Originally Posted by
DoThisMyWay
My only advice, get the cursing and swearing out of the way by doing the passenger side first. The drivers side is a breeze.
It's not that difficult. If you can replace the Tstat, you can replace mounts.
Made me think of...
034Motorsport Motor Mount Set (Street Density, Set of 2)
We're proud to announce the availability of the 034Motorsport's Street Density
motor mounts for B5, B6, B7, and C5 chassis Audi and B5 Chassis Volkswagen models! They are designed with performance in mind, and manufactured from high-durometer rubber for increased performance and durability, without sacrificing comfort.
These Street Density
motor mounts are manufactured from 50 durometer rubber, which is approximately 10% stiffer than stock. Since the mounts are also void-free and solid-filled, the resulting
mount is approximately 25% stiffer than stock, eliminating the slop associated with the factory mounts. The
mount bases are made from steel, and are much stronger than the factory aluminum ones, to cope with the added stress of spirited driving.
The result is greatly reduced drivetrain slop, crisper shifting, and minimal wheel hop, without any significant increase in noise, vibration, or harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mounts.
Features
- Manufactured from 50 durometer (Street Density) rubber with void-free construction
- Reduced drivetrain slop
- Decreased engine movement under load
- More direct power transfer
- Improved shifting feel
- Complete drop-in replacement of factory engine mounts
- Comes with protective sleeves
- Sold in pairs (one vehicle requires 2 mounts)
FREE SHIPPING!
