Results 1 to 14 of 14
    In, Out and Around...
    2009 vs. 2012 vs. 2013 engine changes...
    i recall a thread from a few months back with photos of a 2012 engine and a 2013 engine compared to a 2009 engine. i cannot find it anywhere with the search function or through google. does anyone here have a link or know which keywords to search under?
    the photo of the 2012 engine highlighted additional components by the oil filter and an updated pcv while the 2013 (iirc) had an aluminum intake manifold along with the other updated bits the 2012 engine had installed.
    also there was a technical training manual in .pdf form that was floating around and i cannot seem to find that either. i found the original one for 2009 release but cannot find the one pointing out the revisions/changes.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    I think you're referring to this one.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    bingo! that's one of them... you're awesome... thank you!
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Lots of internal changes ....should be good for long term use. Not to keen on E85 use...
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    no interest in e85... i was just curious about the changes. also i recall "jtech" (our resident audi tech) mentioning several internals that have been changed in 2011-2012 engines and of course the 2013 just cant find the list of items.
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    So has anybody figured out if the new intake manifold can easily retro-ed?
    I'm guessing it should, since someday there's gonna be quite a few plastic ones that crack.
    Ryan - flickr
    Senior Member Three Rings strife1013's Avatar
    Jul 11 2012
    Denver, Colorado
    Anyone know what year they switched from the plastic to the metal manifold?
    2017 Audi A4 2.0T Quattro Prestige w/ Seven-Speed S Tronic Dual Clutch Transmission, Manhattan Grey w/ Black Interior and Headliner, Warm & Cold Weather Package, Sports Package, Grey Oak Natural Wood Inlays, 19" 10-V-Spoke-Design Wheels
    2013+
    Established Member Two Rings pneks2001's Avatar
    Apr 21 2010
    2012Acura MDX
    Mobile/AL/SE
    But not on all 2013. I have the plastic.
    2013 black on black prem plus sport 6 SPD.tinted windows and vag com. VMR 701
    really? what is the build date?
    Aug 03 2010
    Northern NJ
    Quote Originally Posted by iconoclast View Post
    FWD and 6-speed manual A4s still have the CAEB engine. Audi specifically stated that only cars equipped with the 8-speed automatic would be E85 compatible and have the CPMA engine.
    The Nice Car:
    2018 Ibis White Audi A4 quattro 2.0T - Have HEX+CAN VCDS, PM Me
    The Hoopty Beater: SOLD
    1987 Alpine White Audi 4000cs quattro "special build"
    ah, i wasnt aware of that... thank you for clarifying.
    Junior Member Two Rings
    Oct 08 2012
    Calgary
    Tried googling CPMA and CAEB engines but didn't have much luck. What does this mean other than E85 compatible?
    Aug 03 2010
    Northern NJ
    Funny the first result when you google "CAEB engine" is a thread I started about the engine burning oil back in 2009! VW/Audi uses codes to uniquely identify an engine configuration. It covers not only the block itself, but the fuel delivery system, and the emissions controls used.
    The Nice Car:
