Results 1 to 40 of 43
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    4" Oval exhaust tubing
    So, I am going to be getting 034 3" dp's soon enough and want to do a 4" custom single exhaust, but am concerned with ground clearance. Been talking with a few members privately and would like more input. I don't remember if this topic has been discussed or not? If so, I apologize in advance.
    Anyone have any experience running the oval piping? Doesn't even need to be experience with doing it on Audi's but of course preferred. Inteterested in preserving as much ground clearance as possible but flowing as much as possible. Flow is nominally less when considering 4" oval vs 4" round, closer to 3.5" round but a bit better. Kind of in the middle, but still better flow and clearance than the 3.5 single.
    Overkill or just go for the full 034 treatment and be done with it.
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    I'd be down for an oval 4inch exhaust...
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    mine does bump/hit on a lot of surfaces. have to poke over speed bumps, come up my driveway at an angle. maybe just straight up 4" and then oval in a few places?
    RS6 hybrids and corn
    Jul 18 2009
    Re: 4" Oval exhaust tubing
    Quote Originally Posted by bigern45 View Post
    Thought about that too, mixing in oval where best suited. What kind of mufflers and where are they located? I'm looking at vibrant products (4" inlet with dual 3" outlet) for rear muffler, but been told a mid muffler and rear resonator would be quietest in cabin, which rules out my idea of keeping a dual tip exit. But, would think it is easier to stuff a rear muffler up high enough rather than mid in order to maximize clearance. More thoughts and input please.
    And I scrape with my dual 2.5. Even had to construct ramps out of box steel for my driveway. Lame! Too narrow to come in at enough angle.
    Sep 28 2009
    ky
    ^ yes and coilovers with the car lowered make scraping more abundant. i have 2 magnaflows, not sure exactly which model number or anything. im sure the vibrant product works well.
    Jul 18 2009
    Ya. Sitting at 25 gtf on all four corners. Not slammed by today's standards but lowered nonetheless.
    Btw, is your exhaust sound clip posted in the consolidation chatterbox thread? Interested to hear it.
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    I have considered doing the exact same thing for clearance. I think having oval tubing made would get pretty expensive...
    Found this. Kinda spendy!
    http://www.spintechmufflers.com/oval.../prod_106.html
    WTB - Electric high flow fan kit - FORGE 007 DVs
    Jul 18 2009
    It comes pre made oval from several sources. One being vibrant in 5-6 ft lengths...$205 - ouch!
    Also saw another being Dr Gas and spintech above
    I'm wondering if I can downgrade to mild steel as I live in relatively mild climate as a means to cost savings. Then again it costs what it costs. Ssac aside, mass produced systems aren't cheap either (price wise, not quality for all ssac fans out there).
    Jun 29 2010
    I have an ssac exhaust and you know what? I would be happier if it were made from a thicker mild steel to do away with some of the rasp and resonance.
    I've not done much research on inhibition of corrosion in mild steel, but living in Denver, I've often considered it as an option as there isn't too much to worry about in the way of rust and corrosion.
    Sep 28 2009
    ky
    there is a clip on here of it without the added rear muffler, which after a spin down the road i realize that i needed. ill try and get one of the finished product soon. maybe a video from across the way?? http://www.youtube.com/watch?v=DXg7CecyN0U
    Jul 18 2009
    I'm still concerned about restriction and flow obviously and don't want to cut performance and still don't know the extent of sacrifice by going oval vs round
    Jul 18 2009
    Damn that's definitely loud. A bit much for my wants maybe, but tamed down with second muffler?
    Kinzer with a z? Not Kinser of the world of outlaw sprint car fame?
    Sep 28 2009
    ky
    lol.. no. that IS with the second muffler
    Jul 18 2009
    Ah. Damn that is not stealth, is it!?
    Hmmm, full ss?
    I fully understand there often being a trade off between performance and comfort. Anything you think would help tone it down some? If you were so inclined but still keeping the 4"
    But I gotta say I keep going back to get a 2nd, 3rd and 4th listen...:)
    Sep 28 2009
    ky
    honestly if i knew how it would sound now i would have stayed single 3 all the way back, then when i build my next one, do some cutouts of some sort for kill mode or drag racing. hindsight.
    Jul 18 2009
    Thanks. Maybe I need to accept 3.5 as a reasonable compromise.
    May 13 2011
    2015 BMW F30
    3.5 is pretty much all you need.
    | Autospeed | JHM | Pure MS
    Sep 28 2009
    ky
    Quote Originally Posted by happy2B5 View Post
    Hmmm, full ss?
    dont get me wrong - at WOT, it sounds fantastically glorious!! whenever im pushing that hard it just adds to the adrenaline rush, i love it! but driving around town, @35 or so, it definitly is overkill, and i my power level is only 6-10 more whp. 80 on the highway is down right rude. s4 00 2.7 is right, you really dont need that much flow, unless youre pushing 600+whp.
    Veteran Member Four Rings Jupiteraudi's Avatar
    Mar 29 2009
    01 S4 Avant 6spd, 08 S4 DTM pkg.
    Jupiter
    Hey Haps, I have 034's 3'inch DP's for 770's matched up with their 3.5inch exhaust and I love it. Fitment is good and much better than my AWE twin 2 setup. If you're concerned about keeping things quiet then it might not be the best route. The bigger DP's are a tremendous improvement. I also swapped my 2.5'inch AWE DP's for the above.
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Stop it. Please.
    Dual 3 inch, or dual 2.5.
    Oval 4 is retarded.
    RIP Daz, you will be missed.
    Jul 18 2009
    Quote Originally Posted by Meow View Post
    Stop it. Please.
    Oval 4 is retarded.
    Dual 3 is retarded as far as clearance and nvh threshold goes. And dual 2.5, well I already have that and looking to gain more flow and free up restriction. Seen dual 3 in action as I'm sure many others have. No thanks. And this is more a discussion about 3.5 or 4 single, but thanks for playing...
    Mar 08 2012
    MI
    Is this yours? Its from the same channel, just curious. http://www.youtube.com/watch?v=gbIgHg0SJqU
    Jul 18 2009
    Quote Originally Posted by Jupiteraudi View Post
    Thanks for more real world experience. What muffler setup did you opt for, mid or rear (or both)?
    And I am not overly concerned with quietness, however not looking to be ridiculous either. I think I am leaning toward a 3.5 single system. Most likely 034 or custom.
    What bothers me if you will is some of the pictures I've been seeing of 034 3.5 vs say the RAI system. The 034 sags considerably more than the RAI. The RAI system seems noticeably better fitting and more ground clearance friendly. Mind you this is just through casual internet viewing but quite noticeable nonetheless.
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    I made my own custom 3" dp's to 4" single. I also thought about doing 4" oval in some spots but I think the headache and little extra cost wasnt going to warrant the minimal extra ground clearance. The lowest spot on my system is the 3" v-band clams regardless. I have a vibrant 4" in dual 3" out muffler and an 8" race muffler but I would suggest the 12" reace muffler/resonator if you want it a little quieter. Im also catless.
    Tial 605's EPL Tuned
    Lots of other goodies.
    Jul 18 2009
    Quote Originally Posted by RusS4 View Post
    The 8" race in mid position and dual 3 out rear I assume? I believe vibrant product #1155?
    Is your clip on the exhaust consolidation thread? Got one to add to this or that thread? Thanks.
    Mar 29 2009
    Jupiter
    Single muffler in the rear with the mid-pipe to their dp's. It might be considered ridiculous to some, everyone is different, for me it has created a love for overpasses! After driving my b5 for several days, it makes my b7s4 (miltek dp's and stasis exhaust) seem quiet. Completely different exhaust notes but you get the idea.
    Jul 18 2009
    Care to share an exhaust clip?
    Mar 29 2009
    Jupiter
    I'm pretty sure the only vids I have are from my gopro so the wind noise drowns things out. I'll check.
    Sep 28 2009
    ky
    uhh.. yeah. before the tranny swap.
    Mar 29 2009
    Jupiter
    This one isn't great at high speeds, exiting turns is a little better. I'll look for others.
    Jan 11 2007
    Salt Lake City, Utah
    Here's a pic and some sounds of my 4" exhaust. The rear muffler is the Vibrant dual 3" out single 4" in, and there's a small resonator in the middle (thinking of replacing resonator with a second muffler). In the video the car has no interior door panels, but it is pretty loud daily too. Pretty low as well. Unless you're looking to go balls out, I'd prob suggest to just stay 3.5" for ground clearance and all around ease.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Thats a good looking exhaust Jibber, nice work
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 18 2009
    Thanks for posting yours jibber :thumbup:
    I am leaning toward 3.5 atm but have not ruled out the 4 yet.
    Veteran Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    Heres a shot of my 4" just for comparison. I would also prefer a 3.5" simply for ground clearance and in my opinion the 3.5" would flow plenty for my needs. Not sure if its true but I have also heard from multiple people that the 3.5" drones less
    BMW E30 Holset hx35
    B5 S4 Brilliant Black
    B5 S4 Avant: Imola Yellow (retired)
    Mar 29 2009
    Jupiter
    I'm such a dork, I probably could have posted the link.
    http://youtu.be/U802f1jyFgI
    Jul 18 2009
    Was gonna say! Doh!
    Thanks jupiter
    Veteran Member Three Rings s4cappa's Avatar
    May 19 2009
    cars
    ma
    3in dps to single 3.5in cat back fits perfect not even as loud as my awe twin one and its only got a crap muffler on it.
    Jul 18 2009
    Nice! I would like to find out the same. My tt dual 2.5 system is pretty damn loud actually.
    Jan 17 2010
    Boston, MA
    nice looking setup cappa
    BMW E30 Holset hx35
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by zdriver View Post
    X2 !
