First post here. Please forgive me in advance as I am pretty incompetent when it comes to cars! I have a 2003 Audi A4 3.0L with 127k miles.
Recent history:
Last summer: Turn signals started going bonkers. Had it in the shop several times, and the problem always came right back. Last time they said I need a new turn signal module maybe? but could not find part. I said screw it. A week later the windshield wiper fluid stops spraying. Fuse is blown. Replacing fuse fixes problem but the fuse blows quickly again. Strangely, the turn signal problem has more or less corrected itself over the cooler months but wiper fluid issue remains.
Two months ago: Check engine light came on with no obvious symptoms. Then I noticed that the car had some episodes of needing to turn over longer than uusal in order to start. Had the battery checked at auto zone, and it was fine. Check engine light code was for the catalytic converter/O2 sensors.
Took car to shop last week, as I noticed RPM "surges" when accelerating at sub 2k RPM range. Idle may be somewhat rough. Shop "fixes" windshield wiper issue with new fuse. Oil change, tires rotated, new spark plugs, and a new coolant temp sensor. Catalytic converter tested fine so no new O2 sensors, and they cleared the engine CEL.
Windshield wiper fluid works one time and then dies as I leave shop parking lot, lol. Engine "surge" issue is not fixed and CEL returns about 20 miles later. Car now shudders a bit when accelerating from low speeds/dead stop. Engine seems good as new at 2k+ rpms.
Sound like a coil pack problem? Makes sense to my novice brain. Engine misfires, fuel makes its way into catalytic converter, and the CEL with P0421 code appears.
Any ideas for the turn signals and wiper fluid issues?
