Results 1 to 32 of 32
    Established Member Two Rings brianB7's Avatar
    Apr 24 2011
    Pennsylvania
    White/grey smoke during acceleration
    Ive been having some problems with my car during acceleration.
    When accelerating at a quick rate (not WOT) but relatively quick especially while entering highways, my car seems to shudder a little and then throws up a cloud of smoke that appears to be white/grey. It usually lasts about 5 seconds (during which I get off the throttle) then seems to drive normal. I have recently replaced the valve cover gasket but this did not fix the problem. I have also had a cylinder misfire and when I pulled the plug it seemed to be covered in soot on the end.(I am pretty sure the plug misfire was due to the plug being set at the wrong gap which I have replaced all four and haven't been misfiring since. However I cannot get it to stop throwing smoke. My next thought is that it may be somehow related to the BSH PCV fix that I installed. While removing the valve cover I noticed that there was lots of gunk in the tube that runs to the oil filter adapter. I have a new stock PCV on its way along with new gasket and both hoses.
    My question is, do you think that this smoke could be related to the BSH PCV fix, and that returning it to the newest revision of the stock PCV valve will fix the issue?
    My second thought is that it could be either the head gasket and/or piston rings. Is this possible or if these were bad is it more likely that it would smoke all the time and not just during higher boost?
    I should also mention that while at idle my vacuum seems to be running at a low (or I guess it would be higher) my boost gauge is an electronic one from dynotune and only measures in PSI. (It usually runs at -11.2 PSI at idle which with rough math equates to 22.4 HHmg. But is now running at around -8.4 PSI.)
    I am also throwing no codes other than one for my thermostat which will be getting replaced shortly.
    Any help would greatly appreciated.
    TIA
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    Is it idling rough?
    -Chadwick
    FULLY BUILT ENGINE!
    Apr 24 2011
    Pennsylvania
    Honestly its hard to say... the famous ticking noise sounds a little louder than normal (but that may just be in my head). However, the needle and the vacuum stay steady.
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Sounds like a boost leak... Check dv and PCV.
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Apr 24 2011
    Pennsylvania
    Thanks Lensch, but would a boost leak cause the exhaust to smoke? thats the only part that has me confused.
    I mean it is possible theres a boost leak plus another problem.
    Feb 20 2004
    Boost leak would cause abnormalities in the idle/level of vacuum, abnormalities in wot boost pressure, and a smoking exhaust due to running rich (car isn't getting enough air).
    A healthy car pulls around -23in.hg at idle once warmed up.
    Previously:
    Apr 24 2011
    Pennsylvania
    Alright thanks I really appreciate it. ECS has just sent an email saying my new pcv is on the way so I'll post here if it fixes the problem or not.
    Thanks again
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I always thought if the car were running rich that the exhaust smoke would be black and sooty. White or light gray smoke is usually the sign of burning oil. Brillo
    Feb 20 2004
    Quote Originally Posted by Brillo View Post
    If its running massively rich without a converter, yes.
    Previously:
    Active Member Two Rings miles1324's Avatar
    Dec 14 2011
    Oregon
    I have the same issue! I've had my PCV replaced again but it still is doing the same thing. My idle seems fine but after the smoke, my temperature gauge needle goes almost down to 1/4. I'm at 77k miles and have had my tb and thermostat replaced already. Also, my car has trouble going up hills and I have to take it easy just to make it up. I'm not sure what to check next. I haven't changed my valve cover or checked my dv yet so maybe that will help.
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Had the same issue and a catch can from 034 MS fixed it. Not really sure if that was it but since then the car runs great.
    Apr 24 2011
    Pennsylvania
    Well the Pcv should be here by this weekend. Ill toss it on and see if it helps. But given that the idle isn't rough and it is only periodically smoking is it safe to say its most likely not the piston rings or head gasket I honestly don't have the time to tear apart the engine seeing I'm currently in the mid of my semester
    Dec 30 2012
    96' Volvo 850 GLT
    Saint Louis, MO
    I have had the same issue. My mechanics and I suspect that the it was caused by oil in the intercooler being sucked out at high boost and burned in the engine. I just took her up to 6k RPM in 3rd gear on the highway for a bit and it went away.
    Apr 24 2011
    Pennsylvania
    I'd love to try that Chris. But I'd hate to do it and have the issue be something else and cause a hell of a lot more damage ha maybe ill keep that in mind for a last ditch effort.
    Apr 24 2011
    Pennsylvania
    On a side note does anyone know when water fest is this year. I live in Philly and have never been but def want to make it this year
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by brianB7 View Post
    The only way to tell is with a cold engine compression test.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    May 20 2008
    2013 Passat TDI
    You might damage your CAT
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Apr 24 2011
    Pennsylvania
    I have a test pipe ... Sorry forgot to mention that in the original post
    Feb 20 2004
    Under boost. The stock pcv system will actually re-route some air back into the turbo charger. This winds up dumping any oil/fuel in the PCV system into the intercooler or in through the intake.
    Even a BSH PCV fix will dump oil into your intercoolers. Typically, most catch cans will too. The only way to fix the problem for good is to use a setup similar to mine seen in the thread below
    http://www.audizine.com/forum/showth...rbon-for-Good!
    -Dan
    Previously:
    Feb 20 2004
    Also forgot to add that carbon buildup can cause your car to smoke as it makes the car run rich. Reason why I ruled that root-cause out is because carbon buildup wouldn't fuck with your vacuum pressures
    Also, the wastegate actuator arm anneals over time as and makes it so your car will eventually request goofy boost numbers. Lots of high mile 2.0t cars suffer from "lost boost" because the actuator arm is not annealed well enough from the factory. No one has actually come out and said that's what causes this phenomenon. But, I'm telling you and everyone else right now that this is the root cause. Reason why I ruled waste gate control out is because while it does mess with boost numbers, it’s almost unheard of for cars running stock boost. Also, a wastegate acting goofy most likely wouldn’t mess with vacuum levels at idle.
    -Dan
    Previously:
    Dec 30 2012
    96' Volvo 850 GLT
    Saint Louis, MO
    Tryin to bump this up for more info....
    Not sure about everyone else's issue, but I'm only smoking under high boost, and it seems to be happening all the time. Car is totally stock. I did have the PCV replaced to the new model under warranty, but it seems like something related is allowing oil to be dumped into the turbo and/or intake as well as the intercooler I suppose. I little bit of oil getting sucked in is acceptable, but enough to cause so much smoke tells me theres something wrong. I'm also suffering from excessive oil consumption.
    May 20 2008
    2013 Passat TDI
    ^ do a compression test
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Apr 24 2011
    Pennsylvania
    Quote Originally Posted by ChrisS417 View Post
    Im also having excessively high oil consumption. It sounds like were in the same boat. Its odd that your having this with a completely stock car, I guess that means it has nothing to do with my aftermarket parts. Ill be putting on the new pcv saturday. I'll let you know if it changes anything. I guess after this I'll either be doing a compression test or just dropping the 200 or so bucks to let audi tell me whats wrong with it.
    Oct 16 2012
    Baltimore MD
    Wow My car smokes also and I didn't know it was the car running rich. I tried the pcv delete where I have to run a intake manifold plug and the car runs rich causing it to smoke. Why does running the plug cause the car to run rich. Also I know it's not burning oil because running the the normal pcv, it doesn't smoke.
    Quote Originally Posted by Lensch09 View Post
    Feb 20 2004
    Quote Originally Posted by Lemon123411 View Post
    What?
    Previously:
    Oct 16 2012
    Baltimore MD
    http://www.audizine.com/forum/showth...30#post8451130
    What?
    Apr 24 2011
    Pennsylvania
    Update: I installed the new stock PCV and immediately the idle was erratic and there was a high pitched whistling noise (I'm guessing boost leak but why would putting the stock pcv on make it worse?) I'll be reinstalling the BSH pcv revamp tomorrow so its at least drivable. So im trying to figure out what my next move is. Any thoughts? I may just have to take it in to the dealer and let them diagnose it for me, at least that way I'll know exactly what it is.
    Mar 01 2016
    San Diego/CA
    Is your problem fixed? I am facing the same issue.
    Apr 24 2011
    Pennsylvania
    Quote Originally Posted by hemantpd1 View Post
    So it's been awhile since I have been here. I no longer own the Audi and haven't for a few years but I saw this in my email and wanted to get you an answer. Did you also replace the I think it's called breather valve? It's the silver metal tube looking thing? Turns out the revamped pcv required a revamped one of those as well as they changed something in the pcv that required it.
    Mar 01 2016
    San Diego/CA
    Thanks for your reply. I will check breather valve and DV today. I have started a thread and wrote my symtoms at: http://www.audizine.com/forum/showth...ing-on-freeway
    Can you check if you were facing exactly the same issue?
    Apr 24 2011
    Pennsylvania
    Ok I didn't realize you were talking about the smoking. Turns out I had a turbo seal leak one way to check this is to pull the ic pipe off the intercooler and kind of tilt it down. You may want to put something underneath it because when I did this a ton of oil would come out. If that's the case chances are you're going to need a new turbo. I picked one up in the classifieds for about $200.
    Mar 01 2016
    San Diego/CA
    Will check that.
