilovers / Cupra Lip / LED Taillights / 20% Tint /
    Senior Member Three Rings dbens's Avatar
    Jun 07 2011
    Montreal
    damn i just spent like 2 hours a month ago wiring in resistors per Phil's DIY. o well ! Nice writeup though, you think something similar would work for the DRL LED's?
    2007 B7 A4 QG TI S-Line / Debadged / 35% front & 20% back tint/Evomsit stage 1 flash/ Neuspeed Springs / Emilgevor interior led kit / Hoen Xenon matched fog lights
    Oct 16 2008
    South Florida - Ft Lauderdale
    Sir, your resistor is going to melt the crap of everything around it
    5W is way to small for the difference of draw. For info, a 25W gets hot so imagine a 5W
    Phil
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by A410 View Post
    Good idea-
    I just edited my original post:
    "I am in the process of confirming the exact mm size of the festoon bulb from Emil, and will post back soon. I will also post a direct link to the bulb once confirmed."
    "I purchased mine on eBay from seller "r_francis82". The resistors cost me about $6.00 shipped."
    Quote Originally Posted by dbens View Post
    I don't believe these will work on the DRL bulbs. I don't know the technical reason for this, but I think it requires more volts/watts/something. Someone else will be able to say, but proper resistors are needed for DRL's. Let me know if you have questions about them, since I have done LED DRL's.
    Feb 25 2011
    Seacoast NH
    Phil
    Hi Phil,
    I certainly hope not. Schweini has been testing these for some time now. I will wait for his reply, because I don't know the technical electrical info to reply to your post.
    Oct 16 2008
    Quote Originally Posted by wildcat333 View Post
    Hi Phil,
    Since the access it pretty easy do this test :
    Pull your assembly off and connect one side to the positive side of your battery and the other side to the negative side, using 2 wires.
    After 30 secs, touch carefully the resistor
    Phil
    Jan 13 2008
    2008 A4 2.0t Avant 6spd
    Boston MA
    I'm with Phil, you really need at least an 8ohm 20w resistor when ever replacing an incandescent bulb with an LED.
    2008 A4 2.0T Avant 6spd. Black on Black Ti S-Line
    Established Member Two Rings gelgel's Avatar
    Feb 22 2008
    Vancouver
    Thanks for the write-up. Do you have color display?
    I tried sth similar few months ago..
    http://www.audizine.com/forum/showth...plate-resistor
    the resistor that I am using is http://www.ebay.com/itm/230719186583...84.m1497.l2649
    and I had one resistor for each bulb. But I am still getting the bulb out error..
    any insight?
    06 A4 3.2L Brilliant Black MT6
    JHM extra short throw shifter | RS4 ebrake handle | RNS-E | LED interior kit | 6000K HID fogs kit | smoked side blinkers | smoked bumper sidemarker | S-line blackout grille | RS4 Swaybar | ST Coilover | Evoms Intake | AWE catback | 19" BBS RGR
    Soon to be on: Cupra lip
    Feb 25 2011
    Seacoast NH
    I have RED DISPLAY.
    Sent from my iPhone via Tapatalk.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    The circuit for the license plate resistors draw roughly 4w, these resistors are good for 5w, you're not going to melt anything at all. 4w is not nearly enough to be melting the plastic, and if anyone is worried with this mod, then go buy some heatshrink for $2 from a hardware store and apply it around the resistor
    This setup Wildcat has DIY'd has been my setup for nearly a year and I don't even have any heatshrink on my resistors. Everything is fine
    2008 A4 S-line 2.0T
    JHM Stage 2
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by gelgel View Post
    any insight?
    You're using the wrong resistors my friend. 100 ohms is way too high. Get a 35-50ohm resistor. The circuit asks for a specific ampere, with that 100 ohm in there you're bringing the amps WAY too low.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Established Member Two Rings KOT's Avatar
    Oct 26 2012
    2008 AUDI A4 S-LINE
    Kent, WA
    really nice description and pics. will do to my audi same thing. thanks
    Feb 22 2008
    Vancouver
    Quote Originally Posted by Schweini View Post
    thanks for the pointer! Will give this a second try. I'll get the resistors that Wildcat is using. Hopefully this will work on color display too.
    May 21 2007
    Florida
    nice writeup mike! lights look good! if i didnt just buy the ECS LED plate lights i would be doing this. picked them up for $45 shipped - the best price ive seen them at. plug and play, no error on red display.....baaa-zing! but both options are good ones! my LED bulbs burnt our fairly quickly though.
    2018 Navarro Blue Q5
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Great DIY. Some more specifics on the exact resistors (link to ebay item maybe) and specs on the bulb (looks like you're working on that) would be great. Looks like the bulbs are the CANBUS type sold on that website, just by looking at the heat sinks, but could be wrong. There are so many variations out there, that that would be very helpful.
    Nice job! Thanks
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    Seems your LED's also have resistors in them?
    Atleast in my experience, LED's wont have a heatsink on them if they do not already have some sort of resistor built in, since there would be no need to heatsink LED's otherwise.
    I tried with 5W resistors when I did this long ago, and mine also got to hot to even hold for a second and perhaps it wouldnt melt plastic but I wasnt comfortable having something that hot inside my trunklid with practicly no ventilation on a varm summersday. Also, I did wire mine further inside the trunklid so there were more wires etc that were in the riskzone of the heat, so swapped them for 50W which barely gets warm at all.
    Otherwise, nice DIY and people should definitly go for this "right" way to do it!
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
    Senior Member Three Rings jonnybravo's Avatar
    Nov 23 2009
    San Jose
    What was the resistance of the 50w resistors you used. And is it necessary to get wirewound resistors?
    Quote Originally Posted by Khaotic View Post
    Oct 16 2008
    Quote Originally Posted by jonnybravo View Post
    It all depends of the LED that you are installing. Yes, wirewound is necessary and the critical advantage, they can be attached to the chassis who will act act heat sink
    Phil
    Feb 25 2011
    Seacoast NH
    Thanks to those that liked this DIY.
    I will post up night pics tonight.
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    Their kit shouldn't error on non color display without modification per THIS THREAD even after 1+ years. Did you confirm this before doing all this?
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    If anything I would at least solder the resister to the clips and not just wrap them. Otherwise could be a good idea.
    -Chadwick
    FULLY BUILT ENGINE!
    Senior Member Two Rings GDC's Avatar
    Nov 18 2010
    Calgary
    after trying several and i mean several different error free bulbs, with negative results. i went with these and never looked back
    http://www.ebay.com/itm/AUDI-ULTRA-B...04365c&vxp=mtr
    no problems
    b7 audi 2.ot black/black
    go. Stage 2 APR 93, Rev D, Custom CAI, TR18 FMIC with Doublezero30 Piping, 034 hfc, Stasis catback
    show. stasis ss coil (24ftg), 18x9.5 Kup, Cupra Lip, tint, S4 mirror caps
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by B7Joe View Post
    Nice job! Thanks
    These are what I suggested him to get: http://cgi.ebay.com/ws/eBayISAPI.dll...m=261159650482
    If you want to know the details about the resistors, it's this: When you replace the OEM bulbs which which have a resistance of 37 Ohms, with LED's, what you're essentially doing is eliminating that 37 Ohm's of resistance. This is because LED's have next to no resistance properties to them. You NEVER consider them a load. Now, because that OEM bulb is not in the equation and LED's have no resistance, you have a straight 12v shooting through the LED's and the ampere rating is almost non-existent. The cars Canbus system reads this, and displays this fault as an error out light display. So what we now have to do, is find a resistor that can match the value of the OEM Bulb to take it's place. a 37 Ohm bulb and a 12v power source gives you an ampere rating of .32 Amps. This is what your car wants to see. So now we need to find a resistor that will produce the same ampere rating when shooting 12v through it. I used the 50 Ohm resistor, so this with 12v will produce an ampere rating of .24 amps.
    You're probably saying, well that doesn't match the cars OEM bulb at all??? Well, the LED's have a very minute resistive property, so tacking on a .006 milli-Amp or so will raise the .24A VERY close to the .32A the car wants. This is also why this DIY should be labelled that this will work using THESE specific LED's and THIS specific resistor. Different LED's will have different resistive properties and can but probably wont alter your values. This DIY I came up with was what i found worked best for my application. This will not work for every Audi model
    Now when it comes to the Wattage, the 5w as we see on the resistor, that is simply stating how much power that resistor can dissipate. The OEM circuit draws 12V x .32A = 3.84 wattage. This resistor can withstand up to 5w, so in this application, you're good to go.
    In a nut shell, the Wattage should never be smaller than the OEM Wattage (3.84w) and anything bigger than that number is good. The larger the better, which is why Phil used much larger resistors. The only reason I used the small ones was because they are much cheaper, and the install takes 5 minutes. The larger the wattage rating, the larger the resistor is going to be! That's why Phils resistor is huge.
    Quote Originally Posted by FraggyA4 View Post
    Completely unnecessary, and I highly suggest all of you don't do this. Because the resistors have a small power rating, they will in time eventually ware out and you more than likely will need to replace them. This can be years from now, who knows. If you solder them in there, you'll be sorry. Wrapping them a few times and crimping with some pliers makes adequate enough contact.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by GDC View Post
    no problems
    I've also tried several too, and I found they ALL eventually break. The third party vendors have no idea what kind of resistor you need in our cars circuitry. Unless they solely designate their LED error frees for the A4 B7, they are just ball parking it. The resistors they throw in may just be cutting it, and once you get some voltage fluctuating due from a dying battery or decaying resistor, you're Error Display will be popping up
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 15 2010
    London, Ontario
    Phil
    Two questions:
    1) Assuming the resistances are the same why would a 5W resistor get any hotter than a 25W resister? The power being dissipated will be exactly the same.
    2) A light bulb is effectively a wire-wound resistive heat source that happens to emit some light. Assuming the light output is the same and the resistance of the resistor is the same as the original bulb the total heat emitted should be the same as the bulb. Why would this damage anything that bulb doesn't damage already?
    I'm a mechanical engineer with only limited electrical knowledge so maybe I'm missing something obvious. I also can't view the images from work so there could be something obvious there that would answer these questions.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by mnuttall View Post
    Two questions:
    It doesn't. I've been trying to tell people this but they all want to believe Phil because he's well known.
    Don't get me wrong Phil, your DIY is beautiful and well done, it's just over the top for someone like me who already knows the facts and figures.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 16 2008
    No hard feeling Man,all good and after all it's your car.
    Phil
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Phil
    exactly, I took a shortcut, where as you did the more professional way of doing it is all
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 03 2012
    Jeep Comanche
    You can easily remove solder using your soldering iron.
    -Chadwick
    FULLY BUILT ENGINE!
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yes I'm aware, it still doesn't deem soldering necessary
    if people need a DIY on how to put a resistor on the 2 prongs, they more than likely don't have a soldering iron
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by doublezero30 View Post
    hey nate, which led's burnt out quickly for you? the ecs ones, or different ones?
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    LED's aren't bulbs, so if they burnt out and they were the "Error Free" type and cheap (Ebay) then most likely a soldering came loose and or the resistor they put in place could have broken off
    This happened to me with a different set of ebay LED's, I had to solder a piece of metal on just to make proper contact
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 25 2011
    Seacoast NH
    Night time pics to be posted by midnight!
    May 21 2007
    Florida
    Just the cheap $7 bulbs. I just bought ecs ones to replace them.
    Feb 25 2011
    Seacoast NH
    Added pics and video to post #2 above.
    Bought some heat shrink and will add these tomorrow for extra protection. Will post updated pics for the DIY, because at this point, why not.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    well done sir.
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    Car looks great.
    I predict HID license plate lights to be the next trend.
