Results 1 to 10 of 10
    Registered User Three Rings
    Sep 25 2012
    West Va.
    B8 A4 2.0l Down-pipes & Turbo-backs by Steve Petty Motorsports
    Fresh out of production - on the shelf ready to ship.
    Street Down-pipe $643.82
    B8 A4/A5 2.0T Stainless Steel 3-inch "Street Edition" Down-pipe
    The 2.0T Street Edition Down-pipe features a 200-Cell, High Flow, Metallic Catalytic Converter. It reduces noxious exhaust fumes when compared to Cat-less systems and keeps the emissions of the vehicle within spec. It's the perfect compliment of refinement and performance from a down-pipe. The down-pipe also includes a reducer that mates up to the OEM Cat-back and is completely interchangeable with the SPM V-banded Cat-back Exhaust System.
    **You need to perform your own due diligence within your area to determine what specifications of catalytic converters meet your local DOT standards.**
    Track Down-pipe $493.67
    B8 A4/A5 2.0T Stainless Steel 3-inch "Track Edition" Down-pipe
    The 2.0T Track Edition Down-pipe features a free-flowing, straight-through design that enables your engine to extract every last bit horsepower at that track. It's also designed with an interchangeable straight section that allows you to swap out your SPM catalytic converter in minutes. It's designed with a raw and visceral concept to power your way around the track. The down-pipe also includes a reducer that mates up to the OEM Cat-back and is completely interchangeable with the SPM V-banded Cat-back Exhaust System.
    **This does not include a Catalytic Converter. Recommended Track Use Only*
    SPM Guarantee System Features-
    Aircraft Grade T304 Stainless Steel .0065 Wall Thickness
    Ported and Polished Flanges with Flow-matched Connections
    Robotically Pulsed TIG-Welded Systems
    Interchangeable, Quick-Release, V-Banded Design
    Brushed Matte Finished for Increased Resistance to Oxidation and Corrosion
    Standard O2 Provisions and Fittings
    Street Turbo-back $1747.20
    Street Turbo-back without Cat $1597.05
    B8 A4 2.0T Stainless Steel 3-inch "Street Edition" Turbo-back Exhaust With Cat
    The A4 2.0T Street Edition Turbo-back Exhaust System features a High-Flow Design that utilizes chambered and drone reducing mufflers that maintain optimal performance and sound without sacrificing power and performance. Our corrosion resistant T304 Stainless Steel and TIG Welded construction enables our exhausts to withstand the test of time, rain, sleet, salt, and any other element you can throw at it. SPM has taken the aggressive design cues found on the S-line packages and incorporated a dual tip system for that unique and performance oriented look that your A4 demands.
    The 2.0T Street Edition Turbo-back Exhaust System is the most complete, highly optimized, and powerful system to run the streets. It features a 200-Cell, High Flow, Metallic Catalytic Converter, specifically tuned mufflers and resonators, quick and easy interchangeable design, and an overall unmatched fit and finish. There is no other system like this out there. It was born on the track, but it's been tuned for the streets.
    Our IDS system is completely interchangeable and enables you to effortlessly change out individual components and upgrade your system for sound or performance or for the street and track.
    ** The SPM B8 A4 Exhausts requires: **
    S-Line Valance for Pre-2012 Face-Lift Models. Audi Part Number 8K0898019
    OEM Passenger Side 3.2L Heat Shield. Audi Part Number 8K0804172
    OEM Heat Shield Clips. Audi Part Number N90796502
    OEM Passenger Side 3.2L Exhaust Hanger Assembly. Audi Part Number 8K0253144M
    Aircraft Grade T304 Stainless Steel .065 Wall Thickness
    Product Videos
    Product Page
    http://www.drivespm.com/category-s/1835.htm
    Find a dealer near you!
    http://www.drivespm.com/Articles.asp?ID=250
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Good lookin' setup... nice sound, too.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Veteran Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    I have the track edition and its the best setup I've seen, highly recommend SPM
    2009 A4/Brilliant Black/6MT//Usual Vag-Com mods//A5 5 spoke "y" rims with Michelin 255/35/19 super sports//bilstein pss10's//rs4 grill//rs4 grills//S-Line side blades//Ecode halogen to bi xenon conversion//LED bulb interior swap//AWE quad tip exhaust//Eurocode Short Throw Shifter/inlet pipe/sways/end links/alu kruz//S5 front brakes//APR carbonio intake//SPM Test & downpipe//APR stage 2 flash
    Veteran Member Three Rings sickspeed's Avatar
    Sep 12 2005
    2001 S8 and 2011 Q7 TDI and 2010 Toyota Land Cruiser
    MD
    is the front pipe and reducer available separately and do they mate up with other high flow cats, e.g., eurocode's? price?
    2001 S8 or 2011 Q7 TDI Modded.
    Previous Audis: Red 1987 4000 CS, Dolphin 2002 A4 3.0 6MT Sedan, Atlas 2003 A4 3.0 6MT Wagon, Dolphin 2006 A4 2.0T 6MT Wagon, Meteor 2009 A4 2.0T Wagon S-Line .[/I]
    Veteran Member Three Rings svirk2's Avatar
    Jan 19 2012
    99 C43 AMG 1 of 546
    Northern Va
    nice
    2002 A6 2.7T APR tune
    Bilstein shocks
    HR springs
    18' b5 rs4 reps
    Sep 25 2012
    West Va.
    Quote Originally Posted by sickspeed View Post
    Our system utilizes a V-band flange which is not compatible with the 3-bolt flange on the Eurocode piece.
    Established Member Two Rings RainReign's Avatar
    Dec 12 2011
    North Dakota
    I've got the Street Edition paired with AWE quad tip cat-back. Definitely gets people's attention and it sounds amazing. They also have a great military discount.
    Highly recommend SPM for your HFC and downpipe.
    2023 Audi RS3 | Turbo Blue
    Gone: 2020 Audi S4 P+ | Glacier white
    2012 Audi A4 P+ Quattro | Ibis white | Nav w/ backup camera | Sport Package
    CTS Turbo K04 | APR K04 v2 Tune | CTS Turbo Catch Can | CTS Turbo FMIC
    GFB DV+ | AWE Cat-back | 034 Transmission insert | EuroCode Alu Kreuz| H&R Coilovers | VMR V713
    LEDs | VAG-COM | P3Cars gauge | oCarbon | Deval | aFe
    Apr 05 2011
    Pacific Northwest
    I'm hoping to replace my APR Downpipe setup with the SPM Track Downpipe setup sitting in my garage by the end of this week. My goal is to do some before & after on sound and power. I am also thinking of buying the cat pipe for emissions testing swapping in and out as needed.
    Highlander's Build Thread
    Apr 08 2012
    South OC, SoCal
    I have been waiting to hear SPM system for so long finally get to hear it and it sounds great! Now to buy one I guess.
    Sep 25 2012
    West Va.
    Thanks for the positive feedback, guys!
    NoR32 - PM coming your way.
