Originally Posted by
Mops
Certainly possible to do safely. I would get with some performance/race shops and let them recommend a shop that has done work for them or thier customers.
Yes I asked a number of shops and only one said they should be able to do it but would have to look at the wheel design first. Others said that it will weaken the wheels and they wouldn't recommend me doing this.
sirmium
So if I understand correctly, the wheels that you mistakenly bought has 57.1 bore and your s5 is 66.6 bore? If yes, then we are in the exact same situation.
You said that they drilled out 15mm deep? What does that exactly mean? I thought they only need to modify the diameter of the bore, if that makes any sense.
mxrz
It is entirely dependant on the wheel design. Without seeing the hub pad of the wheel in question, no one here can pretend to know the answer.
I'm sorry but I don't quite understand what you are trying to say here. The shop that I called also said I would have to bring the wheels in person and let him looked at it. I told him that I'm getting HRE p40, would all p40 have the same "hub pad of the wheeel"?
Thanks every one who responded!
