Results 1 to 9 of 9
    Veteran Member Three Rings karrann's Avatar
    Jul 13 2012
    Nogaro Avant
    Misfire on Cold Starts. And NGK BKR6E vs BKR7E?
    So My car seems to misfire for a small duration on cold starts. When I first crank the car its fine and As the revs approach 1000 RPM it starts a shake a bit and it continues shaking until it starts to idle and then the shaking gradually goes away and usually can't feel it after that. So i figures id start with the spark plugs and gap them correctly and is that doesn't fix it then more to the Coils and possibly even the ICM. I run stock boost right now on stock everything. What are good plugs to get that won't leave me broke. Ive read good things about BKR7E and some say BKR6E are better. Whats the difference and has anyone tried both that can tell me from experience? As I've said I do run stock right now but I do have a spare GIAC ecu I might go to in the future. With that in mind what is the best gap I can run them at?
    Active Member One Ring Jnsnjohn's Avatar
    May 18 2010
    2003 Kawasaki zx636r
    Hudson/NH/
    HOT - NGK #6 (OEM Range for 1.8/2.7 Engines) - Stock car with stock boost/timing, or mildly-tuned car in cold climates.
    - NGK BKR6E (Copper)
    - NGK BKR6EIX (Iridium Version of the same plug above)
    - Denso K20R (Copper)
    - Denso IK20 (Iridium Version of the same plug above)
    - NGK PFR6Q (OEM Platinum) - If you're planning to stick with stock boost
    COLD - NGK #7 (One Step Colder) - Cars with basic "chip/intake/exhaust" bolt-on upgrades (K03, K04, etc): Drop one range.
    - NGK BKR7E (Copper)
    - NGK BKR7EIX (Iridium Version of the same plug above)
    - Denso K22R (Copper)
    - Denso IK22 (Iridium Version of the same plug above)
    COLDER - NGK #8 (Two Steps Colder) - Cars with bigger turbos will benefit from these, whereas a regularly chipped car may foul these.
    - Champion C63YC (Copper)
    - NGK R5672A-8 (Copper, Non-Resistor plug)
    - NGK BKR8EIX (Iridium)
    - Denso IK24 (Iridium)
    - Bosch F5DPOR (Platinum/Side Fire)
    Oct 06 2011
    Audi S4 /Wifes 2011 cruz..bleh
    Southwest Michigan
    You're just talking about as it comes down from fast idle on cold start right? Heavy misfire or occasional here and there? Tip or Manual?
    I'm running BKR7E on a Jfonz tune and change them out every other oil change they work well for me and are like $15 for the set of 6.
    Jul 13 2012
    Nogaro Avant
    Right. As it comes does its fine until it hits right around 1000 rpm and then it shakes. I think I'll go with the bkr6e. What should I gap them to? .034?
    Oct 06 2011
    Southwest Michigan
    .028
    Jul 13 2012
    Nogaro Avant
    That's for the bkr7e right? I've been doing some research some people say the bke6e work better with .032? U have any experience what that?
    Oct 06 2011
    Southwest Michigan
    I ran the PFR6Q platinum plugs when I was stock at .032 and didn't have any issues. Went to the bkr7e and .028 after I got the car tuned. I doubt you'll have any issues from the plugs either way on a stock tune.
    If the shake is just during cold start and goes away once past the initial warm up I would bet that it is related to cold start fuel enrichment. I would look at the coolant temp sensor, primary 02 sensors, and if Tiptronic the SAI system. Give it a scan and see what turns up.
    Senior Member Three Rings Sl0w_S4's Avatar
    Mar 18 2012
    BPT
    I have bkr7e on my stage 2 car gapped to .030 and I'm getting p0300 code and it has a slight misfire at ldle and also if I'm off the gas and stopped if I start coasting it misfires like crazy until I stop again.
    2000 S4
    Dillenger Tuned - RS4 K04 Housings with K24 compressor and RS6 turbine from SRM-JHM FMIC-034 Soild Mounts - 034 TBB
    Jul 13 2012
    Nogaro Avant
    That doesn't sound good lol. I just picked up some bkr6e plugs. Now just have to let the car cool and decide if I want to gap at .032 or .028
